Repair a Canon 18-55 IS... worth it?
Started Feb 15, 2013 | Discussions
Bodhi Dharma Zen Regular Member • Posts: 325
Accidentally I dropped my 18-55 IS, and now it has trouble while focusing... apparently, it only focuses on the top right spots, but not in the center nor bottom left... it doesn't make strange sounds, well, at least nothing worrying, but.. my guess is that it lost its alignment or something..
My question is about the experience from other members, about repairing their lenses...
Thanks in advance!
iShootWideOpen
iShootWideOpen Regular Member • Posts: 341
Re: Repair a Canon 18-55 IS... worth it?
No!
the repair will exceed the value of the lens, around $80.
 iShootWideOpen's gear list:iShootWideOpen's gear list
Canon EOS-1D X Canon EOS 5D Mark III Canon EOS 5DS Canon EF 50mm f/1.2L USM Canon EF 85mm f/1.2L II USM +10 more
Bodhi Dharma Zen OP Regular Member • Posts: 325
80 bucks??? WHERE!?!??!
thats for the non stabilized version! mine is IS II !!
tkbslc Forum Pro • Posts: 10,598
No, just buy another on ebay
They go for like $80-90 used.   By the time you pay shipping and even a minimum labor cost, you are above that.
 tkbslc's gear list:tkbslc's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +3 more
The version II is only a cosmetic change, so don't concern yourself with that.  Both of the IS versions have the same AF motor and internal optics
Here's one for $80 buy it now.   http://www.ebay.com/itm/Canon-EF-S-18-55mm-f-3-5-5-6-IS-Lens-Image-Stabilizer-/370754373095?pt=Camera_Lenses&hash=item5652aec5e7
Plenty more like it.   If you prefer the v2 they are maybe $10-20 more, but like I said they are the same lens other than the coloring of the body.
thanks!
jackpro Regular Member • Posts: 376
buy another & dont bother with a filter they are cheap as chips & very sharp IS versions only
 jackpro's gear list:jackpro's gear list
Canon EOS 5D Mark II Canon EOS 450D Canon EF 35mm f/1.4L USM Canon EF 85mm f/1.2L II USM Canon EF-S 18-200mm f/3.5-5.6 IS +4 more
