Let's petition Metabones for a Canon to Fuji SpeedBooster!
Started Jan 26, 2013 | Discussions
WaltZ Regular Member • Posts: 142
I have a handful of great Canon EF lenses, and would LOVE to be able to turn them into even faster/sharper lenses on my XE-1. I've sent Metabones an email, and their response was "we'll look into it." Please, please, please, send them an email and ask for an EF to Fuji-X adapter!
info@metabones.com
If you're not familiar with this adapter, here's their press release.
 WaltZ's gear list:WaltZ's gear list
Fujifilm X-E1 Fujifilm X-T1
Zardoz
Zardoz Senior Member • Posts: 1,249
Re: Let's petition Metabones for a Canon to Fuji SpeedBooster!
Would rather a Nikon F mount version.  I suspect that'd be true of all the ex-S series people too.
mr moonlight Senior Member • Posts: 1,789
The only issue with using Canon EF lenses with the X-mount is that you can't change the f-stop unless you put the lens back on a Canon body.
JimLong Regular Member • Posts: 390
According to their website, the Canon EF to NEX supports auto-aperture, image stablization, EXIF and (slow) autofocus support for late-model (post-2006) Canon-brand lenses.  I would assume that if they designed one for the Fuji X mount, it would have the same capability.
(unknown member) Regular Member • Posts: 362
Yeah that does suck, considering you can control aperture of the EF lenses on NEX cameras with the adapter. I guess in this case the aperture ring on the lenses kind of backfired for Fuji (although I love it)
hellocrowley Senior Member • Posts: 1,271
They'd need to redesign their adapter to include an aperture ring, since the X bodies can't change aperture.
And then you run into the problem of how accurate that is, considering those aperture blades were not designed for that lens. Especially with all the different lens sizes/designs out there. Im no expert, but I expect that wouldn't work out very well.
Toanisanidiot Junior Member • Posts: 42
I wouldn't mind just having a canon to fuji speed boster that didn't have electrical contacts. It'd be cheaper without it, and I would be able to adapt nikon F and OM lenses to it with a cheaper adapter.
I also mainly shoot wide open on my canon lenses anyways =]
 Toanisanidiot's gear list:Toanisanidiot's gear list
Canon EOS M Canon EOS 5D
Brian Dougher
Brian Dougher New Member • Posts: 8
This is exactly what I was thinking. More lenses can be adapted to Canon, and I don't need the electrical contacts. could use my Canon converted Minolta 58mm 1.2 lens, my SMC Takumar and my Nikon AI lenses.
VisualFX Contributing Member • Posts: 925
There is no need for these stupid adapters. Just buy Fuji native lenses, where you get full focusing and works as designed. Putting larger lenses on these small cameras is ridiculous.
 VisualFX's gear list:VisualFX's gear list
Samsung NX500 Samsung NX1 Samsung NX 12-24mm F4-5.6 ED Samsung NX 50-200mm F4-5.6 OIS Samsung NX 10mm F3.5 Fisheye +7 more
I dont even think it needs to be said, but obviously fiuji's lineup is not all the way fleshed out yet. Some people just aren't as patient. I'm wanting something comparable to my 135L, I love that lens and theres nothing even close to that focal length available.
I have been amazed with Fuji's lens quality though and given the choice, I would honestly pick Fuji lens over my L glass based on my experience. The Fuji's have been stellar right from wide open IMO
jonnie burtoft Contributing Member • Posts: 533
Canon fd for me, the lenses are small, light cheap and good performers. I have the 50 1.4, 85 1.8 and 135 2.8. I use them on my m43 and xpro1. Cheers jon
Randy Benter
Randy Benter Veteran Member • Posts: 3,145
I am still looking for an adapter for legacy Fuji X lenses. I expected this to be one of the first adapters available. Has anyone seen one of these?
 Randy Benter's gear list:Randy Benter's gear list
Fujifilm X100T Fujifilm X-T10 Nikon D7200 Carl Zeiss Touit 1.8/32 Apple Aperture +18 more
Bernie Ess Veteran Member • Posts: 7,003
I am not too interested
The only lenses I'd like to put on a Nex or my X-E1 are the Zeiss ZF lenses. They have an aperture ring, and very beautiful image quality. They operate on my F- mount cameras and (via small adapter) on my 5d II.
However the lenses that Fuji will bring out for the X-System are smaller, lighter, some of them are very fast (f1,4) and optically all are very good. There will be XF- 23/1,4 , 56/1,4 plus the current 35/1,4.
With those 3 alone you can shoot a lot of stuff, small, light and sharp.The FF lenses with Metabones adapter will make you loose quality. Not a lot maybe, but excellent lenses will probably end up only "very good".
The Metabones adapter is expensive, and the whole thing will end up heavy and large. If I really want shallowest DOF and FF quality, I put my lenses on my 5dII.
Bernie
'All the technique in the world doesn’t compensate for the inability to notice.' (Elliot Erwitt)
shigzeo
shigzeo Senior Member • Posts: 1,732
I'm sure that is not true. The body changes the aperture in the lens after the lens tells the body what setting it wants. The Fuji lenses have NO manual control of aperture or focus. It is as EF as Canon's system is. Fuji would just have to add a separate body-controlled menu item or something to allow more direct electronic control.
 shigzeo's gear list:shigzeo's gear list
Nikon D200 Nikon D800 Fujifilm X-Pro1 Sony Alpha 7R Fujifilm X-T1 +9 more
When I set my 18-55 lens to auto aperture ane change the shutter speed dial, the aperture changes, so I believe that the X-E1 can change apertures.
And thats the issue. Im not sure Fuji would be willing to add that in camera aperture adjustment just for a 3rd party adapter. I could be wrong though, Fuji seems to listen to its customer base. If any company would make a change for that reason alone, it'd be Fuji
devwild Forum Member • Posts: 65
The electronic control for the 18-55 is on the lens but not marked, so it really works like a +/- control. If that really all the signal that needs to be sent to the body, that would be very easy to do with two soft buttons on the adapter. Just another alternative, though certainly would drive up the cost.
The real problem may be that the electronic controls may only speak to official lens with fuji firmware.
Nixon Glenn Regular Member • Posts: 247
I need the EF to x-mount Speedbooster to mount my EOS-modified FD & Minolta lenses and Canon 17 TSE lens on Fuji XE-1 ... hope Metabones read this ...
