GR Digital V has an APS-C sensor
BG_CX3_DPREVIEW
Senior MemberPosts: 1,664
Re: GR Digital V has an APS-C sensor
In reply to slappo, 5 months ago
No idea if this source is trustworthy or not, but it might be correct, could confirm the patent for the recent f1.9 lens for an apsc.
Earthrise
Regular MemberPosts: 235
Fingers crossed, fingers crossed
rondom
Senior MemberPosts: 1,113
Leica x1-2 type camera?
it will be interesting. I still would have preferred the smaller 1" sensor as that would mean a smaller body. But I am glad 1/1.7" will be dropped.
Godfrey
Forum ProPosts: 25,488
re: the mention of Leica X1/X2
I've been using my X2 an awful lot because of the stunning quality photos it makes, along with its very compact size and excellent controls, so Ricoh producing a competitor of Comparable quality can only be a good thing.
Godfrey
http://godfreydigiorgi.posterous.com
audiobomber
Veteran MemberPosts: 3,119
In reply to BG_CX3_DPREVIEW, 5 months ago
What focal length was the patent for?
Dan
rondom
End of a12 28?
I assume this will also mean that GRD will be competing against the GXR A12 units, especially the a12-28, considering that it will retain the same field of view as the classic GRD line. interesting Move from Ricoh. I wonder if they plan anything new for the gxr line. Maybe gxr will be home of the "full frame"?
rondom
In reply to Godfrey, 5 months ago
Godfrey, do you have the evf for x2 as well? Or is it  LCD only viewfinder for you?
i wonder if Ricoh is planning an evf for the new GRD?
audiobomber
In reply to audiobomber, 5 months ago
I found it, 27mm. That is the ideal all-round FL, IMO. I intend to use an FA 28mm f2.8 on my new K-01 most of the time.
Dan
Godfrey
In reply to rondom, 5 months ago
I have the EVF (I use the Olympus VF-2, which is the same unit as the Leica EVF) as well as a Voigtländer 35mm optical viewfinder. I find the EVF most useful when I want to work with the lens wide open as then I use AF more of the time and I can see what it's identified as the focus target. I use the OVF most of the time, setting the focus by zone as I normally do at f/5.6 to f/8. I use the LCD when it is the most convenient way to frame the shot ...
The X2 has proven itself a very worthwhile camera, if a trifle on the expensive side. It produces results on par in quality with both the GXR and M9, and is more sensitive than either. Clean rendering even at ISO 128000 setting! Check this out: Leica X2 Noise Evaluation
Godfrey
Edited 5 months ago by Godfrey
Tom Caldwell
Forum ProPosts: 13,323
The news is a bit thin on the ground.  There have been a few rumours of a GRD with a larger sensor for a while.  This one is billed as from a reliable source, says "it is a bit thicker", is "based on the aps-c sensor" and there is not much else to report.
Well do we get the Ricoh take on the RX1?  What might the price be?  I am sure that they are not going to sell one for less than Sony, or might they?  Ricoh in it's own particular way would have to look closely at their interface and also difference it mightily from the RX1 or else the market clout of Sony would surely wipe a GRDV.
One thing is assured I will have to buy a GRDIV if the rumour proves to be true.  I have the early adopters syndrome - a GRD, GX100 & GRDIII, not a GRDII, GX200 & GRDIV.  I have not missed the GRDII or GX200 but the GRDIV has quite useful refinements over the "III" and as the last of the very capable compact small sensor compact GRD line the "IV" must be well worth owning.
I presume that Ricoh must be into some compact camera trickery as the GRDV with aps-c sensor would have to be  not much larger than the present GRDIV to be considered in the same class of camera.
The GRD to date has been in a class of it's own and a very capable camera, much lamenting that it needs a larger sensor but if it leaves the class it presently dominates there will be a large hole left to fill.
Time will tell, but I think there is not enough announced to be manning the lifeboats just yet.
Tom Caldwell
yonsarh
Regular MemberPosts: 177
if this rumor is correct than the 2 lens we saw here
was patent pending,(both are aps-c)
so GRD could go for interchangeable..... ?
Edited 5 months ago by yonsarh
lenseye
Regular MemberPosts: 385
This looks like a hoax to me! This looks identical to a GRD IV with some extention mounted! There is even a 43mm to 49mm step-up ring with some kind of Kenko filter on top!The weird angle the photo is taken at makes it come across as different...
Why would a leaked photo be taken at some place with livingroom carpeting? Shouldn't prototypes be in some lab somewhere? Nice try but it ain't fooling me!
And my DPreview editor does not recognize English for some reason!
b
iaredatsun
Contributing MemberPosts: 708
In reply to lenseye, 5 months ago
It's not a photo of a GRD V and does not pretend to be one - it's just a photo to flesh out the story. Read the credit:
'Image credit: Ricoh GR Digital IV by matsuyuki'
Toccata47
Senior MemberPosts: 1,098
CP+ or bust
In reply to iaredatsun, 5 months ago
There's been mention of ricoh revealing a new camera at the end of the month. I certainly hope this is it.
Ironically, I had my finger hovering over a "bid now" button in the last two minutes of an auction for a grd iv last night when all of a sudden we lost power.
Joel Stern
Veteran MemberPosts: 8,831
This would be interesting for sure if it turns out to be so.
lenseye
I stand corrected! But at least I was right on, you got to give me that much...
It was too much to stomach for a good reason!
thx,
b
Edited 5 months ago by lenseye
rondom
Godfrey
Impressive...and the high ISO has a lot of character. love the grain. Thanks for sharing.
Edited 5 months ago by rondom
Prognathous
Veteran MemberPosts: 8,484
We can always hope...
With an APS-C sensor and a modest 18-33/2.8-4.0 lens (28-50mm equiv.) I might consider one. I'm not looking for another small-sensor camera unless it has a lens that offers very unique capabilities (range, macro, speed). The wide-angle prime lens in the current GR-D doesn't offer any unique capabilities, and no, it's optical quality does not offer anything exceptional when compared with wide-angle prime lenses for APS-C cameras.
Bottom line: Ricoh should go APS-C and compromise on lens speed. This way they can keep the small size but gain DSLR image quality, without compromising on low-light capabilities (the large sensor good SNR offsets the reduction in lens speed).
Prog.
http://www.flickr.com/photos/oren_b
Tom Caldwell
In reply to yonsarh, 5 months ago
Hi ho, so two new mount modules ... Simple.
Tom Caldwell
