Spots on DP2m sensor.
Started Jan 29, 2013 | Discussions
TaiTom
Junior MemberPosts: 43
Jan 29, 2013
I have had my DP2m for about a month and I am completely satisfied and even delighted with the camera and its performance. However, after a recent outing I noticed 2 spots in a couple of images with a lot of open sky in the frame. This must be dust or oil on the sensor. Anyone else have this problem?
Sigma DP2
Johan Borg
Senior MemberPosts: 2,276
Re: Spots on DP2m sensor.
In reply to TaiTom, Jan 29, 2013
Yes, mine had a tiny bit from the factory. Keeping the aperture in the sweet spot f/2.8-8.0 hides it most of the time. No big deal for me at least..
petr marek
Regular MemberPosts: 178Gear list
In reply to Johan Borg, Jan 29, 2013
Unbelievable, Sigmas customers are so generous, they have to reconcile to so many limitations, failures and obstructions taking photos and developing it... I think interchangeable mount would be a great solution of this Sigmas deficiency - you could at least clean the dust off the sensor... And you don´t need to buy three DP cameras for versatility, only three lenses... :))
Sigma sucks so hard...
PrebenR
Senior MemberPosts: 3,125
In reply to petr marek, Jan 29, 2013
No it doesn't. One can send in the camera and get it fixed. No problem. I got this on my DP1M and I reported it and was told to send it in so they could fix it. I have waited to do it though as 1) I wanted to use the camera 2) I wanted to see if more dust would come on the sensor.
It does not seems that that has happened, so that is good.So I'll send in the camera now to get it sorted as the DP1M will be used for landscape.
The Nikon D600 has terrible dust problems. D7000 had oil problems.... Dust can happen to all cameras and manufacturers.
The brief pain of taking photos is not important, the joy of viewing excellent photos is everlasting.
Truman Prevatt
Veteran MemberPosts: 4,379Gear list
Sigma would "suck so hard" if you sent it back and they said take a hike.  I am sure they would not.  If you have dirt or oil on the sensor of a sealed camera like the DP - send it back.  An SLR with interchangeable lenses and moving parts - maybe you would pick some up along the way.  But a sealed camera should be clean and if it is not I am sure they would fix it for you.
Sigma has a lot of issues particularly with QC, but at the end of the day I am quite sure they stand behind their products.  The OP should send it back and either get it replaced or get it professionally cleaned by Sigma.
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Nikon D800E Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 85mm f/1.4D Nikon AF Nikkor 135mm f/2D DC Nikon AF Nikkor 180mm f/2.8D ED-IF +8 more
SigmaChrome
Veteran MemberPosts: 7,765Gear list
In reply to TaiTom, Jan 30, 2013
Yeah, I've got little collection of spots too. But they are extremely small. Still annoying though. I'll keep my eye on them and if I see any change I'll return the camera to the distributor for repair or replacement.
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD14 +14 more
Johan Borg
In reply to petr marek, Jan 30, 2013
No, please, interchangeable lens cameras get more dust than my DP2M will ever have after every single lens change (been there, done that, my SD15 now has a 50mm/1.4 permanently attached). There's a reason I say it's no big deal, I'm not sure I would ever discover them if I didn't explicitly test for it at minimum aperture.
nandadevieast
Regular MemberPosts: 400Gear list
Why will there be dust spots on DPM's? Isn't a fixed lens cam supposed to be free of these things?
jbr
jbr
Regular MemberPosts: 293
In reply to SigmaChrome, Jan 30, 2013
My DP2M is clean but I had to return two DP1Ms before I got a clean one - a frustrating experience.  In my opinion there should not be dust on a closed camera.  Sending to Sigma for cleaning is not an option.  Sigma does not have this service in Canada.  Joe
Truman Prevatt
In reply to nandadevieast, Jan 30, 2013
If the sensor and all the remaining parts are not thoroughly cleaned and moved into a clean room for assembly - it most likely have dust.
There should not be dust in a sealed camera.  However, you might get some mole growth.  Again a reason for thoroughly cleaning and assembling in a clean room.
Sigma is not known for its high standards of quality control. That is the main reason I do not buy Sigma lenses - although they do make some attractive offerings.  Send the camera back.  It's a pain in the butt, however, you should not have to live with dust on the sensor of a sealed camera.
Truman
