D600 . AF in tungsten light
Started Feb 7, 2013 | Discussions
papparazzi
Senior MemberPosts: 1,950Gear list
Feb 7, 2013
Hi there, need some input from D600 owners...
Have been using a D600 3 days now an noticed something strange, in *warm/tungsten* light it back
focus! when I micro adjust to -17 it resolves the issue.... is this normal?
This happens with every lens :\
 papparazzi's gear list:papparazzi's gear list
Nikon D600
Nikon D600
Nikonfan99
Senior MemberPosts: 1,411Gear list
Re: D600 . AF in tungsten light
In reply to papparazzi, Feb 7, 2013
I would say you just asked a forbidden question. Let the arguments begin. I own a d600/d7000 used focal software to fine tune my large lens collection. I would say that this is a situation that under lower tungsten light, both my cameras do this a bit. My d90 works under low tungsten more accurately. I had two d90’s and neither did it. Sold one after I got the d600. You are going to get some people telling you that you are wrong and I am wrong. They should be here soon
BTW, all my nikon glass back focused during the test. The nikon 50 1.8g on the d600 did the least backfocus. My tamrons both back focused on both bodies the most.
 Nikonfan99's gear list:Nikonfan99's gear list
Canon EOS 6D Canon EF 100mm f/2.8L Macro IS USM Canon EF 40mm f/2.8 STM
AllOtherNamesTaken
Veteran MemberPosts: 3,563Gear list
Both my D600's and my D300 focus bang-on under Tungsten light (or any other kind of light).  Doesn't matter what lens.
papparazzi
In reply to Nikonfan99, Feb 7, 2013
Humm..yes I have heard people saying horrible stuff from the D7000, but most seem happy with the D600 so my question...
So you say...You have it, in normal light your's ok?
What is the adjustment you need to dial in to make spot on?
Nikon D600
papparazzi
In reply to AllOtherNamesTaken, Feb 7, 2013
That's good news...so what do you think is  happening with this D600? Failure? In normal light it works ok...
Nikon D600
Nikonfan99
Yes I am not saying it is a deal breaker but I would say after using focal software, the cameras both still back focused in my living room (tungsten low light) by about 3-6 inches behind most objects at times. Would not do it if I shoot with daylight window or outside. I think the AF system is the same in both cameras. YMMV
lock
Veteran MemberPosts: 6,162
Minor differences in the angle of the secondary mirror.
Although likely there is a front or backfocus in any light, tungsten light may Af errors the most. It has been documented before that adjusmtentof this mirror did help (though I'm not sure if other causes may exist that are repairable).
lock
surrephoto
Regular MemberPosts: 258
I think in time this will be the next "D800/D4 Left AF Saga"-type of defective camera saga. Wonder whether this is even a defect to begin with. No concrete evidence that this is beyond an inherent design limitation. Some have suggested a sub-mirror adjustment and I am in the midst of investigating that (nikon tech in my country are denying this possibility, AS ALWAYS!)
http://forums.dpreview.com/forums/post/50536972
surrephoto
In reply to surrephoto, Feb 7, 2013
Food for thought about the seriousness of this problem;
1. Nikon showrooms are a great place to showcase this issue, just try it with a wide-angle lens on one of those big bright yellow nikon murals lighted by tungsten lamps.
2. It's not just the color temperature, any object that is significantly saturated red/orange will result in back-focus. I stay in Chinatown in Singapore, btw, and that 1 street photography session 2 days back was a good test.
3. If you're a wedding photographer who shoot in dim tungsten or 2800k lamps, your life is going to be difficult with the D600.
papparazzi
some samples...
in tungsten..
Last image corrected with -17 with micro adjustment.
http://farm9.staticflickr.com/8225/8454735966_175fa1fe10_o.jpg
Nikon D600
surrephoto
Re: some samples...
What is the micro-adjustment value you prefer to use in broad-daylight?
papparazzi
That is very upsetting indeed...I wonder how many have this...
Nikon D600
papparazzi
Re: some samples...
With the 35 1.8G -2
and with the 50 1.8 D (zero).
Nikon D600
papparazzi
Sample in normal daylight
Nikon D600
surrephoto
Re: some samples...
papparazzi wrote:
With the 35 1.8G -2
Sounds quite serious to have a value difference of 15. I'm pretty sure that the warmness of the light also affect the severity of the problem so all is not abnormal. Anything below 2800k should result it horrendous back-focus, the problem will also accentuate as the focus distance increases.
As of now the best we can do is to take sample images and seek address at the service centre. In singapore the technician has agreed to do an in-depth test with my D600 (a rather new serial, 3 weeks old) after next week. He has also agreed to test it under 3200k tungsten light.
Steve Bingham
Forum ProPosts: 23,122Gear list
Opinions or valuable information?
In tungsten the following lens seem to focus perfectly on my D600:
Nikon 24mm f1.4
Sigma 35mm f1.4
Nikon 70-200 f4
Imagine that! When I had the D7000 I read about people screaming about focus problems. I had none, as well as my many pro friends. Where the problems there for some? Sure. But I bet they were a small minority.
In general, forums such as this one are a terrible place to gather real information.
Let me offer some solid advice. ALWAYS check the source and qualifications of the person giving the information. If that is not possible than ignore the advice as worthless.
Everybody has an opinion!!!!!
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 17-50mm F2.8 EX DC OS HSM Tokina AT-X 12-28mm f/4 Pro DX +16 more
AllOtherNamesTaken
Re: Opinions or valuable information?
In reply to Steve Bingham, Feb 7, 2013
Nikon 24mm f1.4
Sigma 35mm f1.4
Nikon 70-200 f4
I've been telling people this for as long as I can remember. Unfortunately it usually falls on deaf ears. The conclusions some people come to on here (Not referring to the OP, just in general) are laughable.
I am also someone with many Nikon bodies, all functioning flawlessly with all lenses (which also function flawlessly). Never had a single warranty issue in 10 years. None of my friends, family members, colleagues, or shooting partners (all Nikon) have had a single issue either. Some people just find it impossible to believe that there is a lot of perfectly functioning gear out there. To be honest though, I think half the time it's the user, not the camera, that needs fixing.
Simple human nature makes forums a TERRIBLE source of reliable statistical information.  People post when they have a problem, never to say they are happy - that's how it works for just about everything.  Also, as you say, nobody knows the credentials of the poster in most cases.  Many of the D7000 "issues" turned out to be user error, but if you didn't read the threads and just scanned the thread titles, you'd think the D7000 was a lemon.
AllOtherNamesTaken
Honestly I have no idea why your camera would operate any differently, but mine will focus in any kind of lighting, including the worst light imaginable (Nocturnal exhibits at Zoo's, for example).  My keeper rate is higher than it's ever been.
amobi
Veteran MemberPosts: 3,109
Nikon 24mm f1.4
Sigma 35mm f1.4
Nikon 70-200 f4
Man you are one lucky individual. Everything you touch, turn into gold.  Everything you own function flawlessly. Nikon should shut down their customer service department. I'm sure your D600 has no oil spots on the sensor.
Fayard
Regular MemberPosts: 127
Re: some samples...
In reply to papparazzi, Feb 8, 2013
I had the "left AF sensor" problem with my D800 and sent my camera for adjustement. It came back to me with autorocus problems which where not present before. The biggest of them is a strong front focus with some warm lights that I have in my house. These problems where not there before.
Therefore, I am getting convinced that focus issues depending on the color temperature might happen because of an adjustment problem in the camera. The only way to really know would be to check another D600 with the same light conditions and the same lens.
Unfortunately, you will have to figure out yourself as everybody has a body with different adjustements.
