Problem with the lens 9-18 Oly
Started Jan 22, 2013 | Discussions
tedolf
tedolf Forum Pro • Posts: 22,051
Re: Hoods no good.....
Guy Parsons wrote:
tedolf wrote:
they make a thing called a lens hood.
The rubber ones are best.
Tedolph
As mentioned a few times, a lens hood does not help when the sun is in the frame.
I think it might work for No. 4, the Sun is just at the edge of the frame.
In fact if you think about it, the lens hood probably adds problems because the sun light is hitting the lens front and also may be reflected off parts of the inside of the hood (matt black paint isn't perfect black and fully light absorbent) thus adding to the problem.
Regards..... Guy
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +8 more
Chez Wimpy
Chez Wimpy Veteran Member • Posts: 8,855
Re: Lens flare normal, purple flare not so much
Savas Kyprianides wrote:
What's a multi-AR feature? What model Panny is a good one to look for?
To facilitate video without straight "cropping" the frame (this probably happened because Panasonic had video in mind for m43 from the ground up, step-less aperture, power zooming, ect, but the legacy 4:3 sensor design was going to have be cropped top and bottom - losing angle of view on the lenses - to match the HDTV standard of 16:9) the GH1 and GH2 sensors were both designed oversized on the horizontal axis.  There is a diagram near the bottom of this page and an explanation:
http://www.dpreview.com/reviews/PanasonicDMCGH2/
As a feature it is endlessly fascinating, and I probably adjust the AR more than I adjust the aperture or ISO.  Basically it allows you to tailor framing in camera and avoid extensive cropping afterwards.  Where it makes the most difference is in UWA lenses.  There even a slight extension of the frame brings in objects that cannot be captured outside of image stitching (often difficult with UWA where foreground objects can create parallax errors).  ie: 16:9 when you need a vista, or 4:3 when you want the foreground to feature prominently.  Paired with the 7-14 this is an extremely effective combination.  I can only hope that Panasonic manages to get, errm, "someone", to fabricate them a custom multi-AR sensor in time for the GH4.  For now at least, only the Panasonic made GH1/GH2 sensors have this feature (and the G5 with a modified GH2 sensor, though the multi-AR feature is currently disabled... on the hardware or firmware level, as of yet unknown).
-CW
 Chez Wimpy's gear list:Chez Wimpy's gear list
Sigma DP1 Canon EOS 5D Mark II Canon EOS 20D Panasonic Lumix DMC-G1 Canon EOS 550D +23 more
Chez Wimpy
an iconic shot
Bob Tullis wrote:
Purple flare aside, here's a curious result with the 7-14. . . just out of view was a cross walk sign, not quite shielded by the hood on the lens.
I remember when you first posted this shot, and I still can't get over it   If there is ever a "flare" photo competition on dpreview, it is sure to get my vote!
-CW
awb1000 Forum Member • Posts: 51
Re: Problem with the lens 9-18 Oly
I've been using the 9-18mm on an EPL-1 for 2 years, now the EPL-5.  I have the Oly lens hood, usually have a circular polarizer on, and try to keep the direct sun out of the frame unless I want to deliberately get flare.
 awb1000's gear list:awb1000's gear list
Canon PowerShot G15 Nikon D700 Nikon D5100 Olympus PEN E-PL5 Olympus E-M1
astone OP Regular Member • Posts: 452
As I promised for your evaluation I’m placing some other images, which were taken at the same time and the same place.  No purple fringes were observed.
And again please disregard the content.  They all were taken to experiment with bright sun light.
 astone's gear list:astone's gear list
Fujifilm X100S Olympus E-M1 Sony a6000 Olympus M.Zuiko Digital 45mm F1.8 Sony E 55-210mm F4.5-6.3 OSS +5 more
idiotekniQues
idiotekniQues Senior Member • Posts: 1,255
Just got my 9-18
sold my panny 7-14 last week, the 9-18mm just showed up today.
i went outside and around the house and tried my best to get purple flare by aiming at the sun from every angle and at every bright light in the house (where i could create purple ghosting with the 7-14 a bit less than half the time)
not a bit of purple yet. going to go to my sisters house to shoot the interior again, where i tried twice with the panny 7-14mm and could not avoid purple ghosting in most rooms.
www.pixelsquish.com
 idiotekniQues's gear list:idiotekniQues's gear list
Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +2 more
Re: Just got my 9-18
www.pixelsquish.com
Why did you sell your 7-14?
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,267
www.pixelsquish.com
I'd suspect it was about that last paragraph [g].
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
Savas Kyprianides Veteran Member • Posts: 3,618
-CW
Thanks, very detailed.
www.pixelsquish.com
I returned my 7-14 within the return window because I was getting purple flare indoors near a light source, without direct light in the frame. I knew about the flare going in, but figured a lot of my stuff is interior and that I'd be immune to the effect.
idiotekniQues
excessive purple ghosting, including while shooting interiors which is a primary purpose for this lens.
real estate shooting can equate to paid gigs. no way in heck i could go to a client with the 7-14mm with the decent chance the shots would be unusable.
www.pixelsquish.com
idiotekniQues
yiasou savas!
how are you,
eimai kypreos! apou pou eisai?
www.pixelsquish.com
idiotekniQues
Shot 1st property with 9-18
absolutely no purple flare. thank the lord. i do kind of miss the extra 2mm of wideness however it helps keep me more disciplined and avoid the extra distortion that 7mm vs 9mm brings.
but the flare issue is gone.
www.pixelsquish.com
Re: yiasou savas!
how are you,
www.pixelsquish.com
Kala, efcatisto. Esi?
