Recommendations welcome- protect my new camera!
Started Feb 8, 2013 | Questions
karma2m New Member • Posts: 1
Just ordered a Canon SX40 & want to care for it properly.
Should I buy a filter to protect the lens?  If so, recommendations?
I'm not very experienced, so please be gentle!
Karen in Texas, anxiously awaiting her new arrival!
Dimitrios Zavos
Dimitrios Zavos New Member • Posts: 1
Re: Recommendations welcome- protect my new camera!
Hello karma2m,
A special adapter is required to mount a filter on the SX40. There are two sizes available, one to mount a 58mm filter and one to mount a 67mm filter. Canon offers a 67mm adapter so I'd stick to that since the 58mm that other providers offer might cause some vignetting. If all you want is to protect your lens then a UV filter is sufficient. Please use a good quality filter. No point covering a fine lens with an inferior piece of glass. Also please consider using a lens hood to protect against contact and hits when carrying the camera around on its strap.
Hope this helps.
 Dimitrios Zavos's gear list:Dimitrios Zavos's gear list
Canon EOS 5D Mark III Canon EF 16-35mm f/2.8L II USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
confyushis Senior Member • Posts: 1,070
hood, yes ... filter, not so much ...
a UV filter is typically not necessary and may make your pictures worse ... any glass you put in front of your lens will reduce picture quality, though you may or may not notice a difference ... you would have to buy the filter adapter for about $20 and then buy a filter which may cost much more depending on quality ...
for protection you can buy a lens hood (LH-DC60) for about $20 (try bhphoto.com or adorama.com) ... it will also reduce glare and increase contrast, which no filter could ever do ...
 confyushis's gear list:confyushis's gear list
Canon EOS 550D Canon EOS Rebel SL1 Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 30mm F1.4 EX DC HSM Sigma 8-16mm F4.5-5.6 DC HSM +3 more
drj3 Veteran Member • Posts: 3,845
Any filter can degrade the image.   This is especially true if you do not use a lens hood.  If a filter is used it should be a very high quality multicoated clear filte and therefore expensive. For the superzoom you also have the added expense of the Canon - Filter Adapter FA-DC67A necessary to prevent vignetting.   If anyone makes a lens hood (they may not for a super zoom) that would be a better choice for lens protection.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +6 more
James Cafferty Veteran Member • Posts: 5,364
Re: hood, yes ... filter, not so much ...
I agree with confyushis: skip the filter (unless you have young children or touchy-feely friends or relatives)
Buy a lens hood for outdoor pictures, store it reversed on the lens fitting
Camera Case $12.74 + shipping
http://www.amazon.com/Case-Logic-DCB-304-Fixed-Camera/dp/B0039BPG1A/ref=sr_1_1?ie=UTF8&qid=1360298173&sr=8-1&keywords=Case+Logic+DCB-304
Canon Battery $40 - free shipping
http://www.bhphotovideo.com/c/search?Ntt=Canon+NB-10L+Battery&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
Canon Lens Hood $19 + shipping
http://www.bhphotovideo.com/c/search?Ntt=Canon+LH-DC60&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
Good luck!
All the best,
Jim
Is it the camera, the lens, or your lack of skill that is causing you to...
Leswick Veteran Member • Posts: 3,102
If it will help you sleep better....have this eq added to your home insurance.
Leswick
mgd43 Veteran Member • Posts: 4,235
This is a very controversial topic that comes up often and always goes on and on with good arguments on both sides. I'm a believer in Murphy's Law that anything that can go wrong will go wrong so I use protective filters. I don't see any loss of sharpness.
 mgd43's gear list:mgd43's gear list
Nikon Coolpix P7800 Nikon D5500 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Sigma 10-20mm F4-5.6 EX DC HSM Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR +3 more
Solar Ben Junior Member • Posts: 28
Hi!
If you want to attach a filter to the lens of the sx40 you'll first need to buy the fa-dc67a filter adapter. Then you can install 67mm filters, usually you can find these for about $30.
You could buy a lens hood part number LH-DC60 for about $30. This helps to protect your lens as well as helps block light from causing flares in your images.
 Solar Ben's gear list:Solar Ben's gear list
Canon PowerShot S95 Canon EOS 5D Mark II
