time lapse of stars and sunrise using the time lapse app
Started Jan 22, 2013 | Discussions
kev777zero
Senior MemberPosts: 1,511Gear list
Jan 22, 2013
started playing with the time lapse app recently that I downloaded on my NEX-5R; it makes taking time lapse videos quite easier but the lack of controls like manual focusing or changing apertures make it a little less flexible. Another issue is not being able tochange the exposures as the videos are being taken, as the exposure may change dramatically in situations like sunrise/sunsets. anyways, enjoy!
NEX-5R + Rokinon 8mm f/2.8 fisheye (may need HD + enlarge to see the stars)
http://www.flickr.com/photos/kevinwlyu/8397849129/in/photostream
Nex-5r + Zeiss 24mm f/1.8
http://www.flickr.com/photos/kevinwlyu/8398841614/in/photostream/
 kev777zero's gear list:kev777zero's gear list
Sony Alpha 7 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS NEX5R Sony E 16mm F2.8 Pancake +2 more
NEX5R
bzx
bzx
Regular MemberPosts: 215Gear list
Re: time lapse of stars and sunrise using the time lapse app
In reply to kev777zero, Jan 22, 2013
with regards to your sunrise timelapse, have you tried using "Sunrise" theme from the app? it looks like it should adjust shutter speed accordingly.
here's the manual
https://www.playmemoriescameraapps.com/portal/manual/IS9104-NPIA09014_00-000003/en/index.html
t[+]m
 bzx's gear list:bzx's gear list
Sony Alpha NEX-5 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +2 more
kev777zero
In reply to bzx, Jan 22, 2013
I did use the sunrise theme, but every shot was based on the settings of the first shot, whether it be exposure, focus area, shutter speeds, etc...
paul1508
Regular MemberPosts: 402Gear list
Is there no possibility to set EV to 0 or +1 or anything on the beginning and the camera sets aperture, iso and shutter speed like it pleases?
kev777zero
In reply to paul1508, Jan 22, 2013
you can set EV at the beginning; what I am saying is that the settings are set in stone after the first shot, so say in a sunrise situation as more and more light comes in the apertures, iso, etc... remain the same, making the scene way overexposed
Puddleglum
Regular MemberPosts: 259
Are you certain you used the sunrise setting? The manuals description of it is "Shoots sunrise landscapes in which the brightness and colors change", so it would be really strange if it wasn't re-metering before each shot. Is it possible you had the metering set to something like "spot" that would cause it to not meter correctly?
joel avery
Senior MemberPosts: 1,686Gear list
Really like the star shot Kev.
Thanks for sharing!
 joel avery's gear list:joel avery's gear list
Sony RX100 II Sony Alpha DSLR-A350 Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 +6 more
bzx
bzx
In reply to Puddleglum, Jan 24, 2013
I second that - I would do that experiment again and check results. Otherwise there's something wrong with the app.
t[+]m
kev777zero
In reply to bzx, Jan 24, 2013
t[+]m
I set everything back to default settings and it still didn't work. After the first shot the camera does not focus for the next shot, does not change shutter speed or aperture, etc...
I'm not sure if I did something wrong if the app's just like this. but it's still a worthwhile app IMHO regardless. here's a sunset I did today:
http://www.flickr.com/photos/kevinwlyu/8409043593/in/photostream
bzx
bzx
In reply to kev777zero, Jan 24, 2013
The output sure looks great but that lack of shutter speed adjustment is bugging me.. (I don't have a 6 yet, but will be getting one) - was your camera in aperture priority mode when you started the app?   not sure if that even matters as the app might control the mode via its own modes.
t[+]m
nzmacro
Forum ProPosts: 12,089Gear list
Totally love that first one Kev !!. Clever use of framing. The second one is good as well, but that first time lapse, phew, darn good lighting and exposure and again of course, that framing.
All the best Kev and nice work using that feature.
Danny.
