What is the bracketing on the d5200?
Started Feb 11, 2013 | Questions
artyone Regular Member • Posts: 372
Can someone please confirm the auto bracketing setup on the D5200
Is it like say the D70s where you can do 3 exposures, normal. 2stops under and 2stops over exposed?
 artyone's gear list:artyone's gear list
Panasonic Lumix DMC-GX1 Fujifilm X-Pro1 Fujifilm X-E1 Panasonic Lumix DMC-GH3 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
Nikon D5200 Nikon D70s
MarioV Veteran Member • Posts: 5,967
Re: What is the bracketing on the d5200?
It takes 2 images up to 3EV apart.  You dont really need 3 images for HDR - its like mixing black and white to get every shade of grey in between
Scroll towards the bottom.
http://imaging.nikon.com/lineup/dslr/d5200/features01.htm
 MarioV's gear list:MarioV's gear list
Nikon Coolpix P900 Canon PowerShot G3 X Panasonic Lumix DMC-ZS100 Nikon D5200 Sigma 17-50mm F2.8 EX DC OS HSM
Patco Forum Pro • Posts: 12,190
You seem to be referring to the HDR mode, but the OP is asking about exposure bracketing. Nikon says this about the exposure bracketing feature:
"Exposure bracketing - 3 shots in steps of 1/3 or 1/2 EV"
http://imaging.nikon.com/lineup/dslr/d5200/spec.htm
Patco
A photograph is more than a bunch of pixels
Eeegah
Eeegah New Member • Posts: 24
Basically you set the camera to however far you want to bracket, say 2/3EV, and it takes three shots, at -2/3EV, 0 and +2/3 EV. Only three shots, no matter how far apart you bracket. Haven't played a lot with it myself.
There's also an in-camera HDR mode that I haven't touched yet that produces only JPG files that looks very adjustable.
 Eeegah's gear list:Eeegah's gear list
Nikon D5200 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR
Mr. Click Senior Member • Posts: 1,051
If that's true, man, that is pitiful!!!  A full 1-stop range for bracketing?!?
Photograph—a 1/125 second slice of time that is able to store decades of memories.
Eeegah
You can set how far the bracketing goes. I don't have the camera on me right now and I can't find the range in the reference PDF but I know I want to say it goes up to +/-2 EV. But again, it only takes 3 shots no matter what.
It'll also bracket based on some other parameters, such as white balance or D-Lighting but that's always "fix it in post" territory for me anyway so eh.
Isit13 Forum Member • Posts: 60
Would it be possible to do this manually on my D3100 then use software on PC to combine these or must it be in camera feature for it to work correctly?
Page 84 of the D5200 manual:
"4 Select a bracketing increment.
Highlight a bracketing increment and press OK.
Choose from values between 0.3 and 2 EV (AE
bracketing) or 1 to 3 (WB bracketing), or select
ADL (ADL bracketing)."
Patco
artyone OP Regular Member • Posts: 372
Patco
Many thanks Patco
From what I read from the above, I should be able to shot with AE bracketing a set of 3 images, normal, 2ev under and 2ev over... Not great but still useable for my needs
