GH-3 Viewfinder "issue" - product of clueless
Triggr Happy
Regular MemberPosts: 321
5 months ago
Finally got my camera and first thing I did is check for viewfinder "issue" that some people claim exists.
I immediately realized that there is zero issue. Image in viewfinder is perfect, no smearing at all. People who see smearing don't understand basic optics.
If you move your eye off the center you get double vision, not smearing, because the edge of the viewfinder window frame gets in the way of image in the viewfinder. Image in the viewfinder is focused in your eye but the edge of the viewfinder frame which is closer to your eye is not in focus.
So the image looks out of focus on the sides or in the corners.
How do those people take pictures?
bluelemmy
Regular MemberPosts: 438
Re: GH-3 Viewfinder "issue" - product of clueless
In reply to Triggr Happy, 5 months ago
I hadn't bothered to mention it here but my experience is exactly the same as yours. It's a non-issue. It isn't smearing at all.
David
www.dthorpe.net
jim stirling
Veteran MemberPosts: 5,213
I have no issues with either of my GH3 bodies and find the view through both perfectly clear. However this does not mean that through a quirk of vision or technique that  others have a very real issue. Obviously as with all mass produced items it is possible that there will be a certain percentage of cameras that are faulty. I agree that for many people the camera is not the issue per se but is down to their particular viewing method , and many will probably adapt to using the viewfinder without any problems.
Jim
Edited 5 months ago by jim stirling
TheEye
Senior MemberPosts: 2,848
Sounds like a small exit pupil
Long eye relief and a large exit pupil are apparently too much to ask for in a modern camera. That's probably because the eyepiece would be comparatively large, and because most consumers have either forgotten what a good viewfinder is, or because they never looked through one in the first place anyway.
http://www.flickriver.com/photos/photography-by-thomas/
jim stirling
Re: Sounds like a small exit pupil
In reply to TheEye, 5 months ago
My main cameras have been FF Nikon for several years and I am we'll used to a large viewfinder. I think it is mainly a matter of technique , even with the best binoculars or microscopes some people have a problem lining up their eyes.
JIm
Aleo Veuliah
Forum ProPosts: 13,769
The GH3 I have tested also have no issues on the EVF. But I use contact lenses and I have 99% of vision.
Simplicity is the ultimate sophistication.
God always take the simplest way.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
Aleo Veuliah
I agree.
Aleo Photo Site
clengman
Senior MemberPosts: 1,198
I don't have this camera, but I have read about this blurring issue. I also have vf-3 that I use on my e-pl1. I can attest that my evf is very sensitive to eye placement. If my eye is off center at all the vf appears to be very blurry.
I'm also very accustomed to using various oculars (Another hobby of mine is backyard astronomical observation, and my trade is biology research. I use a binocular microscope every day.) I can tell you with certainty that the issue I notice has nothing to do with eye relief or the size of the exit pupil (i.e. no "blacking out") or the physical edge of the vf impinging on my field of view. It seems to be completely a result of optical misalignment of eye, vf lens and vf display. It just looks blurry unless I look precisely down the center of the tube.
I can't tell you that I know this is the "issue" with the GH-3 since I've never seen the camera in person, but since I have witnessed a similar phenomenon firsthand, I can certainly believe these accounts. I agree though that if you're careful with eye placement it's not too much of an issue. It is annoying to me though that I have to be so careful about eye placement. I've used telescopes with very, very small exit pupils (very high magnification) that were less finicky to use than the vf-3.
sea_dragon
Regular MemberPosts: 328
Hmmm... a bit arrogant calling those having issues clueless. But, I'm glad that YOUR camera is fine.
Anyway, I can tell you that on MY camera, it is NOT the edge of the viewfinder window causing the issue. It is the magnifier glass (or plastic) that has an extremely narrow sweet spot. The image distorts off center BEFORE the edge of the viewfinder even comes into play. Plus it isn't just "doubled". The "smearing" looks like multiple edges on things like the text overlay.
As I've just learned from TheEye's post above, it's called a small exit pupil. As a result, I believe that people with certain vision or eye characteristics have a problem. Me being one of them. I've pretty much accepted the fact that when wearing glasses, I will never see a nice sharp image from edge to edge because I can't get my eye close enough to the viewfinder.
If the exit pupil was larger, I would probably have no problem.
Oh, and I take pictures just fine thank you.
Edited 5 months ago by sea_dragon
brianf
Senior MemberPosts: 1,222
Re:I may be "slightly Clueless" :-)
I have three Panasonic EVF's, a GH2 a GX1 with VF2 and the GH3, the GH2 and VF2 are quite tolerant of where my eye is and are clear the gh3 is only clear if I have my eye close and centered in the EVF.
Probably normal for a GH3 but not as tolerant of my eye position as the others two, mine is also colour blind, it can't display purple/violet but that is another issue.
Cheers.
Slightly clueless Brian
Possibly lucky, not and as clever as you
Edited 5 months ago by brianf
Triggr Happy
In reply to sea_dragon, 5 months ago
Maybe be arrogant, but not any more arrogant than those people posting about the "issue". When you start a thread with heading like "My camera has major problem", that's a bit arrogant too, isn't it?
sea_dragon
Not if your camera does have a major problem.  Now saying "All GH3s have a major problem" is a bit arrogant for sure.
Personally, I've only ever posted about either MY camera or ones that I've looked at in person.
Sean Nelson
Veteran MemberPosts: 7,341
Sea_dragon is exactly right - it's perfectly reasonable to have an issue with your own camera, or to post some particular opinion as your own.
You become arrogant when you start inferring that other people's experiences or opinions are somehow wrong.
mpgxsvcd
Veteran MemberPosts: 7,213
As far as I have seen no one has claimed that the EVF has a problem with anything but off center. The issue is that off center is barely off center. It creates the smearing/double image if your eye moves at all.
Is this something we are all imagining?
http://www.youtube.com/watch?v=aqteueoRRf4
GH3, Hacked GH2, and Full Spectrum GF1 Sample movies
http://www.youtube.com/user/mpgxsvcd#play/uploads
GH3 Tips and Tricks
http://www.youtube.com/watch?v=hIMdxoGbNXU
GH2 Setup Walk through
http://www.youtube.com/watch?v=uROQbbiiO2I
http://vimeo.com/user442745
GH3, GH2, GF1 Pictures
http://www.dpreview.com/galleries/4222674355/albums
Big Ga
Forum ProPosts: 15,242
In reply to clengman, 5 months ago
A sensible reply.
What I find most fascinating with issues like this, is how they often do exist, but many people are unable to detect them by themselves.
Sure, sometimes there are differences between different units, so one can be defective, and another one isn't. But I've far too often seen constant design flaws or irregularities be blatantly obvious to some people, but be totally missed by others. Its just so strange.
Marco Cinnirella
Veteran MemberPosts: 3,627
Very arrogant OP - I experience this blur issue with my GH3 yet have no problems at all with these EVFs:- G5, GH1, LVF-2, VF-2, Sony a57.
Please explain this?
congrats that you have no problems but why paint anyone who does as an idiot?
Francis Carver
Senior MemberPosts: 1,021
Connecting external EVFs & LCD/OLED Monitors to GH3 via HDMI
sea_dragon wrote:
Hmmm... a bit arrogant calling those having issues 'clueless.'
Couldn't agree with you more.
If the exit pupil was larger, I would probably have no problem. Oh, and I take pictures just fine thank you.
Makes perfect sense to me. Also, I understand you can always interface with the GH3 a high-end external electronic VF or a high-end LCD or OLED screen, such as something like this:
http://www.smallhd.com/products/dp7-pro/dp7-pro.html
No GH3 EVF issues that way, for sure.
I am so used to optical VFs in still and film cameras, and in the film cameras an OVF is actually WORKING even when you are recording filmed sequences with the camera. Not so with DSLRs, of course. I could never warm up to the tiny EVFs in digital cameras, but I love the LCD screens with the LCD VF loupes, and of course for the better cameras that fact that you can connect external high-end quality EVFs and LCD/OLED monitors to it for critical framing and particularly focusing.
94
94
Contributing MemberPosts: 612
In reply to Aleo Veuliah, 5 months ago
I agree.
Aleo Photo Site
And I agree. It's something that any experienced user of rifle scopes should recognize. The right distance from the view and correct alignment of the eye's pupil with the optical center of the exit view and you get the best the optic can offer. Anything else will appear, small, distorted, or smeared if either the eye or the subject is moving.
Just adjust the diopter to your eye's focal ability and look through the center and fullest frame. Keep that alignment regardless whether the subject is moving or still. It becomes habitual pretty quickly most of the time if there are no bad habits to overcome.
Francis Carver
Laws of optics for using an EVF
In reply to 94, 5 months ago
Pretty weird and off-putting that one has to adhere to the LAWS OF OPTICS when using an ELECTRONIC VIEWFINDER.
If you are doing hectic paced shooting, particularly fast paced video shooting, your eye may slide left/right/up/down by 1/10th of an inch easily from the perfect central axis of the EVF -- what then?
Personally, I am fan now of using LCD VF loupes on the LCD screen and leave the EVF the heck alone. The GH3's EVF is at least of a very nice size, but there are others that are only 0.2-inch diagonal -- who are those intended for, I wonder -- squirrels?
Connecting an external high-end EVF or LCD/OLED screen to the camera via HDMI is another option, but then you need to juice-up that external device with another battery.
IrishhAndy
Contributing MemberPosts: 868
You can't get double vidion with onr eye
A solution looking for a problem !
