Why I switched to an OM-D Locked
Started 3 months ago | Discussion
This thread is locked.
idiotekniQues
Senior MemberPosts: 1,207
3 months ago
in one picture. my old 40D and 17-55EF-S lens and the OM-D with a 12-35 on it. if only I also had the sigma 10-20, canon 100mm macro & 70-300IS to put next to my other MFT lenses.
www.pixelsquish.com
lighthunter80
Forum MemberPosts: 74
Re: Why I switched to an OM-D
In reply to idiotekniQues, 3 months ago
www.pixelsquish.com
So why did you switch then or have I missed anything?
http://www.flickr.com/photos/lighthunter_de/
idiotekniQues
In reply to lighthunter80, 3 months ago
www.pixelsquish.com
size
www.pixelsquish.com
lighthunter80
www.pixelsquish.com
size
www.pixelsquish.com
Size alone is probably not all but it's your thread and I leave it up to you if you want to tell us more details
I got a Canon 5D and Oly E-PL5 and wouldn't want to miss either of them.
Bob Tullis
Forum ProPosts: 22,314
It isn't so much the body as it is the lenses.
Still, there was a time there wasn't a choice, and choices mean, er. . . well, I forget what just now, but it means something iirc.   Just saying. . .
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
Henry Richardson
Forum ProPosts: 11,792
I agree.  It isn't only size.  It is weight too.
Henry Richardson
http://www.bakubo.com
zxaar
Veteran MemberPosts: 3,041
Re: Why I am NOT switching to an OM-D
http://camerasize.com/compare/#190,289
www.pixelsquish.com
::> Knowledge is mother of efficiency.
papillon_65
Forum ProPosts: 10,962
In reply to zxaar, 3 months ago
What do you expect when you compare a toy camera with a proper one?
www.pixelsquish.com
Any problem on earth can be solved by a well aimed Pomegranate...
Tony
http://the-random-photographer.blogspot.com/
mfj197
Regular MemberPosts: 495
Comparing the E-M5 to the Pentax Q, eh?  A more appropriate comparison would be the one below, showing the Pentax against the E-PL5.
http://camerasize.com/compare/#190,382
Although perhaps a better view is the one below, the Pentax Q against the E-PM2 - which shows the gulf in sensor size between the two.
http://camerasize.com/compare/#190,387
Michael
zxaar
In reply to mfj197, 3 months ago
Q is smaller. So whats your point?
Michael
TORN
Contributing MemberPosts: 580
Yes that surely shows something. I size was my priority in DSLR land I would probably had something like a 600D plus a Tamron 17-50. Still it is bigger as the mirrorless but it would fit in right in the middle between those.
To me the biggest advantage is that with a pancake a mirrorless fits into a coat pocket. Longer lens attached it hangs around my neck just like the other. Have to admit I am in for size and not so much for minimum weight. It is quite possible to have a full frame kit which won't break your neck. I went fora while with a 5D, Voigtländer 20+40+90 whichis about 1500g and none of the lenses is essentially bigger than the mft, with no AF though but full metal instead. Now with a new 6D it would be even less weight and bulk.
To me the E-M5 just overdid a bit on the size front. It decreases usability for me. Or let's sayFuji and Sony did a better job FOR ME to keep ergonomics up but herethe E-M5 polarizes.
mferencz
Regular MemberPosts: 150
His point is that it's the sweet sport between maintaining high quality performance and size.  Why stop with the Q in your example.  If it's just about size, they make cameras the size of a postage stamp nowadays.
mujana
Senior MemberPosts: 2,704
In reply to papillon_65, 3 months ago
www.pixelsquish.com
Tony
Well maybe the toy camera could be a bit smaller than this Canon actually is?:-)
zxaar
In reply to mferencz, 3 months ago
Tell it to OP who seems to think that size and weight are everything.
Paul De Bra
Forum ProPosts: 10,312
Yep, exactly why I switched too.
Canon makes good cameras and the 17-55IS lens is amazing. But it is all large and heavy.
I will hold off of the Pana 12-35 for the moment, waiting for Olympus to come out with something (hopefully less prone to purple fringing and hopefully with a bit more range)... but the 12-35 looks "fitting" with the E-M5 in terms of size.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
Future user
Junior MemberPosts: 49
Combined difference
It's the combined difference of size + weight, both for the body and lenses. Moreover, it's an incremental difference each time you add a lens to the setup. Even if one is young and healthy, it's noticeably lighter to carry the MFT setup. It's both a physical and mental lightness.
Greynerd
Senior MemberPosts: 2,157
He did not say size and weight is everything. He just said he is switching to an omd because of the size difference. After that everyone else's imagination took over.
MatsP
Regular MemberPosts: 339
I made the same switch after taking an involuntary bath when sailing in the archipelago with my 40D on me and it was drowned.  It recovered partly after some time but remained unreliable as soon as it was a little damp. I sold all my gear in one package with camera body for free.
The reason for me to choose the OM-D instead of a new Canon body was size and IQ. Tests indicated better IQ than the 40D, which I regarded as an excellent camera in all respects than size. To my opinion no Canon APS is significantly better. My most used lenses were APS ones so a FF didn't seem an alternative.
While I'm from the very start was very happy with my OM-D E-M5 I sometimes missed the ergonomics of the sturdy 40D. But  since I got the JB grip the OM-D ergonomics have improved a lot. It's now a joy to hold in my right hand when walking the streets which it wasn't without a grip.
On my 40D I used a Sigma 17-70 as standard zoom and a Sigma 10-20 as UWA, both very good lenses. I also had an old Sigma 70-210/2,8 with 1,4x extender, big and heavy.
On my OM-D the kit lens 12-50 make the same service as the 17-70. They're comparable regarding sharpness but the 12-50 is slower, which to some degree is compensated by the better high ISO performance of the OM-D. I'm one of those who like the kit lens, but it could be faster. I also have the 9-18 and it is good but not fantastic. As telephoto lens I use an Oly 40-150/4-5,6, which is amazingly good. I also have a Sigma 19/2,8 but to my eyes it's just a little bit sharper than the kit lens, though 1,5 stop faster of course.
007peter
Veteran MemberPosts: 8,071
I used to LOVE CANON....but it has a WEIGHT problem
My old setup was a Canon 30d + Canon 17-55mm f/2.8 IS USM.  Love the IQ, but hate the bulk.
I downgraded from 30d to a Rebel XTi, then stay with Rebel series for lighter setup
I downgraded my Canon 17-55 f/2.8 IS to a Tamron 17-50mm f/2.8 VC.
The setup was somewhat lighter, but not enough.
Now I find myself with both Micro43 and Sony NEX.
There was a time when I thought all photography begin & ends with canon;
Today, I believe all photography begins & ends with Micro43 or Sony NEX.  It' a mirror-less world, or soon to be.
papillon_65
In reply to mujana, 3 months ago
www.pixelsquish.com
Tony
I think you missed his point, which is easy to do as it was....well...pointless really...
Tony
