Pixma Pro 100 prints are too dark
Started Jan 18, 2013 | Questions
penns Junior Member • Posts: 38
Re: Pixma Pro 100 prints are too dark
Hugowolf wrote:
penns wrote:
Hugowolf wrote:
penns wrote:
I would rather leave the color management on auto and not have to mess with this.  On auto, I just print it from here.  With manual, I click ok and then print.  What else do you need to know?  I haven't changed another settings that I know of.
Since Auto seems to be causing problems, I would suggest trying to get the printer to use the correct paper/printer profile.
In the Main tab of the printer properties dialog:
Select the media type for the Canon paper you are using.
Select a print quality of high or standard
Under color/intensity, choose Manual
Then press the Set button
There are two tabs in this dialog, everything in the Color Adjustment tab should be set to zero or normal.
On the Matching tab:
From the Color Correction dropdown, choose ICM
For the Input Profile, choose Standard
For the Printer Profile, choose the one that matches your Canon paper
For the Rendering Intent, choose Relative Colorimetric
OK out of everything until you get back to where you have a print button. You should now be ready to print.
Brian A
Ok tried that.  Still purple.
The bottles look quite purple on my calibrated monitor. How about the Tree shot sky?
Brian A
Thanks for all your help.  I've decided to give up.  I called my credit card this afternoon.  My extended return policy is up on Tuesday so I needed to decide.  Thanks again.
klavrack wrote:
Just an update--my new-in-box i960 is doing great.  Just finished 1st tank of BCI-6 Photo Magenta.  I replaced it with a CLI-8PM tank--still spot-on color and I get a fairly economical option with better fade resistance.  Shame on Canon for phasing such printers out, IMO.  Last time I looked, a new-in-box i9900 was listed on Ebay for $1500.  Still, lots of happy PRO-100 owners out there.  Any word on yours?
I got mine back and it's still doing the same thing.  Maybe it's just the way this one prints.  I called the credit card that I bought it with and they give extended return privileges.  I'll be sending it to them for a refund.  I'm not sure where to go from here, but I will print a few with the old Hp for now.  I was told to get an Epson.  Maybe I'll look there.  Although I'm sorry you had the same problem, I'm glad it wasn't just me.  Thanks for speaking up.
Petruska Veteran Member • Posts: 7,493
The bottles are PURPLE....
as viewed on my claibrated monitor, and it prints purple on both my Epson R3000 and Canon PRO9000 MK II printers.
What Brian, Joe and myself are trying to tell you, is that there is nothing wrong with your printer!  Unfortunately it is you, your settings and the application that you use are not correct for your goal.  You can buy an Epson, HP, or another Canon printer and it will still print that photo purple, which is correct.
You need....
1.  A good monitor, and calibration hardware/software.
2.  Use a good photo editing/printing application, such as, Photoshop, Lightroom, Photoshop Elements, etc. and learn to make the correct settings.
3.  Only use OEM inks, and if going 3rd party inks then you need to go to the next level and generate your own custom ICC printer profiles using a ColorMunki Photo, etc. which is probably beyond your knowledge at this point.
Good luck!
Bob P.
Bob P.
jtoolman
jtoolman Veteran Member • Posts: 5,510
Brian A
Brian A
I'm not sure which tree shot?  Are you getting me confused with someone else?  I have been working with these bottles and a shot of some rooftops in Venice.
By the way your bottles also look purplish on my Hardware calibrated monitor as well.
Have you considered that you monitor may be displaying you image incorrectly? So when the printer prints it the way it actually is, it looks off?
Have you tried printing a standard image file without editing it. These files are intended to bypass the monitor's calibration. The image file will have a composite of different images and a black to white ramp as well as RGB and CMY patches which will be very easy to visually determine if the printer is printing correctly. If one of these images prints perfectly but does not look correct on your monitor, them you will know that it's you monitor that needs calibration.
Here is a particularly good one that I use.
Print it using only standard settings. Do not use any slider adjustments. Neutralize everything. Just use the settings you were given a few posts ago. Then look at it in Daylight. Look for the color on the black to white ramp where it should be neutral. The photos should appear "Right" not too light not too dark and the colors should appear natural with no shift in either direction.
Unless you printer is not printing correctly, this print should be excellent.
Joe
I printed Canon's stock photo for them.  It was dark/purple.  I've decided to give up and will be trying something different.  My credit can gives me extended return privileges for 90 days and I called them this afternoon.   The 90 days is up on Tuesday so I had to decide.  I appreciate everyone's help on this.  I am very disappointed, because this printer seemed to be just what I was looking for.  Not sure what I'll buy, but I'm looking at Epson.  Thanks again
Unless you get your monitor properly calibrated so the files, which as you have stated, are being printed directly from the camera's card, will be displayed in their correct color, an Epson or any other printer is not going to solve your problem.
Imagine a fever thermometer that is consistantly off by two degrees on the cold side. You could have a slight fever and be told that you are 98.6 by the uncalibrated thermometer.
Any viewing instrument that is being used as a standard, which in this case, the standard by which you are judging your images is your uncalibrated monitor, has to be trusted as showing your image correctly. Regardless of the fact that your HP printer seems to print your mages the way your monitor is displaying them does not mean that that everything is fine. It means that by total luck your HP printing is also printing off color. It's just that it happens that it is adding the oposite color shift and it is by cooincidence printing a print that matches your uncalibrated monitor.
On your monitor, your bottles are looking more toward cyan but correctly printing as purple, right? But on all of our monitors ( calibrated ) your bottles image are looking purple. Even my laptop screen shows them as purple. So since several of us see your bottles as being purple, chances are they are indeed purple.
I know it is a dificult concept to grasp and believe me, I went through a year or too, strugling, with my printing. But now I can pretty much print with my eyes closed and be assured that I get accurate color and density from any of my 15 Canon and Epson printers. It's all about your workflow.
Joe
Brian A
Brian A
Joe
Joe
Even on my monitor the bottles are not cyan.  I would call them a deep blue with a bit of purple.  It may be that my monitor is off a bit.  I understand that.  But when I printed the stock Canon photo and one of my own and mailed them to Canon, Canon agreed that the printer they had at their location was printing them different than mine.  Also I know what color the bottles and the sky was when the pictures were taken.  I have a hard time believing that neither the Nikon D700 and the Canon sx10IS could capture it correctly. I cannot afford calibration hardware at this time, so I will just have to see if the next printer I try will work better.  In the meantime, my Hp hasn't died yet and actually I don't have a backlog of pictures waiting to be printed.  I have time to look into all the possibilities.  Like I said, I appreciate your help and if I find a way to calibrate my monitor I will do it.
lot Forum Member • Posts: 61
Brian A
You suggest choosing ICM. I have been using the None setting. If you don't mind sharing, why ICM?
Hugowolf Forum Pro • Posts: 12,530
Brian A
You would choose none, if you want the software (Photoshop, Lightroom, Aperture, etc) to manage the color. You would select ICM (image color management) to have the driver mange color via the OS's CMM (color management module) using a selected ICC (international color consortium) profile.
Brian A
I bought an Epson 1430.  It is printing the pictures very close to what I expected with no adjustments.  They are very different that the prints from the Canon.  I was told in the beginning I should get an Epson.  I guess I should have listened.
PhotographerMelissa New Member • Posts: 1
HI - I have a Canon Pixma Pro 100 as well. I also have a colormunki but regardless I still cant figure out why my images are printing out darker than what I see on the screen. I have Photoshop manages colors, but no matter how much I try and rework everything, it still has the same results. I know about the ICC profiles and whatnot, but I'm just not sure what all my settings need to be in order to have them working right. I did have them great at one point, but something happened and now its not cooperating with me. lol
SC489 Regular Member • Posts: 232
I worked out how to get a good match with my Pixma Pro 100 a few months ago - see http://www.dpreview.com/forums/thread/3782841?page=1
In summary, my set-up is:
Camera: Lumix GX7 shooting RAW with Adobe RGB colour space
Monitor: Viewsonic VP2770 calibrated to 90Cd/m2 & 5000K using a Spyder 4 Pro colorimeter
RAW Development: DXO Optics Pro 10 with export in TIFF format to Lightroom for printing. I find Lightroom has superior print layout functionality and it supports soft proofing. I may start using Lightroom for routine RAW development, leaving DXO Optics Pro for for specific photos where I need the lens correction functionality and noise reduction.
Printer Driver: Canon Pixma Pro 100 XPS driver using Windows 8.1 Pro x64. I've stored profiles for my common papers and sizes.
Print Settings: I view the photo using soft proofing in Lightroom with Simulate Paper & Ink turned on - I generally create a soft proof. Select the paper ICC profile in Lightroom, none in the printer driver, printer resolution 300 ppi. I generally use relative colorimetric matching, sometimes perceptual depending on the image. The Print Studio Pro plug-in is easy to use but there are no options to set the print area precisely. However, it supports 16 bit printing (but can you tell the difference?).
Paper: I've tried Canon Pro Platinum, Pro Lustre and Permajet Oyster to date - all with excellent results and matching. I have a specific Oyster profile for my printer which is free if you use Permajet paper. You send Permajet a printed colour profile chart and they email the profile for your specific printer.
Viewing Light: This turned out to be quite important. I'm using a desk lamp fitted with a 5000K 4W GU10 LED - this one http://www.lyonlighting.com/cgi-bin/sh000001.pl?WD=420cobcool&PN=Ebrite-Definded-Beam-GU10-LED-5W-45W-Cool-White-5-000K-Lamp-420COBCOOL%2ehtml#SID=129 . This provides a similar colour temperature to the monitor at the correct illumination level when viewed from several feet.
No doubt there will be many other opinions on this Forum but the above works for me.
 SC489's gear list:SC489's gear list
Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic 20mm F1.7 II +3 more
jtoolman
Recalibrate your monitor ans set it to 80Cd/m2 ( Use the advance setting ) then create a profile for you PRO-100 and the paper you use.
Assuming you are setting everything up correctly, turning of Color Matching in the printer driver, and using am ICC within your Editing APP you should get a print that will be CLOSE. It will NEVER match. You are comparing two drastically different system. A backlit Monitor and a front lit print. You would have to evaluate your print under as bright a light as you see in a gallery. Normal room light is not bright enough.
Go to my video channel ( Link below ) and take a lot at my specific PRO-100 videos. All will be explained.
You can also use the CANON Print Studio Pro plugin if you use PS or LR.
Joe
MY VIDEO CHANNEL. PRINTING and personal videos.
https://www.youtube.com/watch?v=uJj_wpgqs9s&list=PLy-ZTSBwqckaCIdkls-n-6IN4ogCE5FxH
Google Plus:https://plus.google.com/115622597218038655375/posts
Micromachining and Miniature Cabinetmaking channel
JTOOLMAN1949 https://www.youtube.com/channel/UCFPD5beoll9TvvW2u_dR0hQ
