Overexposing V Underexposing
Started Feb 10, 2013 | Discussions
tiberiousgracchus Regular Member • Posts: 250
I took a few shots the other day where I had accidentally overexposed shots. Looking at them I believed they were totally lost. Luckily recently I decided to shoot RAW and see how it works out. I was amazed at the details I could get back from the few shots I took. Very Impressed. Underexposing on the other hand gives way to banding. Even with Skies blown out to correctly expose for the foreground im still able to grab detils back in LR. Oh and loving RAW
The before and after shots below:
http://www.flickr.com/photos/tiberiousgracchus/8442560670/in/photostream
http://www.flickr.com/photos/tiberiousgracchus/8441506547/in/photostream/
...with DR @400
baobob
baobob Veteran Member • Posts: 7,222
Re: Overexposing V Underexposing
http://en.wikipedia.org/wiki/Exposing_to_the_right
http://www.luminous-landscape.com/tutorials/expose-right.shtml
These are 2 ref that explain why and how you can avoid noise in shadows
That said the Fuji X's produce very little noise anyway
So nowadays this applies for the few shots where deep shadows are important
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
bigpigbig Senior Member • Posts: 1,721
I think it is always a good idea when possible to expose to the right (very important not to clip highlights). There is much more data to the right and when adjusting tones you'll have much more flexibility.
Say, for example, your shot has 5 stops of dynamic range. Say also, the tones are evenly distributed (though this is not necessary, just easier to picture). Even if you want your midtones to be at neutral grey, you are better off shooting it 1 stop over exposed (manual exposure or exposure compensation) and adjusting in post. This will move you highlights from +2.5 to +3.5 but not clip them. You will then have much more data across the entire range with which to make adjustments (think curves adjustments or levels adjustments).
I have experimented quite a bit with this and in certain circumstances it is astounding and in others it hardly makes a difference.
 bigpigbig's gear list:bigpigbig's gear list
Fujifilm X-E1 Fujifilm X-T1 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +12 more
tiberiousgracchus OP Regular Member • Posts: 250
TVM for the info baobob.
Christof21 Senior Member • Posts: 2,060
You mean that it is not a good idea to use dr@200 or 400, it would be better in fact to have the opposite function in the camera (overexpose and correct it) !
I don't know what to think...
I am not sure what DR200 or DR400 does, but as long as you are not blowing highlights, you should try to shoot as bright as you can.
That is the expose-to-the-right theory.
it just makes the opposite, under-expose 1 or 2 stops and correct it as utomatically. It preserves the highlights.
Mayber I under-estimate the importance of the sky in a picture but I prefer to preserve shadows and have less noise.
The article is vert interesting !
I believe(d) in the exposure to right theory. however after seeing what the camera is capable of im no longer afraid of overexposing. The links in the original post is and exaggerated example but it goes to show that blown out highlights does not neccessarily mean loss of detail. With my Canon blown highlight meant you could not retrieve the info but with the X100 its still possible.
belcanto Regular Member • Posts: 448
Really interesting. I've been reading about ettr for a while but thanks to this link realised what it is. The question now is, How do you do it?? The histogram in the camera only shows the EVF's light. There is no high-clipping funktion. There isn't even a choice to choose where to meter. So again. How do you do it?
Kjell
 belcanto's gear list:belcanto's gear list
Panasonic Lumix DMC-G5 Fujifilm X-T1 Voigtlander Nokton 25mm F0.95 Olympus M.Zuiko Digital ED 12mm 1:2 +12 more
Mark Weston
Mark Weston Contributing Member • Posts: 942
Expose to the Right vs DR Auto, DR200, DR400
With my X100, I shot DR100 and raw. I am waiting for my X100S to play with the Fuji parameters again, but this topic confuses me. It really seems like the Fuji DR settings are doing the opposite of expose to the right by underexposing and lifting the shadows instead of exposing to the right and bringing the highlights back. If I am understanding this correctly, I will likely stick with DR100 and use the histogram. Anyone have any extensive experience comparing the results of DR400 vs DR100 and exposing to the right? Does Auto DR only do this in high contrast scenes where the highlights really are pushed to the right even when underexposing the entire scene? If yes, maybe it is worth giving Auto DR a try. Unfortunately, it looks like Auto DR does not work in Manual mode when I want to lock shutter speed and aperture down for control of motion and depth of field.
http://www.markwweston.com
 Mark Weston's gear list:Mark Weston's gear list
Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS Sony FE 28mm F2
djpearlman
djpearlman Regular Member • Posts: 109
Re: Expose to the Right vs DR Auto, DR200, DR400
DR 200 and 400 expose to the left to make sure (over-sure) not to clip highlights in jpegs, where they can not be recovered. Less of a worry shooting raw because there is more highlight headroom there.  But still, as with slide film in the old days, digital file shadows can usually be recovered to some extent while truly burned out highlights can not. I used to love overexposing tri-x, but don't do that with digital.
Dan Pearlman
Santa Fe, NM
http://djpearlman.tumblr.com
Trevor G Veteran Member • Posts: 6,541
That's not really correct.
The exposure is the same - it's as far to the right as your light metering, luminance-only histogram and EV compensation skills allow.
The difference is that overall it is under-exposed in-camera by 1 or 2EV to allow extra highlight detail on high contrast scenes, and then has the shadows lifted in-camera by 1 or 2EV, depending on which DR setting you use.
And it would be much easier to get better results if our Fujis had proper RGB histograms.
I am surprised there is such little support for my request for the feature:
http://forums.dpreview.com/forums/thread/3379160
I show some graphic examples of the problem and solution.
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
baobob
Sorry I get ^partly misunderstood
The ETTR method applies for RAW shooting
In my X100 and XP1 experience with around 10000 shots in JPEG DR 200 and 400 are very valuable tools for OOC JPEG with the settings for highlights and shadows set to -1 or -2
I mainly use the ETTR RAW method with my 5D2 that can be prone to produce noise in deep underexpose shadows
These methods are here, just try what is relevant in your type of photography
With the X series I don't use so often RAW even if I ALWAYS record RAW with JPEG "just in case"
baobob
If you read M Reichmann, he explains that you just push on the left the histogram in the RAW editor
I tried it with my 5D2 for very deep shadows, it works well
baobob
I have a cross experience DR 200 / 400 in JPEG X100 XP1 and ETTR with the 5D2 in RAW
IMO I think for real fine adjustment ETTR in RAW plus careful PP in the RAW editor could be more powerfull
That said according to DPR review of XP1 page DR, DR400 plus tricking shadows and highlights leads to about 13 EV especially in highlights it's rather spectacular even if you get sometimes a flat picture than could need some quick improvements
So I have not yet any experience of RAW ETTR with the Fujis
Mark Weston
Thank you for your insights
I am looking forward to getting my hands on the X100S and playing with these settings more.
Re: Expose to the Right - not possible without a proper RGB histogram
None of us do.
It's not possible to ETTR with any modern Fuji because of the lack of a proper RGB histogram.
You can't do anything regarding exposure with just a luminance histogram, as we have, because we cannot see when a chroma channel is peaking and crushing, or clipping. That will frequently happen before luminance clipping shows on our puny, in-cam histograms.
I've devoted a thread to the topic currently but here is some detail anyway:
Left histogram overlay shows the Luminance channel only, just like the in-cam histogram. Right overlay is a full RGB + L histogram from Silkypix of the same scene.
The in-cam histogram is very deceptive because it only shows Luminance (brightness) information. It can only give an approximate idea of real exposure.
In the very common case shown above, if we use the in-cam histogram it looks as if the scene is under-exposed by about 1EV, but in reality, the R channel is already crushing image detail, as shown by the Silkypix histogram on the right.
Here is the RAW - here is a good reason to shoot RAW, because you can usually claw reasonably over-exposed highlights back from RAW, but not always.
Once again the Fuji Luminance-only histogram is upper left - full RGB+ histogram is on the right, courtesy of Silkypix
properly exposed, it is easy to pick up the extra detail in this, the same image, processed from RAW.
Note for Adobe users: Adobe's Highlight recovery tool allows you to get back much of the crushing you get in over-exposed JPEGs. Silkypix does not. Silkypix does a great job ith RAW.
Important note: The in-cam RGB histogram normally consists of 4 images, one above the other, showing each channel, R G B & L, at once.
I like the Pentax iteration:
But you might prefer the Panasonic version:
Whatever one we get, we need it soon, because this is the upshot of not having one.
You might think that, if the colour is crushed, we could just convert to B&W and not lose anything except the colour.
Wrong...here is the crushed JPEG with all colour turned off:
The JPEG still loses highlight detail from chroma channel clipping or crushing, even with colour turned off
Even just the R chroma channel crushing is reflected back into the Luminance channel, and we get a loss of detail in the highlight areas. Compare with the extra highlight detail in the RAW version below:
The average output of this RAW image has been set to match the JPEG as much as possible
Of course, if you know your histograms, by looking at the L histogram we can see this crushing of the chroma channel causing 2 spikes in the L channel, here reproduced (otherwise check the top image again):
The two spikes on the right side show that chroma channel crushing has been reflected back into the L channel, even though it was nowhere near over-exposure itself.
The matching RAW, after processing, shows none of that problem:
Histogram from RAW output is in great shape, because the chroma crushing was undone in processing and did not affect the L channel.
Please Fuji, may we have a proper RGB Histogram in-camera, like everyone else?
If you agree, would you mind dropping in to this thread and saying something, please?
Cheers
Trevor G
baobob
Thx Trevor for this state of the art (?) of fuji's histogram (or lack of)
That said  with my EOS 5D2 in live view you do not get any histogram at all in preview
And it's only in review that you do get 3 channels histogram
Which means that for proper ETTR you have to do some trials
Not glorious as well....
nixda Senior Member • Posts: 3,846
Two things to say here:
1. whether one has to underexpose to do ETTR or overexpose to do ETTR is irrelevant as the end result is still ETTR.
2. 'Recovering blown highlights' is a misnomer. If highlights can be recovered, then they weren't blown. At least not in all channels. Highlights can be 'recovered' from raw data relative to the JPEG version when the conversion to JPEG was done suboptimally and clipped them. If the engine did the JPEG conversion 'correctly', i.e., if it had preserved the highlights, one would not need to recover anything. So, the ability to recover highlights in a piece of software is simply a capability to utilize the portion of the raw data that's been tossed out when converting to JPEG. If you can't recover highlights from your Canon raw files, relative to the JPEG versions, the JPEG engine did a much better job. IMO, that's a hallmark of a good engine. Being able to recover, say, 4 stops of highlights is a hallmark of a suboptimal engine.
 nixda's gear list:nixda's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
You can't. At least not easily.
Best would be to a raw histogram. That would show any sensels that are truly clipped. AFAIK, no camera displays a raw histogram. Neither does any mainstream software.
So, the only way really is to learn the behavior of your camera at various JPG settings, e.g., figure out through a series of test shots what the 'headroom' is when all in-camera processing parameters are set to their least-biased values. Then adjust exposure accordingly, and don't worry if it shows some blinkies in the camera, because you know the data are there in raw. If still worried, you can always bracket around the chosen exposure, but make sure the bracketing doesn't change ISO, which the X-E1, for example, does at certain settings.
