Melbourne night photos with K-5 & Tamron 70-200mm. WB question.
Started Jan 23, 2013 | Discussions
Kyogle Contributing Member • Posts: 549
These were taken from an apartment in South Yarra looking towards Melbourne's CBD. Although I am happy enough with them I am wondering whether AWB was the most appropriate setting. What WB would you normally use under such circumstances? Thanks.
David, an Australian living in the Highlands of Scotland a few months each year.
 Kyogle's gear list:Kyogle's gear list
Fujifilm X-E2 Fujifilm X-T1 Voigtlander 15mm F4.5 Super Wide Heliar Voigtlander 21mm F4 Color Skopar Pancake II Voigtlander 25mm F4 Color Skopar Pancake +6 more
Pentax K-5
afterswish1
afterswish1 Contributing Member • Posts: 737
Re: Melbourne night photos with K-5 & Tamron 70-200mm. WB question.
I posted a thread asking a similar question, and I think the consensus was that at night with mixed lighting you can choose what you like best!
You could go with a white balance that for you gives the most 'realistic' scene, or that suits your artistic goals for the shot. I rather like the results you got in those two images with it on auto.
Beauty and folly are old companions.
John Venables Senior Member • Posts: 1,085
It is difficult with mixed lighting like that but I like the effect you have with the photos shown.  I think it comes down to taste more than anything else.
This is where shooting in Raw helps as it gives you more room to change the WB.
http://farm1.static.flickr.com/213/448093203_0e1da1cb0e_t.jpg
John V
K5 K10D Pentax 18-55WR, Tamron90DImacro, Zenitar, Tamron 200-500(screw mount)
Using K100D Super and Panasonic ZS3 New Member • Posts: 12
Adjusted image
Hi Kyogle
With mixed lighting, different parts of an image may or may not be to your liking. There may be no WB that could make all parts of the image appear as you wish. If this is the case the part of the image that appears incorrect can be adjusted separately from the rest of the image.
For example (and this is just my opinion) the color and luminance of the sky in the first image looks incorrect for the rest of the image (a night scene). It''s too bright and colorful. I took the liberty to adjust the image to my liking and uploaded it as an example. (This is only my second posting and I'm not sure if I can upload my example).
In addition to keeping the first image content as is, have you considered creating a duplicate image and cropping it where the image is of the buildings or just the upper parts of the buildings and a small portion of the sky?
 Using K100D Super and Panasonic ZS3's gear list:Using K100D Super and Panasonic ZS3's gear list
Pentax K-5
Jonathan Lee Regular Member • Posts: 393
if u like the color film look, try the ultra complicated ... daylight balance.
Cheers, Jon.
 Jonathan Lee's gear list:Jonathan Lee's gear list
Sony Cyber-shot DSC-TX30 Canon EOS 5D Pentax K-3 Canon EF 50mm f/1.8 II Canon EF 135mm f/2.0L USM +7 more
Qwntm Veteran Member • Posts: 6,075
That Tamron is a winner! Particularly so with the screw drive in the Pentax mount!
Edward
www.youtube.com/photouniverse
www.edwardthomasart.com
www.pbase.com/edwardthomas
 Qwntm's gear list:Qwntm's gear list
Fujifilm X100S Pentax K-5 IIs Canon EOS 70D Canon EOS 7D Mark II Pentax K-3 II +11 more
Kyogle OP Contributing Member • Posts: 549
Thanks for your helpful comments. Much appreciated.
Using K100D Super and Panasonic ZS3 wrote:
Adjusted image
Hi Kyogle
Thanks for this. Actually the sky in the first photo is basically how it was. I took the photo before it was really dark and there was still plenty of colour in the sky. When it became totally dark I stopped taking photos.
andrew britten Senior Member • Posts: 1,126
Hi Kyogle
Any Melbourne shots I've done under these lighting conditions have the same look to them as yours and I always love the way the sky renders.
AWB balance on the K-5 is the best approach I feel.
Did you shoot raw?
If so the raws are immensely tuneable. Having said that, mucking around with balance in post doesn't give any better result than out of camera, other than a bit of tweaking here and there.
S, I reckon you got it right.
AB
 andrew britten's gear list:andrew britten's gear list
Pentax K10D Pentax K-7 Pentax K-x Pentax K-5 Pentax K-01 +1 more
Yes
andrew britten wrote:
Hi Kyogle
Did you shoot raw?
AB
Hello Andrew
Thank you for your comments. Yes, I shot RAW and Jpg but only processed the jpg for these shots. I played around with WB in Silkypix Pro 5 but didn't like the results any better than simply using camera's AWB.
