Yongnuo YN-560 III has built in receiver
Started Feb 14, 2013 | Discussions
victorian squid
victorian squid Veteran Member • Posts: 3,390
A little faster than I thought , but I think everybody's going to jump on this. I would assume future models will be TTL compatible (622), but for now there's an awful lot of 602-603 receivers out there.
Question - does this change anything for anybody if you were in the market for a new flash? Assuming of course you're invested in the 602-603's, or if you don't have anything yet.
There's a lot of interesting new technology starting to pop up out there. But, some of it looks like it requires investing in a given system.
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm f/2.8L II USM Tamron SP 150-600mm F/5-6.3 Di VC USD Canon EF 16-35mm f/4L IS USM +37 more
ktownbill Senior Member • Posts: 2,190
Re: Yongnuo YN-560 III has built in receiver
http://www.yongnuostore.com/product/yongnuo-yn560iii-yn-560-iii-ultra-long-range-wireless-flash-speedlite_canon/
I linked some more info.  The 560iii's are only $84 plus you don't need a receiver since it is built-in.  A real game-changer for sure. There is some info on backwards compatibility with the 602/603 receivers in the link.
I'm passing on these for the moment though because I want hss. I think these have a lower gn than the yn568 too.
Bill
ihgold2 Forum Member • Posts: 71
So, why are these guys like 85 USD, compared to ~500 USD for a 580EX II?
Ok, no HSS.  But do they work more or less the same?  I guess they can't be a Master either, correct?  But, do they work using E-TTL, just like a Canon would?  Can they be controlled from the camera (60D in my case) the way the EX IIs can?  Or only from the flash itself?
With the built-in receiver, would I just need to buy an RF-602 or 3 (or is there something else because I no longer need the receiver portion?) to trigger it remotely?
What else is there to consider when looking at the 6x price difference?  Even if build quality is not as good, you could buy and replace the YN a couple times and still come out ahead.
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,289
Ok, no HSS. But do they work more or less the same? I guess they can't be a Master either, correct? But, do they work using E-TTL, just like a Canon would?.
The YN-560 is a manual flash power control only hot-shoe flash. No TTL of any kind.
victorian squid and ktownbill, thanks for the info.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
victorian squid
victorian squid OP Veteran Member • Posts: 3,390
Thus, only working with the 602 and 603. You just know though that they've got a 565 or 568 version to work with the 622's in the works! For the price though - and those who prefer to work manually this is pretty neat. You could have a fleet of flashes and a trigger or two for the price of one 600ex-rt.
Starshot Contributing Member • Posts: 764
If they have one that comes out for my 622s I'll buy it!
jamesdo
jamesdo Junior Member • Posts: 25
Bill
YN560-III can do HSS for sure
how to do high speed sync with YN560-III
daviddavis71
daviddavis71 Regular Member • Posts: 434
It says it has built in RF, but I bought the yn560III and the RF603N, but can not get the flash to fire unless it is on the hot shoe of the camera or mounted on top of one of the RF603's.
I thought you were supposed to be able to fire the flash without having to mount it on a 603.  The flash recognizes a button press because the blue light flashes, but the flash doesnt fire.
Is it me?  Am I doing something wrong or am I misunderstanding how this should work.
 daviddavis71's gear list:daviddavis71's gear list
Nikon D5200 Nikon D610 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tamron SP 24-70mm F2.8 Di VC USD +1 more
fotowbert
fotowbert Senior Member • Posts: 2,046
YN560III works for me
daviddavis71,
My recently purchased yn560III built-in rf receiver works as advertised. With rf603NII trigger in hot shoe and yn560III set to built in rf trigger mode I get constant blue indicator light on flash while camera meter is live and flash fires upon shutter press. Blue light goes out when camera meter times out.
When triggering the flash with the rf603NII hand held I get blue indicator light on yn560III upon half-press of the trigger button and it fires upon full-press. The rf603NII trigger is set to "TX" mode to force it into transmit mode since it is not in hot shoe.
The original rf603N trigger does not have the "OFF TX TRX" switch so must sense it is in a live Nikon hot shoe before it will operate as transmitter. Perhaps that is your problem.
Also check the setup menu for it being set to operate as rf603 compatible and not rf602.
  • John
 fotowbert's gear list:fotowbert's gear list
Canon PowerShot A20 Canon PowerShot SD870 IS Fujifilm FinePix F31fd Panasonic Lumix DMC-LZ8 Canon PowerShot S95 +15 more
rockjano Senior Member • Posts: 2,450
I just ordered two YN560III for $46,55 each
The best bang for the buck for sure.
I like TTL and remote TTL control I use my D300 SB600-SB800 combo for that but in studio environment the manual is the only viable solution…
I hope they will work well with my RF602 set.
rockjano
daviddavis71
Re: YN560III works for me
Thank you for answering.  I have the rf603.  Maybe that is the issue.  Or maybe I need to get deeper into the menus of the flash to see if I can trigger flash.
Thinking about it, I did not try to trigger the flash by having the 603 on the hotshoe and flash set to RF on.  I will have to try that tonight.  Didnt even think of that, I was trying to trigger the flash with a 603 by pressing the button.
David
daviddavis71
Whoa, where did you get them for $47.00?  Is that US $$?  I just got mine for $74 on Amazon.  I only got one because I already have the 560II.
David
daviddavis71
Nope.  Did not work.  I will order the new 603.  They are only $35 a pair.  Hopefully they will trigger the old ones and now I have 4 units.
David
Hi
Yes the usual price is around $72 with free shipping on E-Bay.
I don't know why it was that cheap but I paid just that and I also bought one on the next day.
Sure I did not get them yet (there is one more week) so it might be fake as well, I hope not, I also got tracking number
Here is the link: http://www.ebay.com/itm/121267727614?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
52 AU dollar that is about 46.55 US dollar
I hope it is not a scam
jano
David
fotowbert
David
The original rf603 only goes into transmitter mode when it senses it is in a Nikon hot-shoe.  (There is a DIY mod to make it a transmitter by tricking it into thinking it is in the hot-shoe if you are so inclined) The new rf603 mark II models have a switch to do this.
Pressing the button on an off-camera rf603 is intended to be used for activating the shutter of the camera via a hot-shoe mounted rf603 with its shutter cord plugged into the camera's wired release port.
Also the yn560III must be in rf mode to operate with its built-in rf receiver.  Pressing the mode button on the yn560III cycles it thru 4 modes, normal (hot-shoe operation), S1 optical, S2 optical/digital delay, and rf internal receiver.  The icon in the lcd panel for the rf mode is somewhat obscure when it displays at the far right in the top row.
A needless complication IMO with the yn560III is it remembers a unique power level for each of its 4 operating modes.   It should be a global setting like the zoom head position.
You got to pay attention to the details to make this stuff work!
  • John
daviddavis71
When I put the 603 on the hot shoe and the 560-III on another 603, it works.
When I put the 603 on the hot shoe and the 560-III in RF mode, it does not flash. In this mode, when I push half down on the shutter release to focus, the blue light on the flash comes on, as does the flashing red light on the front of the flash, but flash does not fire with shutter release pressed all the way down.
fotowbert
YN560III likely defective
The YN560III is likely defective.
This indicates your rf603 on camera is transmitting OK.
Based upon your posts my best guess is your yn560III has some defect in its rf circuit. If you had access to some other transmitters and yn560III units you could probably confirm this. Looks like you should return the yn560III as defective.
  • John
