P7700 minimum apertures in aperture priority mode
Started Jan 27, 2013 | Discussions
Terrier989 Regular Member • Posts: 292
I am on the verge of buying a P7700 and have read many of these excellent threads, I have found the max apertures related to zoom setting but now want to know the minimums in aperture priority. f8/f11/f16/f32???
thanks
terrier989
Nikon Coolpix P7700
tomjar Regular Member • Posts: 490
f/8 at all focal lengths
 tomjar's gear list:tomjar's gear list
Nikon Coolpix P7700 Nikon Coolpix AW120 Nikon D5000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
walkaround Senior Member • Posts: 2,551
Re: P7700 minimum apertures in aperture priority mode
Smallest aperture at all zoom ranges is the same f8, just like all 1/1.7" sensor cameras.
Terrier989 OP Regular Member • Posts: 292
Thanks both.
Walkaround I have only ever owned DLSR with Aps-C I was not aware that the min aperture was dependent on sensor area.
Bit of a bummer as I was hoping for f11 or even F16.
terrier989
bper Regular Member • Posts: 201
When comparing it to a DSLR, the aperture is not the same because of the crop factor. At f8 it would be equal to f36.8 in a full frame DSLR (see info below) - bper
Nikon Coolpix P7700 equivalent aperture
thanks.
however that is an equivalent you cannot dial it in for use with say manual ext flash or playing with DoF
terrier989
Terrier989 wrote:
thanks.
terrier989
Applying crop factor to the aperture, in this case 4.55, is not hypothetical - it is actual equivalence you can verify experimentally.
"Playing with depth of field" is not a strong suit of smaller sensor cameras. Max aperture f/2 on the P7700 is f/9 on a 135 format, for the same distance to subject and framing.
Nikonworks Senior Member • Posts: 2,202
walkaround wrote:
"........ Max aperture f/2 on the P7700 is f/9 on a 135 format, for the same distance to subject and framing.
As a people photo that is reassuring, pic wise it looks like 5.6 not your calculated 9.
Thanks for the info.
