D800 f/1.4 Focusing Issues Fully Resolved!
4 months ago
Might as well post this, as it may help others. I spent alot of time with this camera getting OOF results with fast prime lenses when shooting them (f/1.4's) wide open. It seems that with every lens I own I needs between +15 to +20 AF fine tune to counteract the front focus in the body. Yeh, it seems like the body is out, calibration wise but I have checked this out and talked to Marianne Oelund who advised me that if it works there is no need to send it in to Nikon. I can now focus, like the D700 in any light, in low contrast, at distance, and close up, medium distances, wide open. The AF fine tune has worked perfectly. What is surprising is that close up focusing with AF fine tune OFF the issue was hidden, subjects still looked sharp. The thing is, at distance it looked terrible, totally OOF like some of the example pics I have seen on this forum. Now after tuning I notice that up close subjects are just a touch sharper and at distance now they are actually in focus - best of both worlds. Don't get me wrong, I still get the odd one or two that back or front focus (just like the D700 did in challenging conditions).
To re-iterate. Getting excellent results at all distances using:
AF-S (yes, despite what people say on here you do not need AF-C on static subjects, sorry)
True single point AF - no area or dynamic mode, centre mainly (or one of the centre cluster with a cross type sensor).
AF-fine tune is evidently very important. And it works much better if the lenses are fine as in my case but the body is out. Also you do get between -20 to +20. The DEFAULT setting gives you even more leeway as well as I have found in testing and had confirmed by Marianne Oelund. If you have focus issues with the D800 and haven't fine tuned try it because it has worked wonders. People are "worried" about leaving a camera tuned to +10, or +20. It's just a number and makes no difference I've found other than making each lens a whole lot sharper.
google + https://plus.google.com/u/1/110463150518351139559
flickr http://www.flickr.com/photos/steverphotographer/
Re: D800 f/1.4 Focusing Issues Fully Resolved!
In reply to primeshooter,
4 months ago
primeshooter wrote:
Might as well post this, as it may help others. I spent alot of time with this camera getting OOF results with fast prime lenses when shooting them (f/1.4's) wide open. It seems that with every lens I own I needs between +15 to +20 AF fine tune to counteract the front focus in the body... I can now focus, like the D700 in any light, in low contrast, at distance, and close up, medium distances, wide open. ...
AF-fine tune is evidently very important...
Glad you got it sorted out.
Robin Casady
http://www.robincasady.com/Photo/index.html
4 months ago
Hi primeshooter,
get your D800 adjusted by Nikon as well and you won't have to fine tune every lens. My first D800 was like yours but my 2nd is spot on with most Nikkor lenses.
FX
4 months ago
Good to hear it works for you too. I had a bad D800 first. Then Nikon sent me a new one and after fine tuning it works fine. As you, I did test it with AF fine tune ON/OFF and ended up with better results using ON.
If you don't mind me asking; what distance, related to focal length, did you do your fine tuning at?
In reply to steras,
4 months ago
I did it at a few different distances, but after trying to lenses and needing the same amount it was clear and easy to do. Probably about 1 metre then 2.5-3 metres (ish). To be honest even without a tripod, turning tuning ON and OFF I instantly notice the focus is exact and not front anymore!
4 months ago
What was your process to fine tune your lenses?
In reply to Mitrajoon,
4 months ago
Just as advised on here, tripod, mirror up, cable release, ruler at 45 degrees etc etc. I even tested some hand held afterword just to check real life. Front focus is so bad that I notice when I turn af fine tune off and take a shot at distance it misses. When I turn it on, exact focus resumes. And people said it was my technique!
4 months ago
I hope the ruler at 45 degree was a joke. You cannot fine tune a lens like that.
4 months ago
Thxs
4 months ago
I must admit mate that I find it unbelievable that you have posted so many times that the D800 was crap with fast primes..in just about all the D800 poor AF thread you chimed in with your own adverse D800 focus condition ......and now you say you never did a AF fine tune first...thats why Nikon add it to the menu options..so you can FINE TUNE...
before trying to make people follow your own mindset..please read the FM
In reply to Tommot1965,
4 months ago
Well it's out by alot more than I would expect. And if you want to be obtuse, I have read the manual. It HEAVILY advises against AF fine tune (I know why they say that but they really SHOULDN'T) :-)...more people actually said it's my technique! So I guess they are wrong too. You live and learn.
In reply to FX and DX,
4 months ago
Sure you can. I did it as well. Lens Align is exactly that. Did my 70-200vr2 handheld and it has made all the difference. I tried tripod and wall charts with live View, etc. The ruler worked better for me.
4 months ago
You should be able to get sharp wide open shots even if you are on a skateboard ! I only point out this to ask you to carefully read my reply to your other thread, when i said I missed focus and estimate the DOF to be no more than 2.5 inches, I did not say I missed focus by 2.5 inches there is a subtle difference but I am pleased you are getting the results you require, a number of posters tried to help but the somewhat irritable responses from you were a little unnecessary. Anyway put away the charts etc and get out and enjoy what is without doubt a fine camera
In reply to ScottnLaguna,
4 months ago
Actually, you need more than just a ruler at a 45 degree angle to do it right. You cannot guarantee where the actual AF sensor pixels are within the AF square. You do NOT want to put the AF square on a slanted ruler because you can't guarantee that you are actually focusing on your chosen "zero spot".
Done properly, you need to have a focus target that is parallel with your sensor plane. You put the slanted ruler next to that. You focus on the target and then examine where on the ruler you are getting sharp focus.
A minor distinction, but an extremely important one if you are going for correct fine tuning.
Mike Dawson
In reply to michaeladawson,
4 months ago
One of the Nikon web sites (might have been Nikon Europe) suggested using a book and a ruler. Choose a book with a lot of text on the back jacket. Put it parallel to the sensor plane. This can be done with a mirror. Tape a small mirror to the back of the book. Align the camera so the reflection of the center of the lens is under the center AF point in the viewfinder.
Set the ruler up at an angle next to the book. I think 45° might be a little too steep.
Robin Casady
One final question...
4 months ago
primeshooter wrote:
..... To be honest even without a tripod, turning tuning ON and OFF I instantly notice the focus is exact and not front anymore!
To iterate, is the only difference to your earlier settings the fact that you turned on the focus fine tune and found the right corrections?
If so, I would be tempted to ask why it wasn't the first thing to do when experiencing AF difficulties?
regards
Janne Mankila, Finland
The AF fine tune is a part of technique...
4 months ago
primeshooter wrote:
.....more people actually said it's my technique! So I guess they are wrong too. You live and learn.
They were trying to find an adequate reason for your missed focusing attempts. In all honestly, I think everyone assumed that you had already been through the focus fine tune procedure, as it is the very first thing to do when experiencing misfocus. Thus, I would even say that the fine tune procedure is technique.
regards
Re: One final question...
In reply to J Mankila,
4 months ago
regards
I think he answered this in one of his responses. According to him, the manual advises against making AF Fine Tune adjustments. So he was following "Nikon advice".
There is another "type of user" that popped up in these AF Fine Tune discussions a few months back. Their belief is that you should not have to use AF Fine Tune. The camera and the lens should have come from the factory good to go at 0. If your lens needs fine tuning it is defective and should either be exchanged for a new one or sent to the service center for repair. They bolster the argument with the "my Dxxx didn't need any fine tuning so I shouldn't have to now" line.
I'm NOT in any way saying primeshooter is one of these. Simply making a general comment. I agree with Janne... AF Fine Tune is there for a reason. And should be used (or at least checked) with all lenses. If you have issues with AF then fining tuning should be one of the first things you check.
Mike Dawson
4 months ago
Hi Primeshooter,
Thanks for sharing your experiences with fine tuning on the D800.
I however hope that people don't see it as the holy grail for AF issues.
Also you can get shifts depending on your aperture setting with prime lenses.
In relation to zoom lenses - so and so have not so much use to DIY fine tuning. If you do it is the best to take a kind of average for your most used focal length in combination with the most used aperture setting.
Single focus point is what I mostly use, both in AF-S and AF-C on the D800.
Michel
- To observe without evaluation is the highest form of human intelligence -
http://www.fotopropaganda.com
http://www.fotopropaganda.com/blog
http://www.flickr.com/photos/9240992@N05
4 months ago
True, but only if you don't move!
