Bowens light giving long beep.
Started Feb 14, 2013 | Questions
matt simpson
Contributing MemberPosts: 862
Feb 14, 2013
I have 4 Bowens lights, 2x 250 and 2x 500w (if memory servies me).
One of the lights has an intermittant fault in that it wont flash but gives a long beeping sound (about 1 seconds or so).
Anybody know what this could be?
Peter Berressem
Forum ProPosts: 10,647
Re: Bowens light giving long beep.
In reply to matt simpson, Feb 14, 2013
Matt, I'd assume that it's the retiring flashtube. In case the flashtube is the same type as in your other units (depends on the model) you could verify this by swapping the tubes.
cheers, Peter
Germany
matt simpson
In reply to Peter Berressem, Feb 16, 2013
I will try this.
I am sure that they are the same (BW2030 i think).
I need a special star/hex screwdriver (with hole for nipple) to take them off.
Will report back with what happens.
Peter Berressem
In reply to matt simpson, Feb 16, 2013
This tube is standard for all basic Gemini (R) or Esprit heads. AFAIK, you just have to pull the tubes from the socket, no screws are used there... ??
cheers, Peter
Germany
matt simpson
In reply to Peter Berressem, Feb 17, 2013
It has the 2 ends which just pull out, but in the middle it has a 'support' that is fastened to the tube with wire. This is screwed into the body of the flash housing.
I had a look at undoing the wire, but it didnt look as simple as it appeared, so undoing the screw would be the easier option.
Peter Berressem
In reply to matt simpson, Feb 17, 2013
The new tube comes without the support, though with the wire which you have to wind to thesupport foot. So, removing the support from the flash makes no sense at all, doesn't it? Also, you'd have trouble to fix the screw back, as the nut sits lose behind the front plate...
cheers, Peter
Germany
matt simpson
Ah, ok i see.
I will have to work out how to wind the wire off without having to undo the bracket then.
steveaps
Regular MemberPosts: 231
Hi, it's really easy just Un wrap the wire and the tube pulls out , do not do it any other way you will have a problem. Do it the suggested way very very quick.
Cherished
New MemberPosts: 2
In reply to matt simpson, Aug 27, 2013
Hi there, sorry to bother you but did you sort your long beep out?
I am having the same issue with my light & not sure what to do?
Cheryl
KernowTog
New MemberPosts: 1
In reply to Cherished, Oct 23, 2013
Same problem with one of my Bowens, I put a new tube in and the problem went away.
MatthewCP
New MemberPosts: 1
In reply to matt simpson, Jun 16, 2014
Hello,
I've just had a similar problem and have solved it so this may help other users.
I have a basic Gemini 400 and after using it I turned it off with the switch. It beeped for around a second at a time and the green light flickered continuously. I phoned Bowens support and the technician told me that the main rocker switch contacts can 'get stuck'. He advised me to turn it off and unplug it, then to rock the switch quickly from mains through battery and back a dozen times. I then plugged it back in and switched to mains and it now appears to work correctly.
I'm relieved that I don't need a new flash tube!
Hope that helps,
Matthew
