Canon 6D Shutter Count Help
Started Jan 26, 2013 | Discussions
Dane01 Forum Member • Posts: 64
Is there any way to get the shutter count for a canon 6D, just got one today and the box seems to ne kinda cut so wondering if a return. When powered on I had to set the date and all but still want to know if any way to do a shutter count. Any help will be appreciated.
Canon EOS 6D
Sunpilot Forum Member • Posts: 85
Re: Canon 6D Shutter Count Help
Hmmm...I'd like to know also...mine arrives in a few days and I want to check it out
You're never lost, because no matter where you go...there you are
 Sunpilot's gear list:Sunpilot's gear list
Canon PowerShot SX110 IS Canon EOS 6D Canon EF 16-35mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM
KnightFall Regular Member • Posts: 173
Just ship it to a canon service center.
Are you going to replace if it has 5 clicks on it?
CameraCarl Veteran Member • Posts: 4,468
This sometimes works: put a new or old memory card in the camera. Format the card in the camera. Take a picture and check the image number.  If you formatted the card in the camera first, the image should be 0001.  If you didn't the camera could start numbering from the last image number on the card.
ASR45
ASR45 Forum Pro • Posts: 34,982
Thanks for that, never new that.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
Silicon Sam Regular Member • Posts: 456
Alan.
Mark Twain
Sigh.... Here we go again.
Formatting an old card in the camera alone will NOT get rid of the data that contains the last picture number taken.
You can take a card with picture 7430 in your old camera, put it in your new camera, formatted or not it still will show 7431 as your next shot, unless the new camera has a number in it that's higher than 7430.
Put the old card in your card reader on your PC or Mac, format the card, then put it in your camera, format it a second time, this time in the camera, and you will have a zero'ed out card. The next shot will be 0001 if it's the first shot on the camera body, or the next number in line if the camera already has some clicks on it from another card.
 Silicon Sam's gear list:Silicon Sam's gear list
Canon EOS 5D Mark II Canon EOS 10D Canon EOS 50D Canon EOS 300D Canon EF 15mm f/2.8 Fisheye +6 more
Hank3152
Hank3152 Forum Pro • Posts: 13,460
Proper method of resetting the file number......
I agree Sam, it will only pick up from the last file number in the camera's memory.
To the OP ~ Here's the way to reset the file number to whatever number you want:
Take a newly formatted card and take a single test shot. Place the card in a reader and edit with the PC. Renumber that image filename to the number you want (_0001?). In the menu set camera to auto reset numbering mode and put the card in the camera then take one shot. It will be numbered one greater than the number you had on the card. Return to the menu and change back to continuous numbering mode.
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
Petroglyph
Petroglyph Senior Member • Posts: 4,988
Doesn't Canon put the 'Shutter Count' tag in the EXIF meta-data of its files.  Exiftool can read this information from both raws and jpegs.  (Or I thing gThumb or PhotoMe will also do).  This is the absolute number of clicks like the odometer of a car.
Regards.
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +5 more
