Best starting lens set
Started Feb 9, 2013 | Questions
gavin Veteran Member • Posts: 4,361
Hi, I am helping a friend buy a small DSLR and is pointing her to the OM-D. I know nothing about Olympus lens or M4/3 lens. So what are the best lens if
1) 2 lens set: something like 12-50ish and 70-300mm? I would like to find a fast lens say 2.8? I saw a new tele zoom coming out?
2) 1 super zoom lens. I saw 14-150mm.
3) Should I get olympus or other M4/3?
Gavin
What camera do I have? I rather you look at my photos www.flickr.com/photos/gavinz
 gavin's gear list:gavin's gear list
Pentax WG-3 Sony Cyber-shot DSC-RX100 III Canon EOS 5D Mark II Canon EOS 40D Canon EF 50mm f/1.4 USM +6 more
Barry Stewart
Barry Stewart Veteran Member • Posts: 8,578
Other forum
Gavin, you'll get more responses in the M4/3 forum, which is one click under the Olympus SLR forum.
Thanks for the steering your friend toward the O-MD camera. If money or size/weight are a concern, I can certainly recommend the E-PL5, which is smaller and lighter than the O-MD but not as robust (and not weather-proofed.) The 14-42 kit lens is okay... but I sure hope Oly comes out with a better general-purpose lens, such as the wonderful 14-54 on the regular 4/3 mount.
Barry
 Barry Stewart's gear list:Barry Stewart's gear list
Olympus C-5060 Wide Zoom Olympus E-1 Olympus PEN E-PL5 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +9 more
Craig from Nevada
Craig from Nevada Senior Member • Posts: 1,588
Re: Best starting lens set
Gavin
You can pick up a new e-pl2 for between $300 and $350 on Amazon.  You can get a 40-150mm lens pretty cheap on ebay.  You can save plenty by going this path.  Upgrade later if you want to.
 Craig from Nevada's gear list:Craig from Nevada's gear list
Olympus Tough TG-4 Olympus E-30 Olympus E-620 Olympus E-5 Olympus PEN E-PL6 +10 more
gavin OP Veteran Member • Posts: 4,361
Thanks. She bought the OM-D as she is going to Antarctica this week. Need to weatherproofing
Barry Stewart
So she got the 12-50?
If so, it's weather-proofed.
One concern will be water spray/rain on the front element. Nice for some shots — but not ALL.
If it's salt spray, she'll need a way of dealing with that.
Greg (Daddyo around here) is high on the 2x in-camera teleconverter feature, which doubles the reach of any lens you use. He says it's better than cropping later. If your sister only has the 12-50 and wants more range on some shots, she should keep that in mind. (And make sure to turn it off when not needed.)
I'm not talking about the 2x conversion-to-35mm-speak factor of any Olympus lens. That the 12-50 lens is 'equivalent' to a 24-100 lens is a given. This digital teleconverter turns it into a 48-200.
Barry
