When is 50mm NOT 50mm?
4 months ago
I know when I buy a non-native lens for use on my NEX that I've got to multiply by 1.5. **BUT** when I buy a Sony E-mount lens do I still have to do the multiplication OR has Sony already figured that into the focal length? It's hard to believe that this hasn't been done, but then . . . I just don't know!
Silly question? ? ?
Stephen Lucchetti
Re: When is 50mm NOT 50mm?
In reply to slucc,
4 months ago
a 50mm lens is always a 50mm lens no matter what camera it's attached to.
http://www.daisyseyecancerfund.org/Files/Awareness/photographing_rb_poster.pdf
In reply to Glenn,
4 months ago
Definitely -- a 50mm lens is ALWAYS a 50mm lens -- that's physics. BUT, I guess the actual question should have been what is the effective focal length of the lens? When selling an E-mount lens is Sony quoting the actual focal length of the lens OR the effective focal length on their NEX system?
Is it really as simple as a 50mm lens is always a 50mm lens?
Stephen Lucchetti
In reply to slucc,
4 months ago
Silly question? ? ?
Stephen Lucchetti
When using 50mm lens on Sony Nex you get 75mm angle but 50mm depth of field.
In reply to slucc,
4 months ago
Stephen Lucchetti
It is only when you attach an adapter that legacy lenses change the effective range.
E-Mount lenses are directly attached.
Novice photobug, proud NEX-3 owner
http://davesnex-3photos.blogspot.com/
In reply to slucc,
4 months ago
Stephen Lucchetti
Sony is quoting the "actual" (35mm) focal length of 50mm (= 75mm equivalent field of view), 35mm (= 52.5mm equiv.) etc. It's confusing at first, but makes sense.
[edit:] The focal length of a lens is valid for a 35mm Full-Frame sized sensor/film. On the smaller APS-C sensor in the NEX (& most DSLRs/SLTs), less of the image circle of the lens gets recorded, reducing its field of view by a factor of x 1.5. Think of it as cutting a chunk off around the original image e.g. 50mm gets cropped down to a 75mm view (although its perspective doesn't change to a true 75mm view).
Alan
http://www.flickr.com/photos/59079068@N02/
In reply to slucc,
4 months ago
why are people making it so confusing for the OP?
Put simply, ANY lens you put on NEX requires a x1.5 on the FL written on the lens.
In reply to slucc,
4 months ago
they are quoting the actual focal length. you have to add in the crop factor of 1.5 to get your equivalent field of view on APS-C Nex cameras. this only matters really if you have experience with certain FL lenses on 35mm or full frame digital. if you've only ever shot APS-C then the focal lengths are going to seem familiar to you because the angle of view is the same. DOF is the same, but if you switch to FF you will notice the FOV changed but you will still have to select the same FL to get the depth of field you wanted from your APS-C experience. It might seem shorter but that's only illusion because the wider field of view makes it seems so.
Focal length is an absolute number
In reply to slucc,
4 months ago
Silly question? ? ?
Stephen Lucchetti
No, not a silly question. A lot of people are confused about this.
Focal length is an absolute number. A 50mm lens is a 50mm lens, on a NEX, on a full frame camera, or on whatever camera you use it. But the field of view will change on different sized sensors. When everybody used 35mm film, they called 45-60mm a standard lens, 45mm and below a wide angle, 60-105mm a short tele and everything above a long tele. On a NEX, with a 1.5 crop factor WHEN COMPARED TO 35mm FORMAT, you need to adjust this terminology. A 50mm on a NEX can not be considered a standard lens, because it behaves like a short tele on APS-C. So on a NEX, I would consider it like this:
Wide angle: 30mm and below
Standard: 30-40mm
Short tele: 40-70mm
Long tele: 70mm or more
Re: Focal length is an absolute number
In reply to zink,
4 months ago
zink wrote:
Silly question? ? ?
Stephen Lucchetti
Focal length is an absolute number. A 50mm lens is a 50mm lens, on a NEX, on a full frame camera, or on whatever camera u use it. But the field of view will change on different sized sensors. When everybody used 35mm film, they called 50-60mm a standard lens, 40mm and below a wide angle, 60-105mm a short tele and everything above a long tele. On a NEX, with a 1.5 crop factor WHEN COMPARED TO 35mm FORMAT, you need to adjust this terminology. A 50mm on a NEX can not be considered a standard lens, because it behaves like a short tele on APS-C. So on a NEX, I would consider it like this:
Standard: 30-40mm
Short tele: 40-70mm
Tele: 70mm or more
Quoted this, because so many other posts are just plain wrong or confusing.
In reply to zink,
4 months ago
Standard: 30-40mm
Short tele: 40-70mm
Tele: 70mm or more
What is considered wide or telephoto may be vary between photographers, but the consensus I got from here and most sites was that on full frame, <35mm is wide, 35-50(or even up to 60)mm is considered normal, 60-80mm is no man's land (hence rarely any full frame lenses were made using such FLs), 80-135mm is portrait(aka short tele), >135mm is telephoto.
why is 50mm on full frame normal? because 50mm is a human eye's focal length (maybe that's why it is easiest to make?), but what you see will not be exactly what you shoot if you used a 50mm, since when you are using a camera the lens is going to be closer to the subject than your eyes. Hence a lens ~45mm on full frame will be more ideal.
anyways taking into NEX's crop factor you divide my numbers above with 1.5, roughly giving:
wide: <23.5mm
normal: 23.5~33.5 or up to 40mm
no man's land: 40~53.5mm
portrait/short tele: 53.5~90mm
telephoto: >90mm
(I'm not exactly sure how the no man's land FLs came about, but I guess photographers just found it awkward as in it's hard to compose street shots or portraits with it)
50mm on NEX does make it a no-man land's FL, so your traditional photographer will be loathed in using it. However it's quite close to portrait and it's easy to make hence cheaper so the average shooter tends to accept it.
In reply to kev777zero,
4 months ago
Standard: 30-40mm
Short tele: 40-70mm
Tele: 70mm or more
wide: <23.5mm
telephoto: >90mm
Who is making it difficult now for the OP? Also, with zoom lenses, there is no "no man's land".
4 months ago
Because the focal length does not change, period.
Using a smaller sensor does nothing but crop the image circle from the lens, so it's the field of view that is changing, not the focal length, so using 1.5x the FL is an over simplification of what's happening.
In reply to zink,
4 months ago
Silly question? ? ?
Stephen Lucchetti
Standard: 30-40mm
Short tele: 40-70mm
But let's say i take a photo with nex using a 50mm and take a photo with FF cam using a 75mm lens, and i frame it exactly the same, will i get a similar image composition? I think NOT, right?
In reply to blakninja,
4 months ago
yes actually you will. the FOV will be the same in your example
In reply to Lightshow,
4 months ago
it is an oversimplification but the logic works. it'll only confuse people when you go too technical about it.
4 months ago
blakninja wrote:
Silly question? ? ?
Stephen Lucchetti
Standard: 30-40mm
Short tele: 40-70mm
Yes, that IS right. A 50mm lens on NEX will give the same FOV as a 75mm lens on a FF camera.
Edit: doubled Glenn's post. Sorry.
In reply to zink,
4 months ago
haha yes you're right
In reply to zink,
4 months ago
may I refer to my posting in an other thread about a similar question:
In reply to Glenn,
4 months ago
I don't think the composition will be the same. I will do some testing and prove you guys wrong
