Some D600 + 24-70 f2.8 pictures. Is that IQ expected?
wint
Regular MemberPosts: 283
5 months ago
And now, I'm posting here some of pitcures taken in the weekend.
What you guys think about the IQ produced from my combo? That are the IQ to expect or lacking something?
No post production here. From RAW 14bits to jpg 100% in LR4.
MarceloLI
Veteran MemberPosts: 4,632
Re: Some D600 + 24-70 f2.8 pictures. Is that IQ expected?
In reply to wint, 5 months ago
The pictures looks really bad, over exposed but it is not the camera or lens fault, it is your fault.
Why you are using ISO 800, 2200 and 6400 in a sunny day??
Check your settings and learn how to use the camera.
http://i.pbase.com/o4/17/494717/1/91869896.BfmL81rN.MorrisonHotel.jpg
Edited 5 months ago by MarceloLI
wint
In reply to MarceloLI, 5 months ago
My goal was not the right settings. I was shooting handheld randomly to test the IQ from the combo.
Peter Damroth
Regular MemberPosts: 368
Wint, these shots aren't bad they seem a bit over exposed (yes, set asa lower) consider setting camera to 'Standard or vivid' . The camera has a long scale and it can look low in contrast on some scenes. Also start with no Active D-lighting on low contrast days, and use ADL on contrasty days. I hope this helps you.
Peter Damroth Photography
Roland Schulz
Regular MemberPosts: 449
You could do better with a Sony RX100...
Sorry, but MarceloLi is right, pictures look really bad and I´m also sure it´s all user error.
Could have done the shots one or two stop slower from ISO. Do not know why you also set exp. comp. to +, not zero or -.
gl2k
Senior MemberPosts: 3,232
Why are you asking others if those images are of decent quality ?
What I mean ... are they good enough for you or not ? Can't you decide this on your own ?
wint
Re: You could do better with a Sony RX100...
In reply to Roland Schulz, 5 months ago
About the exposure compensation I didn't noticed is was up. Again my concern is not about the exposure is about the result from the lenses in any settings.
wint
In reply to gl2k, 5 months ago
I'm testing the lenses. See my previous reply.
JacquesC
Contributing MemberPosts: 653
The shots appears to be as sharp as you can expect considering the settings you used.
If you want to evaluate your lenses then you should pick subjects and conditions that allow you to shoot at base ISO with varying apertures and focal lengths. Just shooting away without paying attention to your settings will not tell you anything, it will in fact only muddle things up.
Unless something is really broken you should get good results with the combo you're using, you have some of the best body/lens combinations in your hand - learn to use it well.
Jacques
Apple & Eve website and blog : apple-and-eve.com
heulwen
Regular MemberPosts: 211
I'm confused. How can you expect to get good results from your lenses if your settings are all over the place?
It's not like good glass is going to cover up or make up for the things you dialed your camera to do.
An overexposed/washed out picture will be overexposed/washed out no matter which lens you have on the camera.
ormdig
Regular MemberPosts: 141
How can you "test" the lens using these ridiculous settings? It's as if you are purposely setting the combo up to fail. I highly suspect your motives here. If you were trying to test the lens/camera combo you would set the exposure to optimal settings, not as you say, pay no attention to them. It's a testament to the camera that the images look as good as they do despite your obvious attempt to sabotage them. If you are truthfully interested in the quality of your equipment then use it in a manner that allows it to produce quality images.
Steve Bingham
Forum ProPosts: 18,425
Wint
I will try to be helpful, but if you were "testing" the lens this is not a good way to do it. You have exposure compensation at 1/3 stop +, you are using a high ISO, and I see camera movement in the 1st picture. You have a great camera and a great lens but your post is puzzling. All of these facts hint that there might be others.
To answer your question:
1-Yes, this is a great combination
2- Your image quality is lacking - but not because of the camera or lens
Read a little more. Then practice. Repeat. You seem to have a good eye, but your basics need a little polishing. Keep working at it. You will get there.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
Peter Damroth
ENCOURAGE People, don't put them down.
amazona
Junior MemberPosts: 41
Is it provocation?
To be honest, You should give your equipment to someone, who know how to take photos. Let buy yourself a 20$ camera, and start a photo education from the beginning.
You can't test enything, because you can't use your photo equipment.
Regards.
http://www.trekearth.com/themes.php?offset=1&thid=9668
Roland Schulz
Sorry, but this was once a PRO forum
In reply to Peter Damroth, 5 months ago
rssarma
Veteran MemberPosts: 6,399
What, exactly, are you testing your lenses for?
Sharpness, DoF, CA, AF, decentering, vignetting....??
Raj Sarma
http://www.nycstreetshots.com
http://www.flickr.com/photos/rssarma
Follow me on Twitter: rssarma
Edited 5 months ago by rssarma
Hugo First
Regular MemberPosts: 453
you seem to expect professional results because you have professional equipment.
there's something missing, however.
i can count the whiskers on the man's face in the last photo. there's no problem with "sharpness" taken completely out of the context of the overall photo.
without "putting it all together," however, the final product can only be seen for what it is: a carelessly made snapshot that fails to satisfy on a number of levels.
the deficiency seen here is not one that can be rectified by purchasing an equally expensive camera from another manufacturer. if it were that simple, everyone would be a pro.
the deficit is behind the camera. it may seem undiplomatic to say so, but it is best to simply put it out there, and you can respond as seems best to you.
it will take hard work, and not just desire, to achieve the results you seek.
wint
In reply to Hugo First, 5 months ago
1) I'm not a PRO. I'm a beginner learning to be a PRO.
2) I know the photos looks bad. I had no good settings and they were not processed. My only goal was to check if even trying something randomly the results were going to be as expected for a normal functioning camera and lenses. Nothing beyond that.
I didn't know people would require very good looking photos to give they feedback about a overall result I was looking for.
3) I got also good photos in my life.
Looks here please:
500px.com/mrka
John Motts
Veteran MemberPosts: 4,266
In reply to amazona, 5 months ago
I can't believe the bloody rudeness on this thread.
A guy comes along asking for a bit of advice and a pack of amateur know-it-alls just rip him apart because it makes them feel big and important.
To the OP - yes you have some way to go, but at at least you asked for some advice. It takes time to learn, but stick at it. These pictures are nowhere near as bad as made out on this thread.
Peter Damroth
In reply to John Motts, 5 months ago
DITTO!
