An Easy Way to Set Infinity Focus on DP Merrill Cameras
Started Feb 14, 2013 | Discussions
Scott Greiff
Senior MemberPosts: 1,578Gear list
Feb 14, 2013
Fukui-san today wrote a post today that gives a super-easy way to set the DP Merrill cameras to infinity focus.  The original article is here:
http://shinzlogclips.blogspot.com/2013/02/sigma-dp-merrill.html
The procedure is:
  1. Set the camera to Auto Focus.
  2. Turn off the camera.
  3. Turn the camera back on.  When the camera restarts, focus will be set to infinity.
  4. Turn the camera to Manual Focus to ensure the shutter won't auto focus.
 Scott Greiff's gear list:Scott Greiff's gear list
Sigma DP1 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD15
SandyF
Forum ProPosts: 14,885Gear list
Re: An Easy Way to Set Infinity Focus on DP Merrill Cameras
In reply to Scott Greiff, Feb 14, 2013
Does this mean that the camera is set at infinity essentially any time it starts up? You could then just switch to manual focus and it would be at infinity? I have mine set to turn off rapidly, so it's always off and on. It would be useful if it set itself to infinity focus each time (?)
Best regards, Sandy
http://www.pbase.com/sandyfleischman (archival)
http://www.flickr.com/photos/sandyfleischmann (current)
 SandyF's gear list:SandyF's gear list
Sigma DP2 Sigma DP1 Sigma DP2 Merrill Canon EOS 5D Mark II Sigma SD9 +5 more
Kendall Helmstetter Gelner
Forum ProPosts: 18,981Gear list
How does it know "real" infinity?
The procedure is:
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
PicOne
Veteran MemberPosts: 6,921
Re: How does it know "real" infinity?
In reply to Kendall Helmstetter Gelner, Feb 15, 2013
The procedure is:
Yeah.. infinity or beyond?  If you're willing to do all as described, why not put the camera in MF and just spin the lens focusing ring all the way til focus is at the end?
'Everything in photography boils down to what's sharp and what's fuzzy.'
-Gaylord Herron
Laurence Matson
Forum ProPosts: 11,291Gear list
The procedure is:
Maybe there is a reason why it focusses past infinity. Most lenses do, btw.
Laurence
laurence at appledore-farm dot com
Sometimes, life is going to hit you with a brick. Don't lose faith.
Steve Jobs
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
victorgv
Senior MemberPosts: 1,059Gear list
The procedure is:
It works and it faster then manual adjustment. . It focuses past the infinity but may be they did it such that when you use  aperture around f11 you still be able to blur everything but very distant objects.
 victorgv's gear list:victorgv's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP2 Quattro
victorgv
In reply to SandyF, Feb 15, 2013
Best regards, Sandy
It sets to infinity after power off power on in autofocus mode and remembers last focus distance in manual.
SigmaChrome
Veteran MemberPosts: 7,450Gear list
In reply to Laurence Matson, Feb 15, 2013
And so did Dave Bowman. He went to Jupiter - and beyond: The Infinite.
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD14 +14 more
PicOne
In reply to victorgv, Feb 15, 2013
The procedure is:
ability to 'focus past infinity' is by design to accommodate potential temperature (climate) changes, which as you can imagine heat etc.. makes things expand (eg. lens elements) etc.. and therefore affect where 'infinity', as denoted by the lens barrel, really is.
-Gaylord Herron
rick decker
Forum ProPosts: 12,625
In reply to PicOne, Feb 15, 2013
There was some discussion, somewhere, that perhaps there was less stress on AF by letting it go past infinity.  I have shot in a wide variety of weather conditions, and I have never had problems with AF that stopped at infinity.
Many I have talked with actually prefer an AF that stops at infinity. Nothing worse than having AF shoot out past infinity and you take the picture and nothing is in focus. Another 'questionable' advancement in technology.
Scott Greiff
In reply to Scott Greiff, Feb 15, 2013
To elaborate a bit more on the three shots shown in Fukui-san's blog post, the first one was shot with auto focus on the building.  The second shot was shot using the "Infinity Steps" in my original post, and the third was shot using manual focus using the magnification guide.
-Scott
I always figured that it was because you couldn't be exactly sure of where infinity was in any final lens build due to slight manufacturing differences, so you had to allow a little movement beyond infinity so that you wouldn't accidentally build a lens that could not reach infinity at all...
Also I guess it could be in support of things like closeup filters, where you can't even reach infinity anyway and so you may as well let it focus a bit more.
But the manufacturing thing is what made me wonder if it really knew where infinity was, though it could be calibrated at the factory to know I suppose.
In reply to rick decker, Feb 15, 2013
That could be a good use of the upcoming custom focus range for landscapes - you could figure out where "real" infinity was and set a range that stopped exactly at infinity so you could not overshoot.
I wonder (from another post) if exactly where infinity was would depend on temperature at all...
rick decker
When you go past infinity, nothing is in focus, at least in normal temperature ranges.  Hard to say about zero kelvin or 100 centigrade.
One mfr's rep  said it was to reduce wear and tear on AF be keeping iy from banging against the "wall". Possibly with the infinity point varying by focal length within a zoom, it was just adopted with primes for uniformity.  Or it was adopted because of mfg tolerances to prevent cameras going out that couldn't focus to infinity.
It would be interesting to know what the real reason was.
Roland Karlsson
Forum ProPosts: 21,620Gear list
Yes, thats it.
Old manual focus lenses had a stop at infinity, or maybe at hyper focal distance for max aperture. The latter is quite annoying if you need/want exact focussing.
Auto focus lenses can focus beyond infinity, partly because that decreases the need for accuracy when making the lens and partly because auto focus hunt back and forth, and then may need to hunt beyond infinity.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma DP2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited +8 more
Roland Karlsson
As I wrote above, I am quite sure the main reasons are two.
  1. It decreases the need for accuracy.
  2. It makes it possible to hunt behind infinity when searching for focus.
  3. Hmmm ... and maybe it also was to decrease tear when the lens hits the wall.
PicOne
In reply to Kendall Helmstetter Gelner, Feb 16, 2013
My understanding is that this is in fact the case.  Even my slr lens (eg. EF 35 f/1.4 does this)..  there must be a reason for this in all lenses.
-Gaylord Herron
