Just about right
Started Jan 13, 2013 | Discussions
Craig from Nevada
Craig from Nevada Senior Member • Posts: 1,512
Just about right
I recently purchased a 35-100mm lens and have it mounted on an E-30 with a battery grip. I take it everywhere and have been having a lot of fun with it, but it is big and heavy.
This morning I mounted my 50-200mm on my E-620 with a battery grip.  Not like the beast described above and not too small like an E-PL2.  It is just about right in terms of size and weight. Hint, Hint Olympus....
 Craig from Nevada's gear list:Craig from Nevada's gear list
Olympus Tough TG-4 Olympus E-30 Olympus E-620 Olympus E-5 Olympus PEN E-PL6 +10 more
Olympus E-30 Olympus E-620 Olympus PEN E-PL2
Torlang
Torlang Regular Member • Posts: 160
Re: Just about right
The 50-200 just don't feel right on the 620. Feels much better on my E5 with the grip. But,,,,the 50-200 goes on the 620 every now and then, as my wife uses it most of the time. Its also our trekking / hiking camera.
 Torlang's gear list:Torlang's gear list
Olympus 12-40mm F2.8 Olympus E-M1 Olympus 40-150mm F2.8 Pro
Craig from Nevada
Craig from Nevada OP Senior Member • Posts: 1,512
The 620 is my trekking camera as well.
Roger Engelken
Roger Engelken Veteran Member • Posts: 4,266
I've found the 50-200mm fits well, for me, on the E-620. I have not used it with my E-420, but have with my E-5, where it also fits and feels well. I just acquired the 35-100mm lens, and I suspect that will be used with the E-5 alone. I used the combination the other night, so I'll have to see how that went. I did find the weight noticeable, but by no means unwieldy.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 +2 more
dave gaines
dave gaines Veteran Member • Posts: 9,183
Monopod for big lenses
I  have the 35-100 and really enjoy using it too. The E-30 and E-5 are probably the right cameras to use the SHG lenses with. For long term use and slow shutter speeds during the golden hour I like to use a monopod. It not only carries the weight but also gives me more stability and less camera shake.
I have an aluminum, magnesium, titanium alloy tripod by SLIK that didn't cost an arm and a leg with a Manfrotto single axis monopod head. For the 35-100 a larger ballhead or larger single axis head by RRS or Acratech would be better than the small Manfrotto head .
Dave
No thought exists without an image. Socrates
http://whaleshark.smugmug.com
 dave gaines's gear list:dave gaines's gear list
Olympus C-8080 Wide Zoom Olympus E-330 Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED +7 more
