Perfect Photo Suite 7.1 update
Started Feb 18, 2013 | Discussions
johnsong Senior Member • Posts: 1,173
Perfect Photo Suite 7.1 update now shows my activated software as a "Trial"
Anyone else see this??
alexius
alexius Regular Member • Posts: 339
Re: Perfect Photo Suite 7.1 update
have just updated but have not this problem, instead it crashes a lot ... i am a big fan of what you can do with the suit and have been using it since the first version of PerfectTools, they have good ideas but they are very bad in implementing them ... i know i have to take screenshots at what i am doing cause suddenly the program will update my choices in a new way if they update them at all and then I have to quit and start all over again using my screenshots to redo the process ... too bad
Feel free to visit my gallery http://mediaman.dk
suddie1215 Veteran Member • Posts: 3,818
http://www.ononesoftware.com/support/3133/
The Perfect Photo Suite 7.1 update now shows my activated software as a "Trial" - Windows only
This is a bug with the latest update, but it has no impact on the actual use of the software and the software will remain registered and activated on the computer.
You can check to make sure the software is activated by going to the Help menu. In the Help menu options you will only see the option to "Deactivate...", which indicates the software is activated and you are experiencing this issue.
 suddie1215's gear list:suddie1215's gear list
Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS M Canon EF 50mm f/1.4 USM +11 more
