5N update
Started Feb 5, 2013 | Discussions
Jack West Senior Member • Posts: 1,144
5N update
i updated my 5n on my 10.8 mac with no problems to ver 1.02 i'm reading on here that there are lens upgrades as well? do i need these? i have the pancake-kit-50 & 18-200[older] thanks
dannytang Regular Member • Posts: 289
Re: 5N update
I believe the lens upgrades only apply if you have one of the new bodies that support hybrid AF.
 dannytang's gear list:dannytang's gear list
Nikon D600 Sony Alpha 7R II Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Sony FE 55mm F1.8 +5 more
neok Forum Member • Posts: 50
Re: 5N update
That's great. Did you also try to read RAW files? I'm afraid the change in RAW format might cause them not to be read anymore by osx/aperture/iphotot.
Koen
 neok's gear list:neok's gear list
Canon PowerShot G9 Sony Alpha NEX-5N Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Apple Aperture +4 more
Howard ret Junior Member • Posts: 25
Re: 5N update
Can you see any improvement in autofocus with kit lens? Also curious if camera raw out of cs 5.1 can read files?
Kalabalik Junior Member • Posts: 35
Re: 5N update
Just updated my 5N to 1.02. Where can I find the new bracketing settings?
 Kalabalik's gear list:Kalabalik's gear list
Sony Alpha NEX-5N Sony E 35mm F1.8 OSS
RenePR New Member • Posts: 22
Re: 5N update
Press the option selection where the old bracketing is. Left soft key
Rene
Philip Corlis Contributing Member • Posts: 825
Re: 5N update
Did you have to open the upgrade in 32 bit mode or is it 64 bit compatible on your Mac?
Phil
www.PhilCorlis.com
www.FindingBritain.com
cactusgeorge
cactusgeorge Regular Member • Posts: 124
Re: 5N update
Camera>Drive Mode>Bracket>Option button>Select Bracket
Only works in PASM modes
Re: 5N update
Never mind - answered my own question - the update is good to go in OS 10.8.2 64 bit mode.
Phil
www.PhilCorlis.com
Re: 5N update
Worked in 64 bit? Instructions say 32. See any improvements with 5n autofocus? Still able to read raw files in camera raw?
Re: 5N update
Fired up my Mac (10.8.2) and the update opened and went off without a hitch. RAW files opened in Lightroom no problem. Too early to tell about autofocus vs placebo effect from a shiny new upgrade. Thrilled to see brackets up to +/- 3 stops!
Phil
www.PhilCorlis.com
ricklangdon Junior Member • Posts: 35
Re: 5N update
Why no on/off for video button????
Beaverhelmet Senior Member • Posts: 1,549
Re: 5N update
If it is any consolation, I think you can get used to it. I now have a 5N and a 5 before that. During the first months with the 5, I inadvertedly pushed the rec button a lot of times, and it was frustrating. Now I never do it (the 5N has the rec button exactly at the same place as the 5). Seems you learn how to grab and handle the camera after some use. And I am quite happy to have immediate access to the movie function in case that unbelievable once in a lifetime moment occurs. A firmware for the A77 adressed this button and I tried it for a while, but realized it was too much of a hassle to capture a clip this way, so I turned the button on again. The optimal solution, for me, would be a two button solution, like push the shutter button while you hold the rec button and recording begins immediately. But we all use our cameras differently and I am sure others wouldn't like this solution either.
And I recently updated to FW 1.02 in my 5N. Haven't tried the bracketing yet, but I noticed an increase in UI speed. At first when I swapped from 5 to 5N I noticed that my new camera actually was slower in response in the menus and buttons. Now it is just as snappy as my old 5. Thanks for that Sony!
Fredy Ross Veteran Member • Posts: 6,697
We should all thank Sony for an update on an earlier model, the 5n
I wish all the camera companies would do that. Seems one upgrade and then a new camera comes out. Kudos to Sony for being different.
fredyr
Re: 5N update
Phil
www.PhilCorlis.com
You say RAW files open in Lightroom without a hitch. As far as I know Lightroom does have its own RAW processor and does not use the RAW processor of OSX. Do the new RAW files also open in Preview/Aperture/iPhoto? These programs use the RAW processor of OSX. As an Aperture user I am very hesitant to install the new update.
Koen
Letsgokoulos
Letsgokoulos Senior Member • Posts: 1,775
Re: We should all thank Sony for an update on an earlier model, the 5n
fredyr
+1
And most companies proposing an upgrade actually propose a correcting update for bugs or major fonctional problems.
There have been quite a few updates in the NEX series since their introduction on the market, and most implemented additional features or improvements over a few corrections.
Marc
Re: 5N update
Phil
www.PhilCorlis.com
Koen
I don't use iPhoto or Aperture, but Quick Look and Preview had no trouble with the files.
Kuturgan
Kuturgan Regular Member • Posts: 495
Re: 5N update
FW upgrade installed with success! LR4.2 supports new RAW files.
I'm really excited about new RAW Bracketing option and BTW today is my birthday
So thank you SONY for this long-awaited GIFT!
Don't take a picture, create!
 Kuturgan's gear list:Kuturgan's gear list
Sony Alpha NEX-7 Olympus PEN E-PM1 Sony E 20mm F2.8 Panasonic Lumix G 20mm F1.7 ASPH Sony E 50mm F1.8 OSS
