Fire and Snow G15
Started Jan 23, 2013 | Discussions
tkpatric Senior Member • Posts: 1,319
Fire and Snow G15
Very happy with my G15. It is maybe not the best, but it's mine!
 tkpatric's gear list:tkpatric's gear list
Canon PowerShot G15
Canon PowerShot G15
filibuster
filibuster Veteran Member • Posts: 3,210
Re: Fire and Snow G15
Blue snow eh?
Quote hhgttg: Life is wasted on the living.
filibuster (Bromsgrove, Worcestershire, UK)
http://picasaweb.google.com/scenic.filibuster
(unknown member) Senior Member • Posts: 4,085
Very nice photo, thanks for posting your photo from your Cann G15.
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
tkpatric OP Senior Member • Posts: 1,319
filibuster wrote:
Blue snow eh?
The red sun fooled us! Luckily blue is my favourite color.
Canon PowerShot G15
filibuster
tkpatric wrote:
filibuster wrote:
Blue snow eh?
Easily sorted.  Can I have a play?
Derek Oregon Contributing Member • Posts: 520
Don't eat blue snow!
Canon PowerShot G15
Martin87
Martin87 Contributing Member • Posts: 788
Corrected blue snow. Do you like it??
The original is a wonderful photo. I gave it a try because the snow was just too blue for me.
Kind regards.
Martin
 Martin87's gear list:Martin87's gear list
Canon PowerShot S3 IS Sony RX100
Re: Corrected blue snow. Do you like it??
Kind regards.
Martin
Yes, it was too blue! I like it now! Which program did you use?
Thanks.
Canon PowerShot G15
shuttervelocity Regular Member • Posts: 361
WOW!  Much better!  So, what was wrong with the first one?  White balance off?    As a new G15 owner, very happy!!
Sam
filibuster
Sam
Can I have a play too? I wouldn't do it without your permission.
Keith
filibuster
Sam
Keith
Against the usual rules of play, I have found that if I set the White Balance to 'Cloudy' for snow scenes, I get much better results without the 'blue snow syndrome.'
Keith
Martin87
I used photoshop, more details are in the forum message
I used Photoshop. I opened the image using the "Open As" command, and in the Open As menu I selected Open as: Camera RAW . After you open the image in this way it gives the same options as editing a RAW file. I've selected just the snow (the sky was left intact) and I adjusted the white balance on the snow. Also I've decreased the saturation on the snow and increased both clarity and contrast. And voila. It's not difficult at all and can be done in less than 5 minutes.
Hope my advice helped you.
Happy shooting with your G15
Sam
Keith
Please do!
Canon PowerShot G15
filibuster
Fire and Snow G15
Keith
Please do!
Thank you tkpatric for your kind permission.
https://lh5.googleusercontent.com/-PFlkBNrL_X4/UQBFVrOSSeI/AAAAAAAAX7A/LWchroAOOh0/s1200/97497173FEB847D888A9E9FE56371DF3%255B1%255D-HDR.jpg
Just a different implementation of the WB tool. Image processed in Oloneo PhotoEngine and will be withdrawn in say 24hrs.
Keith
Please do!
Thank you! Nice!
Canon PowerShot G15
WOW!!
Sam
RedFox88 Forum Pro • Posts: 24,705
But snow is somewhat of a blue tint in real life.  Your version does not look natural.
Kind regards.
Martin
Danel Senior Member • Posts: 2,905
Fix and advice
Whenever you have a color issue with an image, if you are using PS or PS Elements the easiest way to correct it is to go in to "levels" and then try setting the white point, gray point, and/or the black point.  Just click on the droppers (white, gray or black dropper) and then click on a corresponding part of the image that should be white, gray, or black.  This will easily correct color issues with just one click.  I fixed the OP's image with just one click using the gray dropper only.  Then I set the exposure to plus a little over a stop (snow and/or a bright light source tends to make your camera underexpose).  I did no other processing.  I figured that the snow would naturally pick up some of the hue of the sun and the corn stocks wouldn't be totally black.  Here is the quick fix result:
 Danel's gear list:Danel's gear list
Canon PowerShot SD800 IS Canon PowerShot G15 Nikon D7000 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II +5 more
Re: Fix and advice
Looks pretty good.  I have worked with levels but never used your technique.  thanks.
Sam
