A desaster happend to my SD1 M
Started Jan 13, 2013 | Discussions
ArneMarco
ArneMarco Senior Member • Posts: 1,980
I don't know exactly what happend, but as I just came down from a shooting with the SD1 Merrill it fell for some reason unknown to the floor and the frontpart with the lens attachment fell off with the lens ...  ... So I hope there is something that can be fixed. Because I got the house directly from the Sigma fabric and there were no issues at all with it, I will wait for a fix what ever time it will take ... but now I am really sad ...
Sigma SD1 Sigma SD1 Merrill
joaquin100 Senior Member • Posts: 1,668
Re: A desaster happend to my SD1 M
i am sorry to hear that, maybe you have an insurance that can cover it.
J.
ToasterFlyer Veteran Member • Posts: 3,213
:(.. sorry to read that.  Can you take an image of the damage and post it.
Rich
ny
ArneMarco
ArneMarco OP Senior Member • Posts: 1,980
A photo of the damage
jbr Regular Member • Posts: 294
Re: A photo of the damage
ArneMarco wrote:
Looks like it's just the lens came apart. You should be able to remove the rest of the lens and test with another. Joe
ArneMarco
YES!, you are right ...  It is not the camera, but the lens which is broken ... puuhh ... I just tested the camera and it works ... I think I was so shocked, that I thought the camera was gone ...
xpatUSA
xpatUSA Senior Member • Posts: 7,144
In the same way that the front of a car crumples in order to save the occupants, it looks like the lens died to save your camera!
Ted.
Sigma DP2s Panasonic Lumix DMC-G1 Sigma SD10 Sigma SD14 Sigma SD1 Merrill +8 more
Tiger1 Regular Member • Posts: 364
Looks like a good excuse to buy the new 17-70mm lens which has just been released. Apparently made along the same lines as the 35mm F1.4!
 Tiger1's gear list:Tiger1's gear list
Sony RX1 Canon EOS 5D Mark II Fujifilm FinePix S5 Pro Sigma SD14 Sigma SD1 Merrill +8 more
Ceistinne Contributing Member • Posts: 837
Sorry about your disaster. The same thing happened one of my lenses and it was repaired as good as new.Make sure the focus screen has not been unseated, but you will know that easily enough if all is well with another lens mounted on the camera. Mine hit the floor so hard that it popped the focus screen and left it loose on the mirror. the camera, SD15,  is still working perfectly.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Nikon Coolpix P7000 Sigma dp2 Quattro Nikon D700 Sigma SD9 +3 more
victorgv Senior Member • Posts: 1,323
From the photo it looks  like If you are good with soldering gun and glue it is possible to fix it yourself. One connector tore clear off but circuit board does not look damaged so you need just resolder it.
 victorgv's gear list:victorgv's gear list
Sigma DP1 Sigma DP2 Merrill
New lens barrell parts required I'd say as the retaining mounts are broken. See enlarged with loupe view.  Other than that all else looks ok.
S
A picture is truly worth a 1,000 words.. eh at least it is just the lens.. :).
Rich
S
This why i said glue
Joerg V Contributing Member • Posts: 609
What a brave lens!
Seriously, seeing the first image I literally convulsed in pain. I still can remember how shocked I was when my DP1 slipped out of my hands (once in many years). I was like "ohmygodohmygodohmygodohmygodohmygod".
Good to hear that the camera is alive and kicking.
Joerg
 Joerg V's gear list:Joerg V's gear list
Sigma DP1 Nikon D800 Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.8G Sigma 35mm F1.4 DG HSM Art +3 more
ArneMarco
Yes, it seems so ... I have yet to test if the sharpness is somehow disturbed ... if not, I will be happy. The lens is much cheaper than the house ...
ArneMarco
Yes, I am waiting for the 35mm ... and now I have a reason to buy the new 17-70 ...
ArneMarco
I have never soldered anything ... so it is not the moment to start now  ... Maybe I will ask the repair shop at my retailer if there is something to be done ...
FritsThomsen Senior Member • Posts: 2,759
Last year , I had the rear barrel of my 180mm macro replaced in an authorized repair shop here in Denmark ..the price was approx 1200 DKr.
guzzibreva1 Contributing Member • Posts: 947
It looks like there are some advantages to a camera body made of magnesium.
It put the pain in a less expensive place.
