How do I set up my 50D for back button focusing?
Started Feb 8, 2013 | Discussions
jrk Senior Member • Posts: 1,847
Could someone provide the steps required to configure my 50D for back button focusing?  I've not been able to set it up correctly.
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Canon EOS 70D Fujifilm X-E2 Fujifilm X-T1 +12 more
Canon EOS 50D
MrScary Veteran Member • Posts: 6,285
Re: How do I set up my 50D for back button focusing?
Funny thing these cameras. I have a 7D and use Back Button because camera is FAST. Good for Birding
I also have a 50D and prefer the Front Button on it. Good for People/Landscapes/Macro.
Google--how to set up 50d for back button focusing...
Good Luck
 MrScary's gear list:MrScary's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 400mm f/5.6L USM Canon EF 70-200mm f/4.0L USM Epson Stylus Photo R3000
asad137 Contributing Member • Posts: 693
p. 181 of the 50D manual
In the Custom Functions menu, C.Fn IV, option 1 controls the behavior of the shutter and AF-ON buttons.
Options 2 and 3 are used to enable BBF; option 1 makes the AF-ON button an AF Lock button.
RedFox88 Forum Pro • Posts: 24,721
It has the AF-On button, so there shouldn't be anything to configure.
Well, presumably if he wants BBF, then he wants to remove focus control from the shutter button. Otherwise what's the point?
TTMartin
TTMartin Veteran Member • Posts: 7,304
Since the 50D has an AF ON button, all that is required is to remove focusing from the shutter button.
Menu
Orange Camera Tab
C.F.IV:Operation/Others
1 Shutter button/AF-ON button
3:Metering start/Meter+AF start.
This way when you press the AF-ON button the camera will focus the same as a half press on the shutter button.
A half press on the shutter button only starts metering.
If you want to use the * instead of AF-ON for your back button focus
Menu
Orange Camera Tab
2 AF-ON/AE lock button switch
1:Enable
* is your AF-ON button and AF-ON button is your exposure lock
0:Disable
* is your exposure lock and AF-ON is your focus start
Personally I shoot a lot in AI Servo and don't want to have to continually hold the back button, so I leave AF start on my shutter button, but, configure my AF-ON button as AF-OFF. This way I start focus with the shutter button, but, can stop it at anytime with a back button press. I find this is works better for me.
To configure your camera like that
Menu
Orange Camera Tab
1: Metering + AF start/AF stop
Menu
Orange Camera Tab
0:Disable
* is your exposure lock and AF-ON is your focus stop/suspend
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
jrk OP Senior Member • Posts: 1,847
That's exactly what I'm after, I want to focus with the back button only and have the shutter button on for taking the actual shot.  I will be using this technique for sports photography; continual focus with the back button and shot with the shutter release.
TTMartin wrote:
Menu
Orange Camera Tab
Menu
Orange Camera Tab
1:Enable
0:Disable
Menu
Orange Camera Tab
Menu
Orange Camera Tab
0:Disable
Thanks!!!
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,100
Here's a link to an article on the Canon Learning Center website that might be of some use:
Back Button AF Explained
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon PowerShot S2 IS Canon PowerShot S5 IS Canon PowerShot G10 Minolta DiMAGE Z1 Konica Minolta DiMAGE Z2 +22 more
