How good is the original 5D Mark I compared to the 2013 Canon's?
Started Feb 6, 2013 | Discussions
gromero
gromero Forum Member • Posts: 89
I'm seeing the original 5D Mark 1 body's for sale for very cheap now.
My question is, considering this was a ground breaking full frame camera launched in 2005, have the amateur enthusiast range now caught up with the original 5D (I use the 600D, which is almost identical in IQ to the current 650D) in terms of IQ?
Or does the full frame sensor on the original 5D still offer superior IQ compared to any of the current 'less than $1000' Canon's?
Clearly the new range of Canon's have improved video, but since day one of owning my 600D I have not shot 1 second of video, I use my camera purely for photography. So this aspect of the Canon's doesn't interest me, I'm purely interested in IQ.
Canon EOS 5D Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5) Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
scrane
scrane Senior Member • Posts: 1,342
Re: How good is the original 5D Mark I compared to the 2013 Canon's?
The newer Canons are far ahead of the old 5Dc as far as features, resolution, and high ISO noise. But, in my opinion the low ISO IQ of the 5Dc is superior in its tonality and balanced output. It is still a fine option.
You can compare photos from all Canon cameras on the Photography on the Net forum. The 5Dc does very well and maintains a following of talented photographers.
 scrane's gear list:scrane's gear list
Nikon D810 Sigma DP2 Merrill Canon EOS 5D Mark II Sony Alpha NEX-7
KENTGA
KENTGA Veteran Member • Posts: 4,261
Probably the main problem you'll have with 5D1 is trying to look at the LCD ineven moderately bright daylight.
I sometimes look at my 5D1 photos and they look remarkably sharp.
Kent
 KENTGA's gear list:KENTGA's gear list
Panasonic Lumix DMC-FZ150 Canon EOS 7D Canon EOS 40D Canon EOS 5D Canon EOS 6D +14 more
RedFox88
RedFox88 Forum Pro • Posts: 24,518
no 5D mark I nor 5Dc
Let's talk about the right camera. There is no model called the 5D mark I nor is there a 5Dc, it's plainly the 5D!
Rexgig0
Rexgig0 Senior Member • Posts: 3,097
The 5D1 does, indeed, still have a following. Its AWB is not as sophisticated as, for example, my 7D cameras. Its AF is not very impressive, away from the center AF point, compared to a 7D. The 5D1 OOC files, however, are very pleasing to my eyes. I use my 7D cameras at work, but like my 5D cameras for much of my personal shooting.
I bought my second 5D1 in December 2012, after considering the very attractive prices of still-new 5D2 cameras, but then deciding my earlier decision to skip the Mark II was still the better plan. My DSLR "road map" does indeed have a 5D3 on it, but I am not in a particular hurry to get there. When my finances improve in early June, I may prioritize acquiring another L lens, or two, rather than a new full-frame camera body.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 40mm f/2.8 STM Canon EF 100mm f/2.8L Macro IS USM Canon EF 135mm f/2.0L USM Canon EF 400mm f/5.6L USM +30 more
Shaun_Nyc
Shaun_Nyc Senior Member • Posts: 2,279
 Shaun_Nyc's gear list:Shaun_Nyc's gear list
Nikon D3 Nikon D800 Nikon D50 Canon EOS 5D Canon EF 100mm f/2.8L Macro IS USM +10 more
Rexgig0
Re: no 5D mark I nor 5Dc
With all due respect, we rarely label something as I, Mark I, or senior, until a II, Mark II, or junior arrives upon the scene. Once the Mark II arrives, it is much simpler to use 1, I, 5D1, or Mark I, than type a longer description. We know what it means, and it avoids confusion, as some folks use "5D" loosely, when referring to the current 5D model.
Moreover, unlike some automobile and firearms companies think, "Classic" is a title that is earned, not self-proclaimed. I believe the original 5D has earned the title of Classic. The early full-frame Canon DSLRs were a BIG thing in their day, causing much anguish among the Nikon folks, and at its introduction, there was nothing else like the 5D, the first light-weight full-frame DSLR. I do not, however, use "5DC."
To be clear, I did not mean this to seem argumentative.
RedFox88
I read that "agrument" but never see posts by users "confusing" models.  But I do see people presuming that when someone writes 5D they mean the current model.  So if you'd go with what people write, everything would be just fine.
jedinstvo
jedinstvo Senior Member • Posts: 1,914
A 5D is worth a lot more than five hundred bucks
Which is what they're going for now. A great camera.
gipper51
gipper51 Veteran Member • Posts: 4,331
The short answer is "yes", the 5D still competes very well with most modern cameras.  While it's "only" 12.8mp and tops out at ISO 3200, they are some of the sharpest pixels you will find and 3200 is very usable.
My 5D gets alot of use even though I also have a 5D2 in the bag.  The old model produces images that just have a nice look to them.  The 5D2 is my go-to body for my architectural jobs (where I wish I could afford medium format IQ), for most other things I use the 5D.  I rarely find the resolution to be limiting, and I've made 20x30 inch prints from this camera that look spectacular.  Unless I know I will be needing higher ISO than 3200 I have no reserves about taking the 5D instead of the 2 for most applications.
I would not buy the 5D based on if it's better or worse than a newer APS-C model camera.  The latest crop sensors offer better ISO and more resolution (if your lenses are good enough).  Buy it if you want the characteristics a FF sensor offers.  Big sensors will always render an image differently than a smaller sensor.  Buy a 5D if you want the larger viewfinder, shallower DOF, to use lenses at their true focal lengths.  If you want that, the 5D is a great buy these days.
That said, I would not trade my 5D for any crop sensor camera Canon currently makes.
 gipper51's gear list:gipper51's gear list
Canon EOS 6D Canon EOS 7D Mark II Sony Alpha 7R Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Sigma 12-24mm F4.5-5.6 II DG HSM +7 more
The Davinator
The Davinator Forum Pro • Posts: 16,391
In most ways, modern Canon bodies beat it.  The latest bodies like the 5d2 and 5d3 provide higher resolution with better noise and DR.  Even the budget T4i and the 7d beat it in virtually every way.  It's not a bad camera considering what they go for now....but the latest bodies are better in build, screen, speed, accuracy, resolution, noise, DR, etc, etc.
 The Davinator's gear list:The Davinator's gear list
Canon PowerShot G3 Canon PowerShot SX150 IS Canon EOS 10D Canon EOS D30 Nikon D2X +18 more
The Davinator
If that is the case, why don't we see constant reference to the Canon 1D Classic and the Canon 1Ds Classic, and the Nikon D2x Classic and the Nikon D3 Classic......is it because pros know the difference between 5D and 5D2 when the read a sentence?
qianp2k
qianp2k Forum Pro • Posts: 10,350
5D classic is fantastic!
5Dc still beats any APS-C in natural sharpness, clarity and fine details and better in high ISOs also till ISO 3200. DXOMark confirms that. It has trademark creamy color rendition and stellar skin tone.
Any EF lenses still resolve more fine details (based on SNR - signal to noise ratio) on 5Dc and sharper than the same lenses or comparable EF-S lenses on Canon APS-C.
Canon 5D+24-105L vs 7D+17-55/2.8 vs Nikon D7000+17-55/2.8
5D still beats latest Canon 18mp APS-C in critical SNR and ColorTonality
Canon 5D vs 7D
It beats all much more expensive ISO 200 based Nikon 12mp FF cameras in IQ - D700, D3 and D3s under ISO 1600.
Indeed 5Dc is very good and very sharp. If I don't view/print large, 5Dc withstands my 5D2 and 5D3 to at least 2000-pixel wide. They look different. Sometime I prefer 5Dc colors and skin tone while 5D2 is a bit more contrast and darker. 5D3 looks sits between.
Grand Canyon NP
Local park
Beijing Olympic Game opening ceremony
Las Vegas
(text edited out by moderator)
 qianp2k's gear list:qianp2k's gear list
Sony RX100 Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EOS-1D Mark III Sony Alpha 7R +20 more
MAC
MAC Forum Pro • Posts: 13,210
Re: 5D classic is fantastic!
Canon 5D vs 7D
Grand Canyon NP
Local park
Las Vegas
Ignore some noises here as one or two never experienced any 5D series cameras, nor have any photos can show but never hesitate in jumping threads when they smell magic word 5D, lol.
yep - I keep my magic 5dc for use in portraits with my 100L, 50, 35, and 70-200 f2.8 L. I don't even have a normal zoom for it
poor man's 5d for sure. I can just say like Seinfeld, I got 5d and people can spend the next hour trying to figure out which one, which until very high iso -- usually above 1600 they can't figure out
I like my T4i with touch screen, live view, and auto iso too!
My 60d has the best canon APC-s score at DXO - lol. Actually - love the 60d with magic lantern! lol. Once they complete magic lantern for my 5dc - they are working on beta btw - I'll put it on my 5dc and have a good native iso 6400 lol!
btw - the magic machine is about 1 stop better at hi iso than my best IQ canon APC-s in class 60d lol
the 5dc images are beautiful and pop-up lol
mine will die before I sell it lol
love the weak AA lol
I hope you didn't turn your magic machine into an IR machine lol
 MAC's gear list:MAC's gear list
Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EF 35mm f/2 IS USM Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-200mm f/2.8L USM +6 more
qianp2k
Yes I also keep my 5Dc as its colors and creamy tonality are special. Cannot wait to fire some shots with 5Dc with my latest lenses - 24-70L/2.8 II and 70-200L/2.8 IS II, 40/2.8 Pancake. They will be even better than the ones with 24-105L
Sure 5Dc lacking of bells and whistles on today's standard - LCD, dust, ISO 3200 only, lacking of LV.  One thing I don't have a complain is its IQ.
DVT80111
DVT80111 Senior Member • Posts: 2,105
Is it sharper because...
fewer pixels? 12.8M versus +20M?
 DVT80111's gear list:DVT80111's gear list
Sony RX100 Fujifilm X-E1 Canon EOS 70D Canon EOS 6D Sony Alpha 7R II
qianp2k
Re: Is it sharper because...
Very weak AA filter and large pixel.  If I downsampling my 5D2/5D3 photos to the same size said 2000-pixel wide, they are very close but not really sharper.  5D2/3 noticeably resolves more at 3000-pixel wide.  I found 5Dc is especially shine in cloudy day or under soft light.
MAC
weak AA allows one to use zero sharpness in LR at high iso with razor sharp lens
5d 100L, iso 3200, f5
example where sharpness trumps noise
MAC
agree, with great lenses, 5d IQ keeps giving
5d 100L
jayrandomer
jayrandomer Contributing Member • Posts: 731
What's the problem with using 5Dc?  Sure, it was never called that by Canon, but enough people use the term that it has become recognizable.  Do you get equally upset when someone says the EF 70-200 f/2.8 IS I?  Or when someone mentions the 100mm macro (non L)?  The additional information, while not conforming to the official nomenclature, helps clarify the exact intent of the statement.
