A77 Firmware Update
Started Feb 15, 2013 | Discussions
RobertBarnett
RobertBarnett Senior Member • Posts: 1,417
A77 Firmware Update
I can't get the .exe program to update the firmware on my a77. I have followed it to the letter and nothing. It never gets to the update section. I am using USB cable and battery.
Can someone please post instructions that they have used to update the firmware?
Thanks,
Robert
 RobertBarnett's gear list:RobertBarnett's gear list
Sony SLT-A77 Sony DT 18-250mm F3.5-6.3 Sony DT 30mm F2.8 Macro SAM Rokinon 8mm f/3.5 Aspherical Fisheye Epson WorkForce 1100
Sony SLT-A77
splashy
splashy Senior Member • Posts: 1,729
Re: A77 Firmware Update
Did you set the in camera USB setting and did you look at the EVF.
 splashy's gear list:splashy's gear list
Sony SLT-A99 Sony a77 II Sony 50mm F1.4 Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tamron SP 70-300mm F/4-5.6 Di VC USD +3 more
Stflbn
Stflbn Senior Member • Posts: 2,525
I've never had to look in the EVF to do a USB update. Ever. Back LCD screen for instructions yes... Viewfinder? No.
 Stflbn's gear list:Stflbn's gear list
Sony a6000 Sony Alpha 7S Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS +6 more
JimmyMelbourne
JimmyMelbourne Senior Member • Posts: 2,441
Did you perform remove hardware safely step?
 JimmyMelbourne's gear list:JimmyMelbourne's gear list
Sony Alpha DSLR-A300 Sony SLT-A77 Sony SLT-A37 NEX-5T Sony Alpha 7 +20 more
splashy
Meaning, did you select USB mass Storage
RobertBarnett
RobertBarnett OP Senior Member • Posts: 1,417
Got it bad USB Cable. Now updated. Thanks for the help everyone. You're all gems.
Robert
rickztahone
rickztahone Contributing Member • Posts: 527
I just did the update myself yesterday. I can't wait to try the hvl58 on it tomorrow to see if the flash exposure is indeed fixed as many claim.
 rickztahone's gear list:rickztahone's gear list
Sony SLT-A55 Sony SLT-A77 Sony Alpha NEX-6 Sony SLT-A99 Sony 70-200mm F2.8 G +19 more
Rexel99
Rexel99 Regular Member • Posts: 423
Yeah, I just found out that the 58 flash may be resolved with 1.07, wish they would include all these things in the changes list info...
And for the above, great to hear you got it all working but would perhaps be better to know what windows (OS) you were using and also if the USB port was 2 or 3 etc.. lots of variables for users doing updates...
 Rexel99's gear list:Rexel99's gear list
Sony SLT-A77 Sony 70-300mm F4.5-5.6 G SSM Sony DT 16-50mm F2.8 SSM +5 more
Morten Denmark
Morten Denmark Regular Member • Posts: 121
Do you need to install every A77 Firmware Update?
Do I need to install firmware 1.6 before 1.7? Or can I just upgrade directly from 1.5 to 1.7 or whatever the numbers are?
M!
lehill
lehill Senior Member • Posts: 1,859
Re: Do you need to install every A77 Firmware Update?
Just install the latest update (1.07). It contains all the updates from the very beginning.
Lance H
 lehill's gear list:lehill's gear list
Fujifilm FinePix S5100 Zoom Sony Cyber-shot DSC-RX100 III Sony Alpha DSLR-A850 Sony Alpha DSLR-A550 Sony SLT-A77 +26 more
