Macro question....
Started Jan 16, 2013 | Questions
vishal540
Junior MemberPosts: 34Gear list
Macro question....
Jan 16, 2013
Hi everybody,
I am new to JJM. Well I have a question to ask regarding macro photography. I have D5200 and 60mm F2.8G ED lens. I don't know why I am not able to get close to my subject. People say in dedicated macro lens you don't need any extra things like a closeup filter and neither extension tubes.. then why I am not able to get too close ... Am I doing anything wrong here.???
 vishal540's gear list:vishal540's gear list
Nikon D5200 Nikon AF-S Micro-Nikkor 60mm f/2.8G ED
Nikon D5200
bgD300
Veteran MemberPosts: 4,552Gear list
Re: Macro question....
In reply to vishal540, Jan 16, 2013
The 60mm f2.8G should get you to 1:1 magnification without any additional equipment.
What are you trying to shoot?  There are a number of alternatives ranging from simple reversing mounts to apochromat lenses to extension tubes and bellows.
My photo blog: http://birdsnbugs.wordpress.com
My camera club porfolio: http://www.pacameraclub.com/bgrant.htm
RF Stock Portfolio - http://www.dreamstime.com/resp129611
EXIF is embedded in photos WSSA #51 as bg5700
 bgD300's gear list:bgD300's gear list
Nikon Coolpix P7100 Nikon D90 Nikon D300 Nikon 1 V1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +16 more
vishal540
In reply to bgD300, Jan 16, 2013
Hi bgD300,
I am uploading an image of a spider in original JPEG file without crop.. Let me tell you that the image uploaded is the closest my lens let me do in manual mode... Image was taken at ISO 100, Aperture 3.8, shutter speed 200sec. and using external flash..........I just wanna know how other people fill the entire frame.. Do I have to use extension tube, bellows etc..???
Thanks...
bgD300
It's hard to tell without knowing the size of the spider.  One way to see how close you can get is to set the lens to minimum focus distance in manual mode and then move in and out over a newspaper.  You will be able to tell how close you can get when you see the type come in to focus.
Another thing to do is to continually work on technique until you get the image really, really sharp.  This will then allow you to crop your image to create an apparent increase in magnification.
A bee at less than 1:1
The same Bee butt from the picture above.  Inverted.
This was taken with the 105mm but, my 60mm is equally sharp.
I always use at least a monopod when shooting macros to minimize camera movement.  I sometimes need to use a clamp to minimize subject movement.
mbernard
Senior MemberPosts: 1,080
vishal540 wrote:
Hi bgD300,
Thanks...
You were too far away from the spider. To get 1:1 size of the subject with the 60/2.8 G, you need to be as close as ca 5 cm from the subject, measuring from the lens edge. If the subject is still too small you can use extension tubes but this is not very practical with this lens. For shooting insects, spiders etc., a longer macro lens (at least 100 mm) is greatly preferred.
j2l3m7
Senior MemberPosts: 4,044Gear list
I see you are continually work on technique until you get the image really, really sharp.  Nice photos and technique.  Thanks for posting.
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
vishal540
In reply to j2l3m7, Jan 16, 2013
bgD300,
I know that my lens does not need any kind of extension tubes or closeup filter but after reading your post I felt I am really doing something wrong.. I will now first try to get sharp images and then will get back to you if nothing works out..
Thanks a lot for your advice..
bgD300
Does the G mount lens have a range limit?  I have the f2.8D and it has a limit switch for the AF so that it doesn't hunt the full range when it isn't necessary.  It can be seen here on the left side of the lens in the center.
T Evergreen
Forum MemberPosts: 63
For starters, set the lens and camera on manual focus.  Then turn the focus ring on the lens to the closest focus point the lens will allow.  Turn on the live view mode of the camera.  Put a coin or other small object on the table, and then place the front of the lens about 3 inches/75mm from the coin.  Then move the camera slowly toward and then away from the coin until the coin is in focus.  You should have 1:1 reproduction at that point.
The depth of field is very shallow when focusing this close.  Also, the camera's built-in flash will be no use because you are so close to the object being photographed.
_sem_
Veteran MemberPosts: 4,682
In reply to vishal540, Jan 17, 2013
The max 1:1 magnification means 24mm along the long side of the frame on a DX camera. I don't know how big this spider is, but images of enlarged insects are often made at 3:1 or more. Canon has a dedicated lens MP-E 65mm for this. Your lens can be used if you reverse it on top of macro bellows or a couple of sets of extension tubes. Wide-angle lenses (including kit lenses for the start) produce such magnification reversed without additional extension or with a shorter one. But the technique is a bit involved; DoF is thin, light is scarce, so you need to work either on tripod or with flash; everything is manual including aperture; you need some specific gear. But all you need may be googled up on this forum.
