Today i am not satisfied with my panasonic 20 1.7 on my E-pl5 ..
Started Feb 3, 2013 | Discussions
gwelta
Regular MemberPosts: 186Gear list
Feb 3, 2013
Hello,
Today was my first time with this combo outside! (Yes the weather was very bad the last time in Austria ... )
So i took some shots with my new 20m 1.7 But i am not sure that the lens sharp is and/or that the color are real... (artificial?)
Do you have an idea if the problem could be the lens? I am preatty happy with the kit lens 14-42...
I don't know if should hold this lens.
A bientot Gwelta
 gwelta's gear list:gwelta's gear list
Canon EOS 6D Olympus E-PL7
Olympus PEN E-PL5
jkrumm
Veteran MemberPosts: 8,779
Re: Today i am not satisfied with my panasonic 20 1.7 on my E-pl5 ..
In reply to gwelta, Feb 3, 2013
My 20mm is a very sharp lens and those photos you posted do look quite soft at %100. I would take some more test shots at different focal distances and apertures and shutter speeds. If some are super sharp and some are soft, then you can narrow down the problem to see where it repeats. If all are really soft, you might have a bad lens.
John Krumm
Juneau, AK
gwelta
gwelta OP
In reply to jkrumm, Feb 3, 2013
thank you. i could return it. iwill make a new test tomorrow.
Inkheart
Regular MemberPosts: 412Gear list
I don't think the first photo is soft or blurry because of the lens. It looks like it suffers from shutter shock. You can see it especially in all those thin branches of the trees on the left. They're all doubled. The second photo is not that bad.
Inkheart
 Inkheart's gear list:Inkheart's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Sigma 60mm F2.8 DN | A +3 more
ulfie
Veteran MemberPosts: 3,299Gear list
It's possible--note possible--you're not so steady, maybe pushing down on the shutter too hard too fast.  The two shutter speeds on your EXIFs are not very fast though 1/160 sec. should do the trick.  To really test the 20 put the combo on a tripod and take these same scenes's shots using the camera's self-timer.
Then again, as said above, you may have a bad lens.
Inkheart
In reply to ulfie, Feb 3, 2013
I think it's plenty enough for this focal length. You'd have to have really unsteady hands.
Yeah do that, and it'd be best if you did this test, with anti shock option off, and on, so you'll know if it's caused by shutter shock.
Inkheart
Timbukto
Senior MemberPosts: 4,370Gear list
In reply to Inkheart, Feb 3, 2013
Yes poor IBIS behavior combined with possible shutter shock.  You'd have to have really bad hands to take a blurry shot like that.  Another possibility is completely poor CDAF to front focus, etc...but you'd have to examine EXIF and see the focal distance.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
LincolnB
Veteran MemberPosts: 4,009Gear list
Not very good light, is it?
Not the best light for shooting, I'd say. Flat light, low contrast.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony Alpha 7 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
micksh6
Senior MemberPosts: 2,609Gear list
Perhaps because every setting on your camera was intended to reduce sharpness? Let's see:
  • Noise Filter: standard (should be low or, better, off)
  • Sharpness: 0 (1 would be better)
  • Aperture makes sure diffraction damages sharpness (there was absolutely no reason to use aperture smaller than F4.0)
  • IBIS - on, when shutter speed is safe.
In the end it's could be camera shake during the shot that resulted some blur. Or, you might have shutter shock or IBIS problem, who knows. 1/80s shutter isn't a good speed for benchmarking. 1/160s should be better but I'm not sure why on the 1st shot tree branches on the left show some doubling when it's hard to see it on the right side. Strong wind, perhaps?
With reasonable aperture you would have got 1/320s or 1/640s and sharper photos. And next time remove purple fringing, 20mm lens is prone to it.
BTW, you didn't have some noname UV filter on the lens by any chance?
 micksh6's gear list:micksh6's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +6 more
mh2000
Senior MemberPosts: 2,759
Inkheart
"fast enough," goes with, "sharp enough," which for typical prints, these are. For 100% crops and absolute critical sharpness most people need way shorter shutter speeds. Why do you think people test lenses on a tripod???
sigala1
Senior MemberPosts: 3,629
1/160 sec IBIS bug?
Maybe your EPL5  has a 160/sec IBIS bug. Try again with IBIS turned off.
Alien from Mars
Regular MemberPosts: 464Gear list
In reply to gwelta, Feb 4, 2013
Hi,
Seems like shutter shock at it's best.
Try to turn on 1/8s anti-shock and see if you'd have sharp images then.
gwelta wrote:
Hello,
A bientot Gwelta
 Alien from Mars's gear list:Alien from Mars's gear list
Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +2 more
sigala1
In reply to Alien from Mars, Feb 4, 2013
Alien from Mars wrote:
Hi,
Anti-shock may or may NOT work. It only protects against the shock of the first shutter movement, not the second movement when the shutter opens.
Alien from Mars
In reply to sigala1, Feb 4, 2013
True.
Still worth trying.
gwelta
gwelta OP
Ok thank you for your answer. I tried this morning two new photos before i go to the work. So the light was not great...
And yes! Yesterday there was a lot of Wind and it was 0°C (very cold with the wind).
So i turned off the IBIS and tried a picture with the timer on a tripod (second)
What do you think i should try now?
Thanks a lot.
Fred
Timbukto
Tripod shot is tack sharp.  Keep fiddling with IBIS and shutter speeds, or give up and exchange it for another that might be more well behaved.  Try neck-strap shooting...this is where you put on the strap, move your camera forward til you are tugging on the neck strap.  Try viewfinder shooting...even if you do not have a viewfinder attachment, see what happens if you press it up to your face and fire a shot using auto AF.
Paul De Bra
Forum ProPosts: 11,999Gear list
Not looking good.
It may be an issue with shutter shock as nothing in these images is sharp.
I do not use the 20mm f/1.7 often but this should give you some impression of what to expect. These are with the E-M5 but image quality should be the same. Note that I do use 1/8s anti-shock at all times.
First shot taken at f/4 in good light:
And here is one in really bad light, taken at 1/50s f/2.0:
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
gwelta
gwelta OP
Re: Not looking good.
In reply to Paul De Bra, Feb 4, 2013
Thank you but did you see the last two picture taken and postied this morning ?
If is is a "shutter shock" problem. Is it a camera problem ?
I took pictures with the 14-42 and the pictures are very sharp so i wonder about a problem with the camera but who knows...
Fred
sigala1
True.
Still worth trying.
I guess my bigger point was that anti-shock seems to work against most non-IBIS caused shutter shock, and it seems to work well on the E-M5, but the blurry two-axis IBIS on the EPM1-2/EPL3-5 may be caused by the second shutter movement.
gwelta
gwelta OP
So how should i set my system... ? I don't understand really..
