PIX 2015
Yeah, the 16-50mm kit lens is awful
Started Jan 21, 2013 | Discussions
WoodWorks
Senior MemberPosts: 1,383
Jan 21, 2013
Taken last Saturday in northern California.
Mt. Shasta, 14,162 ft (4,317m)
David
It is impossible for a man to learn what he thinks he already knows --Epictetus
DFaulkner
New MemberPosts: 2
Re: Yeah, the 16-50mm kit lens is awful
In reply to WoodWorks, Jan 21, 2013
No offence, but at that size this could have been taken with an Iphone. Post the full size image & we can make a fair assessment
mbonsack
Junior MemberPosts: 45
La Jolla Shores, CA. Jan 20. 70 degrees.
Yup; totally agree...
The gorgeous Shasta shot and this one, taken in the same state within a week of each other in the winter, make dealing with high California taxes well worth it
-mark
viking79
Forum ProPosts: 14,053Gear list
Nice composition, but as stated, shows nothing about the 16-50mm as promised in the title.  Really need a full resolution image to make any judgments about it beyond color/contrast.
I see you are also at 18mm, which will avoid most of the dark corners in the RAW
From what I have seen of the lens it is great for a wide/standard focal length of 24 or 35 or so, weaker at either end.  Definitely a travel lens where you want compact size, and maybe best if you shoot with corrected JPEGs or one of the newer cameras that will handle it okay.
Your point that composition is more important than lens performance holds true, and that for most people the performance of the 16-50mm will be fine for what they do, but the sarcastic title is misleading as the image you show doesn't have much to do with the lens.  For me, the 16-50mm interrupted my work flow too much for the cameras that I used it with.  If I bought a 6 or something I would definitely get it with that lens though.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
DFaulkner
New MemberPosts: 2
In reply to mbonsack, Jan 21, 2013
Yeah, it sure is...
-mark
Mark,
Viewed full size, there is a LOT of softness & mush on the left had side of this shot. I sold this lens for this reason.
WoodWorks
Full-size image
Wow, tough crowd.
Full-size image
David
blue_skies
Senior MemberPosts: 8,700Gear list
Re: Full-size image
WoodWorks wrote:
Wow, tough crowd.
Full-size image
Not so - you have to enable '100% viewing allowed' in your profile ...
David
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Carl Zeiss Biogon T* 2/35 ZM +31 more
viking79
Re: Full-size image
WoodWorks wrote:
Wow, tough crowd.
The title didn't help.  BTW, it is a great shot, where is that at?  I love those lonely mountain scenes.
Eric
mbonsack
In reply to DFaulkner, Jan 21, 2013
This is one of the reasons I posted.  It was simply a gorgeous day; hard to take a bad photo with an iPhone as someone previously mentioned.  But I wanted to get an idea of what the lens was capable of, and have it critiqued by those with more experience than I.  It definitely captured the tone of the day in my view, but as you say it is certainly not the end-all in resolution.  This photo was also *not* the OOC jpeg; but rather one that I tweaked myself in LR 4.3 to be pleasing.  I upped the sharpness and clarity to something reasonable but not overwhelming, and brought up the shadows, but that's about it.  So maybe the mushiness is my fault, so any PP criticisms are welcome as well.
Thanks for your comments!
-mark
WoodWorks
Re: Full-size image
In reply to blue_skies, Jan 21, 2013
Done.
--Epictetus
viking79
-mark
Also, try not to go above f/8 or so unless you need the depth of field, f/11 generally is fine too.  F/16 is bordering on decency levels, and for your shot you were at f/13 so it will show pretty severe diffraction already on APS-C, so that is part of the softness issue with this photo.
Eric
WoodWorks
Re: Full-size image
In reply to viking79, Jan 21, 2013
Sorry. Sometimes I just can't help myself, what with all the needle-nosed pixel peeping that goes on here.
The mountain is Mt. Shasta, in northern California, about an hour away from where I live in southern Oregon. There are some isolated dirt roads in the flatlands north of the mountain, and you can stumble on views like that quite easily.
David
--Epictetus
bvalenzuela
Forum MemberPosts: 56
I agree, the kit lens is just awful. I ended up returning the NEX6 with kit lens and got just the body. After getting the 50mm 1.8 (SEL50F18), it was just no comparison. I actually was dissapointed at first with the NEX6, but then realized that it was the lens. The pictures I took with the 50mm, was just super sharp, colors were vibrant, and videos just were amazing... To get the best out of the NEX6, I definately recommned getting one of the primes to see what the camera is capable. I ended up getting the 35mm 1.8 since the 50mm is a bit tight indoors, so still waiting... I am pretty sure it will deliver...
blue_skies
Re: Full-size image
It is a good pic, but I would have pulled more of the details out of it.
It also appears to be a bit back-focused, the foreground could be sharper?
JPG image sharpening should be done as last step, there are some artifacts visible at 100%.
Here is a different result:
Left: as uploaded, Right: LR processed JPG
Processed
Original
Henry
blue_skies
In reply to bvalenzuela, Jan 21, 2013
You missed the entire point of the OP, did you?
The PZ1650 kit lens is limited - JPG is better than RAW, aperture is limited, extreme focal ranges are not superior. But otherwise, it is an impressive little lens, and quite convenient.
Yes, a 50mm at f/1.8 runs circles around it, so what?
Henry
Grumpyrocker
Regular MemberPosts: 354
JPG is not better than RAW if you use the right software to correct.
It's a great little lens that's good at its job - being a neat little allrounder that lets you put the camera in your pocket.
Comparing it to a fast prime is plain silly. You may as well apples are better than oranges.
Pixel peepers may not like the 16-50mm, but then they tend not to be a very happy bunch at all.
bvalenzuela
Henry
I didn't miss the point, as if you go back to the OP, all he put was a picture to speak for itself (I got similare results). In any case, I never said that I am expecting Prime results from a kit lens, I am totally aware; however, the type of images that I was getting (totally not sharp, mushy, colors flat), was not worth not even the $150 they charge for the kit, for me that is... I understand some folks will be happy with sup par images. All I am saying is that if a beginner that don't know much about lenses and quality, will automatically think that they are not getting great images from this camera and knock the camera down right away... My iphone pictures are sharper than the kit lens for crying out loud or maybe i just got a defective one... Either case, I will use my feet to zoom and get quality images that this camera can produce...
dpyy
Contributing MemberPosts: 885
It really is awful though because every raw you take needs to be heavily corrected. Just feels wrong, sticking with my z24/e50.
WoodWorks
That's what I enjoy so much about this forum. I mean, someone here might actually believe that you're being serious, and it will start a 150-post conflagration about it.
I enjoy shooting with my iPhone too, but sheesh...
I would have enjoyed seeing you zoom with your feet past the barbed wire fence and No Trespassing signs that were between me and the subject in the photo. The rancher that owns the land probably would have a thing or two to say about that.
David
--Epictetus
WoodWorks
Re: Full-size image
Thanks Henry. Mine was just a quickie development in Lightroom, as I was pleased enough with what the lens delivered. But you're right, there's certainly more to extract from it, had I been in the mood.
Of course, these things are a matter of taste (and intention). I find your development of the shack a little bit too far towards the HDR look for my taste, for instance. But I'm sure there are plenty of viewers who will prefer yours.
As Mao said: Let a hundred flowers bloom!
David
--Epictetus
