SEL50 lens , something inside loose..?
Started Feb 14, 2013 | Questions
geminihc
Regular MemberPosts: 111
Feb 14, 2013
i just got a used SEL50 lens and when i wiggle it, i hear something inside the lens that seems to move around and make some sounds like something is loose. is this normal ?
Brian Caslis
Senior MemberPosts: 2,926Gear list
Re: SEL50 lens , something inside loose..?
In reply to geminihc, Feb 14, 2013
Which way do you move it? If I shake lightly side to side I don't hear anything but if I shake lightly back and forth (along the axis of the lens) I do hear a small noise. If that is what you are hearing I would say it's normal. I've been using this lens for a few weeks with no problems.
 Brian Caslis's gear list:Brian Caslis's gear list
Fujifilm X-T10 Fujifilm XF 35mm F2 R WR Epson Stylus Pro 3880
geminihc
In reply to Brian Caslis, Feb 14, 2013
it rattles a little bit when shake it side to side. it rattles louder if i shake it up and down (long side).
fucntion wise, it does seem to be fine although i find it focuses about 0.5 to 1 second slower than the SEL1855 kit lens at the long end (~50mm)
Brian Caslis
The SEL50 does focus slower than the kit lens. Sounds to me like your lens is fine.
doinksdoinks
New MemberPosts: 18Gear list
In reply to geminihc, Feb 15, 2013
No rattling for my 50mm. Have your lens checked in the service center
 doinksdoinks's gear list:doinksdoinks's gear list
Sony Alpha NEX-6 Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS
muncungliar
New MemberPosts: 19Gear list
SEL 50mm is an OSS (optical steady-shot) lens so I believe the sound comes from the OSS component inside the lens. So it is normal
I never tried to wiggle and hear the sound on my 55-210mm lens which have OSS too, but I had a Canon EF-S lens with IS (image stabilization, equal to OSS in Sony) and have the same behaviour when it was wiggled.
Hope this help.
 muncungliar's gear list:muncungliar's gear list
Sony Alpha NEX-6 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +1 more
aap292
Regular MemberPosts: 145
In reply to muncungliar, Feb 15, 2013
If you live near a Sony store or place that has the 50mm maybe just try to see the lens and see if it has the same noise.
I can hear something tiny moving in mine and the same in the 18-55 but that sound is really quiet.
Kiichiro
Contributing MemberPosts: 509Gear list
In reply to geminihc, Feb 18, 2013
Never noticed this before until last night when shooting late at night. I heard rattling when I was shooting at a certain angle but no rattling when the camera is flat.  After a couple of tests I found out its the rings for the camera strips that was making the rattling sound when it rub against the camera body.
 Kiichiro's gear list:Kiichiro's gear list
Sony Cyber-shot DSC-TX20 Fujifilm X100T
