X100 LCD and EVF
Started Jan 22, 2013 | Discussions
widick Forum Member • Posts: 80
X100 LCD and EVF
I just purchased an X100 and have been surprised at how poorly the LCD and EVF perform.
Both electronic displays produce extremely washed out images.  I have played with the brightness control and it does not solve the problem.
I just compared the X100's display to an old Fujifilm F200EXR's display and there is no comparison.
The F200EXR display gives a pretty accurate rendition of the scene, the X100 does not.  Are others
experiencing the same results?
Fujifilm FinePix F200EXR Fujifilm FinePix X100
bugeyed
bugeyed Senior Member • Posts: 1,336
Re: X100 LCD and EVF
May be defective. Take it to a shop & compare it to another one.
kev
I just think that things should work the way I expect them to.
widick OP Forum Member • Posts: 80
Actually just compared it to my old F200EXR, no comparison.  It's going back.
LaFonte Senior Member • Posts: 2,744
Looks like defective - I would not call it washed out at all. Especially the LCD is pretty brilliant to look at. Or maybe you just turned up the EV wheel by accident?
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-FZ1000 Fujifilm X-Pro1 +1 more
danstern
danstern Regular Member • Posts: 236
Is the LCD/EVF different than what you saw at the store or where ever you saw it, before you bought it? Versus comparing it to another camera altogether... I am very satisfied with the OVF and LCD (although I never frame an image from the LCD)...
Photozopia
Photozopia Senior Member • Posts: 1,302
Already discussed your low contrast EVF in another thread topic - if the LCD display is similar, then I'd return it. The X100 is not noted for overly poor display outputs.
I believe there is same video supply board driving both displays ... perhaps this is faulty.
