imac and lightroom 4 problem - how is aperture - thoughts
Started Jan 16, 2013 | Discussions
lou Capeloto Contributing Member • Posts: 663
Hi
I am currently using an Imac and lightroom 4 consistently seems to hang up
Also have Mountain lion
very frustrating
Have Nik plugin which works fine and photoshop
have followed the various threads regarding optimizing lightroom 4 and have followed them still problem
My question is if anyone has both and will I experience less hangup problems with aperture
Any ideas or suggestions would be appreciated
Lc
www.corot.smugmug.com
 lou Capeloto's gear list:lou Capeloto's gear list
Fujifilm X-E1 Fujifilm X-M1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F2 R WR
webfrasse Veteran Member • Posts: 3,858
Re: imac and lightroom 4 problem - how is aperture - thoughts
lou Capeloto wrote:
Hi
very frustrating
Lc
What kind of Mac? Amount of Ram? Disk? My Car doesn't start, why?
Mikael
lou Capeloto OP Contributing Member • Posts: 663
sorry to hear about your car
Anyhow, the computer is an IMac
OSX 10.8.2
Processor 3.06 GH2 Intel Core 2 Duo
Memory 4gb
1067 Mh2 DDR 3
Hope this helps
LC
Jen Yates Senior Member • Posts: 1,413
lou Capeloto wrote:
Memory 4gb
Use Activity Monitor to see how much RAM you're using. 4GB isn't a great deal these days and I find my 16GB machine will normally use between 8GB and 12GB depending on what apps I have running.
As I'm sure Activity Monitor will show you using all of your 4GB of RAM then I would certainly look at adding some more RAM no matter what software you use.
But if LR is actually locking up (Crashing?) I'd look at plugins.
Thank you Jen
I did and it is using right now with what I have open 2.95 Ram
OSX 10.8.2
Memory 4gb
1067 Mh2 DDR 3
Hope this helps
LC
I would say that 4GB is a minimum today for most work with LR or AP. Memory is cheap today so I would would invest in 8GB which I think is ok in your iMac.
I would also run Disk Utility to do a Repair Permissions. That sometimes removes issues like this.
Mikael
hisoy86 Regular Member • Posts: 137
I run an old 24"iMac 2.93 Core 2 Duo with OSX10.8.2 and LR, but I have 8 gb memory.  No problems.  I also have and use Aperture.  Both programs use about the same amount of resources.  I would think that putting in 8 gb (about $60US) from OWC would improve performance a lot, but I don't think Aperture would run much better on 4gb.
As others have suggested, check your disk permissions using disk utility to see if that might be a problem.
Tom
 hisoy86's gear list:hisoy86's gear list
Canon EOS 70D Sony a6000 Olympus E-M5 II Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Canon EF 70-200mm f/4L IS USM +9 more
bohdanz Regular Member • Posts: 208
I've used Aperture for a few years but thought I'd make the switch to Lightroom when I got it as part of my Adobe Production Premium that include Lightroom and Photoshop.
After watching hours of tutorials from Adobe, Scott Kelby, and Lynda.com, I'm about to move back to Aperture.  As soon as possible, in fact.
Here's what I hate about Lightroom.
  • It's got so many pieces that nothing is a quick, fast, anything.
  • Adobe Lightroom has horrible integration with social media.  I've purchased add ons from developers and getting photos into a Facebook wall, for example, can't happen according to Jeffrey Friedl because Facebook hasn't released an API.  Really?  Aperture's integration to Facebook is seamless.
  • I've probably spent about thirty dollars in add-ons for Facebook, Picasa, etc and it's always multiple steps to get things done.
  • Even more trying is how to open up images in different apps.  In Lightroom I can set up one app - so I choose Photoshop.  But I've got onOne Software Perfect Photo Suite, Topaz, Nik Software, Pixelmator.  Getting an image to open seamlessly in those apps is yet another multi-step effort.
Because there's such a big sell by Adobe gurus like Scott Kelby on the virtues of Lightroom, you're led to believe it's an amazing app.
It's not.
If Apple only had a great instructor like Adobe digital imaging evangelist Julianne Kost -- she's an amazing instructor with the best tutorials -- the world would switch to Aperture.
Bohdan
HI
Thanks all
Followed everyones suggestion and the key finally was upgrading ram for 4gb to 8gb --
jbagg Regular Member • Posts: 232
It's not.
Bohdan
You might try ApertureExpert. He's the closest the Aperture community has to an evangelist.
http://www.apertureexpert.com/
sean lancaster
sean lancaster Veteran Member • Posts: 6,758
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony Alpha 7R II Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 +4 more
