Why not a 21.6mm x 21.6mm sensor?
4 months ago
The entire image circle for mFT lenses could fit within such a sensor. While such a sensor would be 25% larger than an APS-C sensor (468 mm² vs 372 mm²), it would still be barely more than half the size of a FF sensor, so I don't imagine the cost of the sensor itself would be an issue.
The advantages of such a sensor, however, are substantial: you would not need to rotate the camera from landscape to portrait orientation (especially convenient if using on-camera bounced flash) and you could crop to any aspect ratio you like with no IQ penalty.
So, what are the downsides that negate the upsides?
Re: Why not a 21.6mm x 21.6mm sensor?
In reply to Great Bustard,
4 months ago
Lens hoods, especially petal or square lens hoods, are effectively configured for one aspect ratio; they should have some leeway, but going to a sensor shape that is different by that much you might get vignetting when trying to use supplied lens hoods at the lens' wider focal lengths (or only focal length, in the case of primes).
4 months ago
Having worked in the Semiconductor Industry (Eng'r Mgr) for 40+ years, I think that mfg. COST** of a larger sensor is the biggest problem followed by increased software issues. Also, the internal needs of the camera would be different.
** Mfg cost includes the decreased number of sensors on a wafer as well as the yield (which decreases dramatically with chip size.) After production testing also increases with chip size.
Paul
Vancouver, WA
http://www.pbase.com/spdavis/a_few_nifty_galleries
4 months ago
Why not? because it is square.
Disk would better match image circle, disk would be logical, disk would be cheaper, disk idea is 3 years old
Looking for equilibrium...
In reply to s_grins,
4 months ago
Don't the disks have to be cut from a square wafer? So why not save the cutting and just put in the square sensor the circumscribes the image circle?
Interesting angle.
In reply to Klarno,
4 months ago
Then again, how hard could it be to redesign some hoods and sell them for $20 each?
So...
In reply to MaxB1,
4 months ago
...you think the cost of sensor 25% larger than APS-C would be the largest problem? I wonder what an APS-C sensor costs compared to an mFT sensor, as APS-C sensors are 65% larger.
Re: Interesting angle.
4 months ago
Ask Olympus...or try that on the 7-14 or the 7.5, let me know how that works out. At least none of the lenses seem to have internal/rear hoods.
Re: So...
4 months ago
So... It's VERY expensive, complex and requires time from the initial set-up and then production costs. You are technically introducing a new standard as it will impact not only hardware but also software and peripherals (lens & etc.). In my previous work as product engineer for wiring harnesses for Ford and GM cars, it takes 2-3 years from design to prototype work before 'green light' for first production.
we haven't even discussed R&D and registering/approval of patent. How many companies worked and agreed together before micro 4/3rds became a reality?
Soooo.... your reasoning and justifications are very minute and not financially logical on the overall scheme. Personally I think 3D and better phones sensors are the commercially and viable investments. 3D lenses for camera are slowly coming our.
reygon
Take nothing but photos... Kill nothing but time... Leave nothing but footprints...
4 months ago
To accomodate square of 17.3x17.3 you will need a circle of dia 25mm or so. I believe the image circle for mft is 21.6 mm dia.
::> Knowledge is mother of efficiency.
4 months ago
4/3 is more suare than 3/2, why not go one step further and make it a square. I'm all for it. You can say goodbye to those vertical grip.
^__^
Just Shoot !
Re: Why not a 21.6mm x 21.6mm sensor ?
In reply to zxaar,
4 months ago
Bingo ! ...
4 months ago
It would certainly be nice for square format (which I kinda like) sort of like a modern Rolleiflex.
My Gallery is here -
http://www.pbase.com/madlights
Why so serious? :The Joker
Re: So...
In reply to reygon,
4 months ago
The way I was thinking is that there is a whole slew of different sized sensors for compacts, there are two different sizes for APS-C, the mFT (4/3) sensors, and now the new 1" (2.7x) sensors, so it sure doesn't seem like making a new sensor size has presented any difficulties.
I mean, what makes 21.6mm x 21.6mm (the sensor I am proposing) any more difficult to get going than the 1" sensor Nikon uses in their 1 series and Sony uses in the RX100? Both those systems seem to be rather successful, no?
In reply to Promit,
4 months ago
One would think the wouldn't mind making $19 profit off of a $20 piece of plastic so that people could take full advantage of their new oversized sensor. Then again...
Yes -- that would have been a bigger issue, for sure.
To be clear...
In reply to Lights,
4 months ago
...it's not a square format that I am proposing. It's a square sensor that the entire image circle is inscribed in. So, the camera records the whole of the image circle, which the photographer can crop (or not) to whatever aspect ratio they choose without any penalty.
Re: So...
4 months ago
Yes, cost. The thing is sensor cost grows exponentially with sensor size. Thom Hogan stated this, for example, and the reasons were exactly what MaxB1 provided above.
APS-C sensor won't cost twice more than m4/3 sensor, it will cost 5-10 times more, so economically this doesn't make any sense. It's better to make APS-C sensor for that money.
If there was any practical sense in doing it, this would have appeared on smaller sensor cameras, but it hasn't. It's more practical to rotate the camera.
Because of that, I think, it's safe to forget about square m4/3 sensor.
Re: To be clear...
4 months ago
Right I realize that. I see the advantages, and all. But it still would give a large image circle (and a higher resolution at square in comparison with a rectangular sensor of the same design) but square would sort of be it's native format?...which I would like. Why not use the entire image circle in that case. It might cost slightly more. Existing OEM lens hoods might be problematical, as has been mentioned, but there are lots of round ones (Leica style, rubber, WA metal etc.) I would like the idea. No need for a vertical grip to add size and bulk (Like on a couple of my other cameras), whatever format a person wants, without holding at an odd angle..if the LCD screen was a simple tilt screen it would would work fine. Even the position of the viewfinder wouldn't have to be adjusted for verticals. When I have used vertical grips it de-contributes to the ergonomics, almost like having to learn to instinctively use two cameras, so would sure help in that regard.
In reply to Lights,
4 months ago
Rather a modern Hasselblad! (I'm a swede). I think a square sensor is a nice idea, and a square format. 4/3 is so close to 1/1 anyway. The sensor corners could be a little bit outside the image circle but not that big as 21,6x21,6. You could choose between square, portrait and landscape afterwards instead of turning the camera 45 degrees. Or choose format with a button on the camera. Like you could with the film APS format, if someone remember that.
Re: So...
4 months ago
You said "so it sure doesn't seem like making a new sensor size has presented any difficulties" and even comparing other sensor sizes so kindly read again if I said "it's difficult". What I emphasized is it's not commercially logical (cost). As I said, you are introducing a new standard with odd size which is not too far from APS-C (Canon or Nikon size) except it's square. Hey, why not produce a circle sensor? it compliments the lens right but hey it will be more expensive to produce it (beside new production line there will be considerable wasted material from silicon wafers).
For the output and viewing, are you saying it's also better to view in square screens? The film academy, who also uses same camera and lenses principles, came up with 4:3 being the ideal ratio for projecting on a screen. It used most of the image circle a lens produced. It was known as the Academy Ratio. Ernst Leitz doubled the size for his 35mm (movie film) still camera. It has a ratio of 2:3 (still not square!!!) which are basis for APS chips so it still maximize the use of image circle a lens produced. Olympus, Panasonic and 4/3rds system is based on the Academy Ratio. Let's not even discuss printing square photos. So... it's not just engineering it's also complimenting the overall industry. I'm sure the 'beautiful and great minds' out there in the R&D considered and evaluated these so many times before as the camera and film industry progress to a million then to a billion dollar industry.
reygon
