D600 Tethered Shooting using Lightroom 4
Started Jan 24, 2013 | Discussions
pk pete Regular Member • Posts: 121
I have D600 and use LR4.
Can the D600 be tethered to LR4?
What kind of cable I need or which hole in the D600 is for that purpose?
Appreciate!
Pete
Nikon D600
pk pete OP Regular Member • Posts: 121
Re: D600 Tethered Shooting using Lightroom 4
Appreciate!
Pete
I did try.  Hooked up with a USB cable.  My pc can recognize D600 as a drive.
But Lightroom 4 cannot recognize a camera (D600) at tethered.
I guess I answer the question myself.  D600 or Lightroom 4 does not support tether.
lock Veteran Member • Posts: 6,183
LR 4.3: no d600 support for tethering
..yet. But I assume they will fix this.
Clivegriff Senior Member • Posts: 1,643
Re: LR 4.3: no d600 support for tethering
I'm looking forward to be tethering my D600 to LR.
I'm told that there are usually two delays with a newly-released camera: a reasonably short delay while the software companies re-write the RAW code and then a longer one (possibly 6 months) until tethering support is added.
MTT Veteran Member • Posts: 4,954
I tried there latest update yesterday and LR still won't tether to my D600. Camera Control Pro works, so I will use it for now.
http://mtt.smugmug.com/photos/245519815-O.gif This is me Post Processing. If only I can get it right the first time! Full time auto tech, part time photographer. Mark Thompson/MTT Louisville, KY. USA Why do you have to 'put your two cents in'.. but it's only a 'penny for your thoughts'? Where's that extra penny going to? http://markthompsonphotos.com
Onetrack97 Senior Member • Posts: 1,953
Take a look at FastPictureViewer  Pro.  Stupid name but great for tethering.
I use it with Lightroom instead of its native tethered mode or Camera Control.  The advantage is that it allows you to store the photo in the camera'fs memory in addition to sending it to the computer.
Scott
 Onetrack97's gear list:Onetrack97's gear list
Nikon D3 Nikon D7000 Nikon D800 Nikon D7100 Nikon D810
WIMorrison Senior Member • Posts: 1,499
I use ControlMyNikon to tether my Nikon cameras - best software that I have found to do this, cheap and very powerful - well looks a look.
Iain Morrison LRPS CPAGB
wimorrison.co.uk
 WIMorrison's gear list:WIMorrison's gear list
Nikon D7000 Nikon D800E Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +13 more
not ready for d600 yet.
They just released 4.0 with d800/d4 support.
lock
Re: not ready for d600 yet.
lock
My bad, I assumed that because it works with all the bodies I use, including d800e that it worked with all other bodies
well worth keeping an eye on the site as he updates regularily and if you mail him he will tell you where it stands for d600.
again, sorry for getting your hopes up.
wimorrison.co.uk
seekq New Member • Posts: 1
Works in LR5 Beta.
boblajes New Member • Posts: 2
I've had the same issue and this guy has the solution. Basically, he walks you through copying the tether file from LR5 Beta. He then demos a test shot with the d600 tethered in LR4. Here's the link:
http://www.youtube.com/watch?v=a5pCv5fJ5nM
Okay...I just downloaded LR5 Beta, copied the file into LR4 and shot a test. Easy peasy!
LR4 D600 tethered capture
