K5 Firmware 1.14 AF improvment
Started Feb 3, 2013 | Discussions
awaldram
awaldram Forum Pro • Posts: 12,316
No comment just 1 image and a crop, Note the 1.4 aperture
Sorry for running out of resolution but 6 MP was high enough to see the results
One very happy K5 owner !!!
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
Pentax K-5
Gerry Winterbourne Forum Pro • Posts: 11,096
Re: K5 Firmware 1.14 AF improvment
Hi, Andrew.  Not to rain on the parade, but I've tried mine in very dim light and still get the notorious FF.
Gerry
_______________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
awaldram
awaldram OP Forum Pro • Posts: 12,316
I think if the FF tungsten Firmware fix as reported by Pentax (think was 1.03) hasn't fixed your K5 then it has other issues that FW is unlikely to address.
My K5 had a fractional FF completely eradicated by 1.03 don't see any general variance in it Low light behavior as far as accuracy goes , But seems a lot better with fast lens and the stopping algorithm seems much faster which probably ties in with the fast glass improvement.
Its difficult for me to test Tungsten light issues as here in the UK tungsten lighting has gone the way of gas street lamps.
I can get the candles out tonight to give it a real test under heavy red lighting but don;t expect any difference from my previous tests post 1.03
Gerry
Stephenhampshire
Stephenhampshire Contributing Member • Posts: 895
Hmm, hope this might improve the a/f with my Sigma 30mm f1.4!
Everything changes
 Stephenhampshire's gear list:Stephenhampshire's gear list
Samsung TL350 Fujifilm X20 Pentax K-5 Pentax K-3 Pentax smc DA 16-45mm F4 ED AL +24 more
awaldram
I'll get a better idea next weekend when we (me and the camera) are out in anger will be using probably da*300 and Siggy 400 in lowish light will give me a good idea if SDm only or across the board.
markusm Regular Member • Posts: 141
I think it's now pretty much agreed on that the issue is an optical one, where refraction effects confuse the AF sensors. I guess that what that also means is that  you will have more problems with some lenses than with others (and I guess fast lenses will tend to do worse) and that it depends a lot on the light composition.
I won't buy it without more rigorous testing. Confirmation bias makes everyone claim that the camera now behaves a lot better. That said, I am perfectly happy with my K-5, even without the latest firmware.
Markus
sfa1966
sfa1966 Veteran Member • Posts: 3,333
Yes, looks like they've perhaps improved *something* in the AF algortihm. My AF seems a just a little bit snappier and more footsure than it was before. But that's just an unscientific gut feeling, and I left it more than 24 hours after upgrading the firmware before using the camera again, so I did not do a relatively contemporaneous "before and after" test.
Quite encouraging all the same.
sfa
 sfa1966's gear list:sfa1966's gear list
Sigma DP1 Sigma DP2 Merrill Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +9 more
MightyMike Forum Pro • Posts: 34,526
I just put mine through heck, low light and all and i found no real improvement, really left me more highly considering a K-5IIs but i still want to see if we'll get a K-3 first
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
breeze_of_wind
breeze_of_wind Senior Member • Posts: 1,196
Mike from Canada
Thanks -- I will not bother to update, and I too am waiting
See little reason to buy K5 IIs if there is a hope of a better body later this year
John
 breeze_of_wind's gear list:breeze_of_wind's gear list
Pentax K20D Pentax K-5 Pentax K-3 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +9 more
EArenz
EArenz Regular Member • Posts: 433
Just addressed this concern to a limited degree at least for the K-01 with CDAF in this thread:
K-01, v1.02 FW and some AF notes
Ed
There is no reason not to upgrade who knows what little tiny bugs they fixed but just don't expect glaring changes.
Mike from Canada
Stephenhampshire
Done both the K5 and K30 now, all OK. K30 and Sigma 30mm seems a bit more positive to on focus now, less hunting. Could be placebo, but I'm not complaining
Everything changes
klavrack Regular Member • Posts: 494
breeze_of_wind wrote:
Mike from Canada
John
Same here.  I'd replace my K-5 with a K5 III with more AF points, flash issues gone and focus peaking.  FF may be great for Pentax, but I don't want the added lens weight and expense.  Unless Nikon deals with their D600 sensor oil/dust mutiny, a  budget FF might help generate some new Pentax customers, though...lots of very PO'd owners.
Rufus12 Junior Member • Posts: 31
Sorry to hear your camera didn't quite work out with this firmware.
It has been a couple of days since I upgraded the firmware to 1.14 and I wanted to do a more thorough testing/use before I posted an update.  Prior to this firmware upgrade, my K5 would consistently get short sighted focus under halogen lights even as high as EV10 nevermind trying under low light. Prior to this upgrade, under fw version 1.13, natural/artificial white ambient light (fluorescent/led lights) lit subjects however were correctly focused even in near low-light situations.
jatthegreat Forum Member • Posts: 73
Did you notice something like this?
http://forums.dpreview.com/forums/post/50720646
and referring to this thread:
http://forums.dpreview.com/forums/post/50770595
Then it is possible that the AF improvements were added to the Dec release of 1.13 itself because I updated the firmware recently and found AF improvements.
Now, I hope that the problem I saw with Dec 1.13 FW is addressed in 1.14. I'll give it a try later today.
 jatthegreat's gear list:jatthegreat's gear list
Pentax K-5 Pentax K-5 IIs Sigma 10-20mm F4-5.6 EX DC HSM Tamron AF 18-250mm F/3.5-6.3 Di II LD Aspherical (IF) Macro Sigma 50mm F2.8 EX DG Macro +6 more
sfa1966
Ah ... Can't say because I went straight from 1.11 to 1.14. But I am sure they've improved something just like you described it there.
Great shots you took in that thread, BTW.
Most shots were EV6-EV7 mostly natural light it could have been the lens body combination also... now most of the shots came out in focus but there was a lot of hunting or just plain slowness. So in this regard i saw no real improvement making me want the low light AF performance of a K-5IIs
Mike from Canada
Raist3d Forum Pro • Posts: 35,556
Mine seems improved... interesting...
I just walked around tonight and it seems improved and this in low light. I turned off all lens corrections. I need to try now in daylight and see it behaves nice.
Where it starts to fail is in pretty low light and I guess this is where the K-5IIs/K-5II would pick up.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
awaldram
well the weekend came I was shooting in moderatley low light with a heavy yellow sodium element
Without any doubt AF is faster and more accurate.
The reason I'm so confident is the way I shoot.
I always have the camera on AF-c and Hi continuous shooting though I shoot single shots.
In the 2+ Years I've owned the k5 never have I had any issue accidentally firing multiple shots off.
Yet last night I had to turn Multi shot off. again and again lock rat tat tat tat two images taken.
There can only be one reason for this, the camera was acquiring lock earlier than usual so my standard 'squeeze' (to capture the right  moment) was long enough to fire two shots where pre 1.14 only one shot would have been taken in the same time frame.
With about 50,000 shots under my belt in this mode there is no rose spectacles in this, I'm having to alter my technique to cater for a faster camera.
Kerusker
Kerusker Contributing Member • Posts: 894
As you are a very experienced K-5 shooter, your conclusion should be right.
How about the focus accuracy? Faster doesn't mean better in any way.
If it's both - faster and at least as precise as before, then I will wait till the K-5 IIs price is coming down below 1000 EUR (and keep my K-5).
On the other hand: Only hard core K-5 users are looking for improvements by latest K-5 FW. These users are of the same kind which improve their K-5 handling to get the most out of it.
Sometimes it is hard to distinguish between these kind of improvements.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Pentax K-5 II Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED
