X-Pro1 JPEG vs RAW
Chris Dodkin
Veteran MemberPosts: 4,212
X-Pro1 JPEG vs RAW
4 months ago
There has been a lot of discussion recently because of the CaptureOne release, around in-camera JPEG vs various RAW conversions.
I did the following tests with all 3 prime lenses back in the summer - comparing out of camera JPEG from the X-Pro1, with files converted from RAW using ACR into Photoshop CS6. The JPEGs were with the default camera settings for sharpness etc - seeing as default seems to be the theme of the day.
The results are as I'd expected, but do go against some people's preconceptions around the 'ultimate' quality of the Fuji JPEG files
All of these are 100% crops
18mm Lens - Top JPEG - Bottom RAW
35mm Lens - Top JPEG - Bottom RAW
60mm Lens - Left JPEG - Right RAW
Pictures are worth a thousand words etc - clearly if you're thinking that RAW and especially RAW via Adobe is in some way inferior to Fuji JPEG, these may give you pause for thought.
I'll just add that I did not use the default settings in ACR in order to get max IQ out of the RAW files.
Link to the image set on Flickr here: http://www.flickr.com/photos/dodkin/sets/72157630330887924/
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
Cadder
Senior MemberPosts: 1,064
Re: X-Pro1 JPEG vs RAW
In reply to Chris Dodkin, 4 months ago
Thanks,
That helps me with the probable purchase of an X-Pro1
Cadder
Asylum Photo
Contributing MemberPosts: 782
Oddly enough, I prefer the jpeg in all three samples. BUT, that's the beauty of choice.
http://asylum-photo.com
rich789
Forum MemberPosts: 86
In reply to Asylum Photo, 4 months ago
+1
Unless its my uneducated eye, the only difference I can see is that the raw has had a slight exposure lift relative to the Jpeg.
Zardoz
Senior MemberPosts: 1,109
None of this makes the well documented problems with Adobe's RAF conversion go away, unfortunately.
David McGaughey
Senior MemberPosts: 2,075
JPEGs are less sharpened than the RAWs
I brought the 35mm and 60mm shots into Photoshop and added some "smart sharpen" to just the JPEGs.....they sharpen up nicely and look as crisp as the RAWs. The RAWs can't take any more sharpening without getting weird looking.
http://www.dmcgaughey.com
http://frameandfire.tumblr.com/
vkphoto
Contributing MemberPosts: 679
looks odd
Chris, are you sure that you didn't mixed up labels (jpeg/raw, top/bottom, /left/right)???
http://vkphotoblog.blogspot.ca/
http://www.flickr.com/photos/vk-photo/
Chris Dodkin
Re: looks odd
In reply to vkphoto, 4 months ago
LOL - yep, I'm sure
I should have taken the time to match the RAW to the JPEG regarding color saturation and WB, to make the comparison on detail the key differentiator.
As presented, the 'film' sim in camera has a more saturated look - but the processed RAW files can provide higher levels of detail, as well as more manageable WB, dynamic range, highlight recovery, shadow detail etc etc
You can adjust WB and saturation to match the JPEGs look - and adjust to taste.
Chris@1D-Images.com
Chris Dodkin
Re: JPEGs are less sharpened than the RAWs
In reply to David McGaughey, 4 months ago
The JPEGs are using the default in-camera JPEG sharpening - no adjustments or PP have been applied.
You can of course adjust sharpening to taste on both JPEG and processed RAW - doing sharpening during RAW conversion will generally provide a higher quality of sharpened output that sharpening a JPEG.
Chris@1D-Images.com
Chris Dodkin
I prefer the saturation in the JPEG, and the detail in the converted RAW
You can of course adjust the saturation and WB in the converted RAW to match the JPEG - I just didn't do this in this case.
Perhaps I should have.
Chris@1D-Images.com
Chris Dodkin
In reply to rich789, 4 months ago
+1
If you look at the blue siding for example, in the 18mm shot - there is more detail in the processed RAW than the JPEG.
In the 35mm shot - there is more detail in the palm tree in the RAW than the JPEG.
In the 60mm shot - there is crisper detail in the railing
The exposure and color/WB is all adjustable in RAW PP - I didn't spend time trying to 'match' the JPEG 'film' look
Chris@1D-Images.com
Ryan Williams
Contributing MemberPosts: 589
Re: looks odd
I think at this point most X-Trans owners are aware of ACR's limitations. Detail isn't really the big issue, it's colour smearing that's the real problem — something no amount of sharpening or fine-tuning can fix.
In your example photos I could tell which were the ACR shots without even looking at the labels, because the colour smearing is apparent in many places if you know what you're looking for (areas where there're highly-contrasting bold tones, such as green next to white or blue next to red).
Not that I'm saying this is a huge deal, but the limitations are clear and known to most.
Chris Dodkin
Re: looks odd
In reply to Ryan Williams, 4 months ago
Given that we're looking here at a 100% crop, so we're seeing the smallest of details - I'd say that the JPEG in #1 (the 18mm shot) shows more color bleed from the red area on the left of frame, than the processed RAW file does.
Same with the deep blue sign against the green building on the left of frame.
So I'd be 180 degrees from your statement, based on the evidence in front of me.
The JPEG appears to have more color smear than the processed RAW file.
Chris@1D-Images.com
Randy Benter
Contributing MemberPosts: 593
Chris,
Could you please process the tram picture from the DPR examples:
http://www.dpreview.com/articles/1887029702/capture-one-fujifilm-x-trans-raw-support-tested
Can you process this in LR and eliminate the color bleeding in the street sign. Please share your settings if you can. Thanks.
marbla
New MemberPosts: 5
In reply to Randy Benter, 4 months ago
Randy Benter wrote:
Chris,
Here is a simple conversion in C1 with some small tweaks made.
http://www.flickr.com/photos/marbla/8389709656/in/photostream
Do realize that most of the foliage is out of focus though so I don't know how much benefit pixel peeping does.
Ryan Williams
In reply to marbla, 4 months ago
marbla wrote:
Randy Benter wrote:
Chris,
marbla, this thread is about Lightroom/Adobe Camera RAW. Note that the poster you quoted specifically asked to see this done in Lightroom (LR).
marbla
New MemberPosts: 5
Sorry about that... I guess I somehow thought RAW in general but I guess I read past that part.
I gave it a shot in lightroom but I don't really see how to remove the color bleeding unless maybe by pushing clarity though that is not doing anything to remove the problem.
Edited 4 months ago by marbla
Chris Dodkin
Did you mean this one Randy?
I don't have LR though, but I use ACR into CS6 as previously stated.
This is the DPR RAW file in ACR at 100% zoom - screen grab, saved as a JPEG.
I've taken dozens, maybe hundreds, of images that include signage - and never seen one as bad as that DPR sample - I have no idea what's going on there as I didn't take the original shot.
It's not been an issue for me personally in the last 9 mths - but given that it cropped up rarely, as on the streetcar shot from DPR, it's easy enough to address if this was an image you needed to process to full print resolution.
Other signage shots I've gone through show no issue - so again, if we're talking rate of occurrence and how this impacts the use of the camera, it's been no issue for me.
Just to get a flavor.
Chris@1D-Images.com
framus
Contributing MemberPosts: 836
Chris,
Thanks for the great examples.
I've done similar testing but attempting tomatch the OOC jpeg file with the raw file converted in LR4.3 and printed on B3 paper with an Epson 3800. The jpegs are quite good by my criteria. The raws are better in regards to detail and the range of shadow and hightlght detail.  The heinous WC effect in LR raw conversions is discernible in my tests when the files are viewed at 200% on screen. In the B3 prints this WC effect is not discernible to the my naked old eyes.
The  'well documented issues' with ACR & LR X-trans raw conversions are not universally interpreted. Some are alarmed, others not so much.  My tests and your well illustrated examples have me in the 'not so much' camp.
Having said all this, I continue to entertain fond hopes that Adobe will improve their demosaicing routines for the X-trans raw files.
-Framus
vkphoto
Re: Did you mean this one Randy?
Same image, different results. What am I doing wrong?
