Monitors, how good is good enough, and what's your pick?
Started Jan 28, 2013 | Discussions
xjf123richard
xjf123richard Forum Member • Posts: 58
I know I could bring this up for a hundred times and get different answers each time. Deep in my heart I just want to know if there are other good options on the market that I'm not aware of.
So let's keep it simple. Assuming money is not a limit but we all want to save as much as possible for other gears. So we'll get the cheapest one that is good enough for us.
I currently own a Dell U2410, around 500 price range. It's not good enough for me. The red tint is hard to get rid of even with Spyder 3's help. Colors tend to be "darkened" and the dark places in the picture has limited details.
I love MAC displays, but they are just too much expansive for a little improvement. If I want something at that price range, I'd expect something better.
So, what's your pick and is it good enough for you?
Appreciate your input.
herebefore
herebefore Veteran Member • Posts: 3,296
Re: Monitors, how good is good enough, and what's your pick?
Im wondering if you are running it in wide gamut mode..
This isn't recommended unless you have a special need for wide gamut.
If you run it wide gamut and send it non wide gamut content it will look dark and mushy (at least that is my experience.
Larry Lynch
Mystic, Connecticut
Be Careful, sleep can be a symptom of caffeine deprivation
I figured out why I cant lose weight! The only exercise Im good at is CHEWING
Don't take yourself so seriously. No one else does
In all matters of opinion, our adversaries are insane.
Oscar Wilde
CSMR
CSMR Regular Member • Posts: 475
For me U2410 was not good enough (mainly: too bright, too low res for the size). Very happy with U2711.
NewsyL
NewsyL Veteran Member • Posts: 5,655
This red tint.... when you bring up an all white or light gray screen, is it just on the left side of the monitor?  s there a hint of green on the right?
Are you familiar with the issues of viewing sRGB embedded images on a wide gamut monitor using software that is NOT color managed? (you get over saturate colors and red, in particular, stands out)
or vice versa, what happens when you view a wide gamut embedded image on a standard sRGB gamut monitor using software that is NOT color managed? (you get a dark desaturated image)
If you have not heard, the Dell U2410 is End of Life and will be replaced by a new model, the U2413, within a month of two.
There are some big changes happening right now with the IPS panels and the LED back lights so it may be best not to rush into a decision and wait a few months.
The new Dell U2713H, a wide gamut version of the new standard sRGB gamut U2713HM, is an example of what we should see more of.
Otherwise, in North America, your primary brands of upscale monitor are going to be from NEC or EIZO.  Samsung has an interesting S-PLS LCD panel technology, very similar to IPS, but they have yet to match it with a wide gamut back light.
Have you been following these two review sites?
http://www.tftcentral.co.uk/reviews.htm
http://www.prad.de/en/monitore/reviews.html
________________________
Newsy http://newsy.smugmug.com
Pictus
Pictus Veteran Member • Posts: 5,479
I have a U2410 and a Spyder3, the Spyder3 never did a good calibration, but the i1DisplayPro + Argyll+dispcalGUI did!
The U2410 is using the Adobe RGB mode + the trick to change its RGB settings by using the hidden factory menu . (warning before changing the default values, take a photo or write down the original values)
Here my profile + all the config files for dispcalGUI
Unpack all files into a directory, can use the monitor profile i1-adobe.icm or load the i1-adobe.cal into dispcalGUI by going to menu>Options>Install display device profile
My U2410 settings are:
Preset Mode = Adobe RGB + Factory Menu trick = R255 G226 B215
Brightness=10
Contrast=50
Color Settings>Gamma=PC
The dispcalGUI config is like this (Menu>Options> enable "Show advance options")
1-Try my profile
2-Buy a i1Display Pro (not the Munki as it can not calibrate the internal LUT of NEC/Eizo/Quato/Del u2413,u2713H,U3014)
3- If still not satisfied with U2410, get a U2713H or a NEC PA , Eizo SX/CG or a Quato
How to choose a monitor.
Good info about soft proofing and etc...
xjf123richard
xjf123richard OP Forum Member • Posts: 58
Thanks. I'm well awared of the color managment issues. In fact I asked and learned a lot from this forum.
I've bought the monitor for more than a year now, so I guess it's too late to sit back... But thanks for the heads up, I'll wait to see what happens next
xjf123richard
Brightness=10
Contrast=50
1-Try my profile
Great insight! Thank you. I'll try this but I don't think I'll have the money to put on a i1Display in a short time.
Pictus
Glad to help, the X-rite ColorMunki Display1 is cheaper and have the same quality, but it is slower and blocked to use third party software(excluding Argyll+dispcalGUI), so if you get a conclusion that the U2410 is not good enough, will need the i1Display Pro for the better monitors anyway...
