OMD exposure preview/live-view "as the taken image"
Started Jan 31, 2013 | Discussions
juantastico Contributing Member • Posts: 567
Hi again,
I am still learning more about this fantastic camera!:-)
I am wondering if it is possible to have a live preview of the exposure (aperture and speed), the same as when shooting in "M", but having this also in P, S, or A?
For example if i take a picture in "S" at 800 in a room with low light the image will be very dark, yet the live-view is bright, thus not representing the final outcome of the picture.
This is not an issues in "M" as the live-view is the same as the final outcome.
I hope there is a work around
Ps.
I have disable the live view boost feature, it seems that this feature has only an impact on manual.
Juan
Peter 1745 Contributing Member • Posts: 916
Re: OMD exposure preview/live-view "as the taken image"
If you go beyond the camera's ability to expose correctly in S mode the Aperture value flashes on the live view screen to warn you. Similarly in A mode the speed flashes. In P mode they both flash.
The only time you don't get these warnings if it you have set live view to display without any overlay.
I don't know of any way to get the live view to act the way it does in M mode
Regards, Peter 'Keep taking the photos'
juantastico OP Contributing Member • Posts: 567
Hi Peter,
Thank you for your answer.
I have looked almost everywhere (manual and internet), and I have come to the conclusion that it is not possible to have the same "real time" live-view as in "M" in any other shooting mode.
This is one feature that was possible in my canon G1X (as i recall :-)), in both A and S you could see the real preview and not only a warning when you were overcooking a photo, as with the OMD.
One more question is it possible in "M" mode to add the function (to a button) to get a quick glance of the optimal values for aperture and speed, thereafter you can override this manually if needed. I loved this function on my G1X, it made manual mode a dream
Cheers
Juan
No, but the exposure compensation display tells you how far away from the optimal exposure you are. It reads form +3ev to -3ev and flashes when you are beyond these limits. When the camera thinks you have it perfectly exposed it reads 0 .
Incidentally you can enable the option to have Auto ISO in manual mode.
Menu>Gears>E Exp/symbol/ISO>ISO-Auto = All
This shows Auto ISO as an option on the Control panel. You don't have to use it but it there if you want to.
Thank you for the answer and the tips
Have a great weekend.
Juan
pavinder Regular Member • Posts: 253
pavinder wrote:
A bit late on this, but this article offers an interesting workaround, although far from ideal:
http://photography.forumsee.com/a/m/s/p12-19210-086090--howto-em5-full-time-range-dof-exposure-iso-previewhowto-em5-full-time-range-dof-exposure-iso-preview.html
Thank you for the link I will, try the suggested set-up.
Juan
bowportes Senior Member • Posts: 2,682
juantastico wrote:
Hi Peter,
Cheers
Juan
Coming from Panasonic cameras, I have been genuinely surprised that the live view of exposure and 1-touch exposure suggestion are as poorly implemented on the EPL5 and EM5 as they are. My Panny G5 does both of the things you request. One-touch exposure suggestion can be assigned to a function button, and Live View of exposure is obtained through the shutter speed preview, which is assigned to another function button. Both of these are very useful and I miss them on my EPL5. Given its great feature set, I'm surprised these were omitted. Kudos to Panasonic for including them!
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
