Bringing a logo back to life
Started Feb 9, 2013 | Discussions
DiamondEagle New Member • Posts: 14
Apologies if this is the wrong place for this kind of request.
I'm updating the website for my local running club and need help fixing up the logo (the origional has long since gone missing...)
How do I smoothen the edges and remove the "greys" around the edges? If you zoom into the image you'll see that it's quite "dirty" - not a clean pink...
DigitalPhilosopher
DigitalPhilosopher Contributing Member • Posts: 988
Re: Bringing a logo back to life
This is a way too small image to work with and, especially, producing anything. Wouldn't it be better to start from scratch?
In any case, to remove the grey outline, pick the magic wand tool (or the select color function), and choose the white area. Expand 1-2 pixels (according to need), then clear. To clean the pink area, repeat procedure above but select the entire pink area. Then use something like Filters > Blur > Average
Check my blog for reviews, tips & tutorials:
Amateur Nikon
Follow me on Twitter:
@amateurnikon
Allen Gerdes Veteran Member • Posts: 5,560
There are numerous easy ways to accomplish this, but as digitalphilosopher said, we need a much larger resolution image with which to work.  Post a high resolution image and I am sure you will receive responses with numerous ways to do it.  It is possible to tell you how to do it, but it is much more effective when we can show the results of our methods.
Regards....Allen
DiamondEagle OP New Member • Posts: 14
Thanks. I've increased the resolution in Photoshop. What are the attachment size restrictions in this forum? Can I attach a .psd file?
JJMacks
JJMacks Forum Pro • Posts: 10,285
When you wrote you increased the image resolution in Photoshop did you mean you just used Image Size? Or did you have a larger image your trying to post that is a psd file. If you have a large high resolution PSD you have two choices upload it to sharing server and post a link.  You could also save a Jpeg from the psd and post that. The PSD would be better for it may contain some vector layers.  If you just did an Image Size that does not help.
JJMack
 JJMacks's gear list:JJMacks's gear list
Canon EOS-1D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/2.8L IS USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS USM +3 more
Unfortunately it was just a image resize (and resolution increase) that I did in Photoshop. I don't have any other version of the image - just the ugly one that I posted which I got off the web server where the website is hosted.
mikes
mikes Veteran Member • Posts: 3,243
No problem.....
Just use CorelDraw, simple and quick with auto trace.
https://dl.dropbox.com/u/25890514/logo.jpg
Only when you can criticize yourself, should you criticize others. Mikes.
Re: No problem.....
Good job, Mike.  I knew that someone with a vector based program would come to their rescue.
Regards....Allen
mikes
Thanks Allen....nt
benross Contributing Member • Posts: 924
Re: No problem.....
Or Pixelmator and PSL10 for very time consuming approach, using Pen tool with assigning a stoke thickness. The text was re-created (Arial Bold) on PSL 10. I actually see some outline colour in the logo! Anyhow, useless but fun!
Re: No problem.....
WOW! Perfect! Thanks. I'm certainly going to have a look at CorelDraw...
Again, THANKS!
Re: No problem.....
Thanks benross! It's certainly not useless to me...
Yes, the origional image does have a thin grey "border" around it, but it might just be "old age". I prefer the image without the grey border.
I really appreciate your efforts. Thanks.
mikes
Re: No problem.....
Also, have a look at Vector Magic here and play with it, although it is way overpriced. Once it is converted to a vector, the sky's the limit. Here is my blown glass example, just for a play.
Again, THANKS!
Re: No problem.....
Wow! And thanks. I'll certainly have a look a playing with vectors.
Michael Edward Rudge Veteran Member • Posts: 6,995
Re:my try
 Michael Edward Rudge's gear list:Michael Edward Rudge's gear list
Canon EF 50mm f/1.8 STM Canon Pixma MG5350 Samsung Galaxy S4
Re: No problem.....
Did you create that "3D chrome" effect in Vector Magic?
Re:my try
Thanks Michael. Can you describe how you did it?
Re:my try
Yes,, I used PS CS2,
I used selection tool on the red, and painted selection RED, the used the stroke 1 pix black, then just did a selected border inverted, and soft 20% black shadow
Ronny Harris Veteran Member • Posts: 7,062
A late play...
Vector Magic and PS.
Ronny
