Help Please Is this mark the lense or the sensor?
Started Feb 14, 2013 | Questions
RenePR New Member • Posts: 22
I have been noticing these marks on my photos can someone tell me what is the cause of them (Upper Upper left hand corner).
Thanks in advance
edwardaneal
edwardaneal Veteran Member • Posts: 9,101
Re: Help Please Is this mark the lense or the sensor?
you have a bit of dust on your sensor - get a rocket blower and blow it off
NEX-7 & Sigma 30mm f/2.8
NEX-5 & 18-55 OSS
And a spare black 18-55
 edwardaneal's gear list:edwardaneal's gear list
Sony Alpha NEX-7 Sigma 60mm F2.8 DN Art Carl Zeiss Touit 1.8/32
RenePR OP New Member • Posts: 22
NEX-5 & 18-55 OSS
Thanks for quick response. Whats the level of dificulty to blow sensor or should I have a pro do it?
Rene
Glenn Veteran Member • Posts: 7,476
really it's not hard. if your blowing just don;t dig the end of the blower into the sensor if you're wet cleaning don't soak the inside of the camera or touch the sensor with anything but the swab... if you can scratch your nose without an ambulance ride you can do this...
El Matadurr
El Matadurr Senior Member • Posts: 4,988
The Giottos large rocket air blower is one of the most essential pieces of kit I own. Moved enough dust and crap off of my lenses and sensor to make a dust-bunny army.
http://matthewdurrphotography.com
 El Matadurr's gear list:El Matadurr's gear list
Sony Alpha NEX-7 Carl Zeiss Touit 1.8/32
aap292 Regular Member • Posts: 146
Some other tips: You can use a little light to see if you can visibly see the dust on the sensor. If you buy a blower, don't stick the tip right beside the sensor. Most dust will easily fall off even if you blow from a bit of a distance. And third, stick the body upside down with the sensor facing down so you the dust will theoretically fall down.
So the line is a dust "spot"? Were you able to locate them?
jk2l Regular Member • Posts: 183
Try to take photo against white wall, sky...etc that is plain single color. Use blower to blow the dust in those area and repeat taking photo until it is gone.
WaltKnapp Forum Pro • Posts: 13,857
The line is probably something resembling a short section of hair, and yes it's clearly visible in your photos.  I do have a sensor magnifying viewer, but this one probably is visible without that.
Best to stop the lens aperture down, the dust becomes more visible the smaller the aperture.   Way I do it is stop down to f16 or so, set the lens to infinity and point at a section of even clear sky and shoot a photo.
Note in spite of all the faith that everything can be blown off, that's just not so.  Most of the time a blower can get it off, but not always, and the longer it's on there the less likely it will blow off.  When it does not I go to a static charged sensor brush and if that can't get it when used properly (very very lightly) then I go to wet cleaning.
You should really learn to do all this. The techniques are not that hard. Choose a cleaning system and learn it. There is no photo tech following you around, but at any instant a bad dust spec can be in all your photos.  I have cleaning supplies along on all my photo forays. I use the copperhillimages supplies so can recommend them, they do have instructions on their site.
Note on average I only have to clean a sensor less than once a year.
I'm Only Responsible For What I Say, Not For What You Understand.
-Walt-
Thanks everybody I will update as soon as a clean my sensor.
This is the reasons I loce this forum. Great members 2 👍👍
Rene
akophoto Junior Member • Posts: 35
Absolutely nothing to worry about. When you take the lens off a NEX you are looking straight at the sensor. Its protected by a hard glass filter.  Just blow it off with a rocket blower but never let the tip of the blower encroach the camera opening. There is then no risk of touching the sensor filter. Wet cleaning is also easy as the shutter is always open and out of the way and you have no mirror box to navigate like a DSLR.
Dust is always going settle on the NEX sensor due to being so open to the outside environment.
El Matadurr
Yeah...early on in my cleanings I got it too close to the sensor and unknowingly drug the tip along the surface of the sensor (glass...really). Supposedly it isn't a scratch (doesn't show until f/11 anyway) and can be cleaned off, so we'll see.
