My GH3 EVF - a new observation and opinion
Started Jan 12, 2013 | Discussions
sea_dragon Contributing Member • Posts: 742
6
 sea_dragon's gear list:sea_dragon's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Leica Summilux DG 25mm F1.4 +4 more
Panasonic Lumix DMC-GH3
ryan2007 Forum Pro • Posts: 12,001
Re: My GH3 EVF - a new observation and opinion
Their was never anything wrong with the GH-3 viewfinder.
I hear more complaints about the Olympus OMD.
AoxoA
AoxoA Regular Member • Posts: 295
Of course you do...
 AoxoA's gear list:AoxoA's gear list
Olympus E-3 Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +6 more
s_grins
s_grins Forum Pro • Posts: 10,253
My guess that Panasonic put cheap, maybe  stamped plastic, dioter lens on the top of EVF, and this is bad.
Another thought: to make sure your test is correct, ask somebody else who does not have eye problems to check your EVF the same way you conduct it with your wife
Regards
S.
Looking for equilibrium...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
RicksAstro
RicksAstro Veteran Member • Posts: 3,543
From what I've observed here, I suspect that the vast majority of GH3 EVFs are about the same.     There seems to be a certain set of conditions (observers eyes, astigmatism, eye position) that makes it looks worse than to others.   To those people, many are convinced all GH3 EVFs are bad, and they certainly are bad to them.   From some reports, some users have looked through multiple GH3s and they looked about the same (good or bad).
I observe large differences in ghosting when I recorded through the viewfinder and changed the zoom of my HX9V, but when I look through it using my eye (which is a -1.5 diopter prescription with some astigmatism) it looks quite sharp, with ghosting only if I move off-axis.
Rod Baakkonen
Rod Baakkonen Regular Member • Posts: 388
I've had my GH3 since Jan 3rd and don't see a problem.  I tried the demo camera in the store to see if it had a problem and could not see what people have been documenting.  Maybe some of us are just lucky to not have a camera with the issue.
Rod
 Rod Baakkonen's gear list:Rod Baakkonen's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Adobe Photoshop CS6 Adobe Camera Raw 7 +1 more
Of course you do...
I see you do not disagree.
Serenoa Forum Member • Posts: 75
My GH3 is about a week old, and I have upgraded from the G2 which I used for about 2 years.
I have extremely poor close vision (prescription more than +5 and other adjustments).  What I like about both the G2 and now the GH3 is that I can adjust the EVF diopter to the extreme and use the EVF without my glasses.  I need the glasses on to use the larger monitor panel.
I primarily shoot using the EVF because it looks clearer to me and easier to focus.
That said, I was concerned before my GH3 arrived last week, after reading all the posts about the blurring problems. Thankfully, it is not a problem for me and I am very happy with the camera.
My EVF is perfectly clear to me (with the diopter adjusted to max) and the only way I can even get any kind of blur on the display is if I cant/tilt my head towards the side (so that my eye is no longer parallel to the EVF).  But at that point, part of the screen is blackened out on the opposite side, so it is not anything I would ever be tempted to do.
I think the problem is only visible if you do not have the camera appropriately held up to your eye. I have the top of the rubber EVF surround resting on my brow bone on the top of my eye.
 Serenoa's gear list:Serenoa's gear list
Panasonic Lumix DMC-TZ5 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GH3 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +5 more
Inkheart Regular Member • Posts: 425
I think there might be something wrong with this EVF. Let's take a look at Sony's EVF - it is generally highly praised and probably currently the best out there. So, if there is an EVF that does not create so much controversy and is commonly considered very good, than if the EVF of the GH3 is so much criticized it must simply mean that it's not that good.
And I guess that's the biggest problem. It may be good, but it could have been better, and that's what people are expecting from a top of the line camera, especially since better EVFs have been out for a few years now.
Inkheart
 Inkheart's gear list:Inkheart's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital 17mm 1:1.8 +2 more
Aleo Veuliah
Aleo Veuliah MOD Forum Pro • Posts: 14,628
sea_dragon wrote:
I use contact lenses, and with them I did not found any fault on the GH3 EVF.
Simplicity is the ultimate sophistication.
God always take the simplest way.
Imagination is more important than knowledge.
God is the tangential point between zero and infinity.
Aleo Photo Site
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GH4 +4 more
Alband
Alband New Member • Posts: 4
I got my GH3 December 13., and my fiirst impression of the viewfinder after adjusting the diopter was: " Wow, - this is better than the GH2 ! ".
The picture in the viewfinder seems to be a little smaller compared to both GH1 and GH2, but sharpness, contrast and color is considerably better, - in my opinion.
The central, magnifying part of the diopter also appears to be a little smaller in GH3 compared to preceding GH cameras, and this may cause the modest degree of distortion that occurs when the eye is off-center in the viewfinder. I did not experience this as a problem, - adaption didn't take long. I use reading glasses (+ 2.50), by the way.
Bralte
 Alband's gear list:Alband's gear list
Canon PowerShot SD950 IS Nikon D800 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +6 more
Nikcan
Nikcan Senior Member • Posts: 1,417
Bralte
My two pennies  in the subject, I have had the GH3 a month now, and wear bifocals. Today as it was not raining in the UK for a change so I went to a local park and fitted the 100-300 mm lens on the GH3 to primary take bird pictures on the lake. A while later I got out my GH2 to take a few landscape shots with an old 14-45mm and boy what a difference the viewfinder was.
The GH3 viewfinder was much better and I was surprised as I have had the GH2 for nearly two years. The corners are sharper, the viewfinder has better clarity and colour. I am 66 years old and have just booked an eye test after two years of having my glasses.
Best Regards Mike.
http://michaelgoodes.blogspot.com/
http://ekim.zenfolio.com
'Live every day as if it was your last, one day it will be'.
 Nikcan's gear list:Nikcan's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 +9 more
Pete Berry Senior Member • Posts: 2,587
Mine a disappointment
Bralte
Best Regards Mike.
First, it's 4/3 view is significantly smaller than the GH1-2's EVF's, by virtue of being a crop of it's native 16:9 format rather than native 4:3. This computes to a 25% dimension decrease on each axis, and was striking to me on first comparison look.And not as detail rich due to smaller size. But in comparison to the OMD's relatively tiny one, it's still pretty big!
Next, it's color rendition simply doesn't "do" reds - all are shades of orange, with the secondary problem of lack of red being blue purple/violets - GH1-2 much more accurate color-wise. The GH3 does excel in contrast and saturation though. Am I the only one with a significant color problem - which, incidentaly was barely affected with the EVF color controls. Am I the only one who sees this color problem?
All-in-all disappointing, but with all the rest the GH3 brings to the table, not a killer.
Pete
guybie Contributing Member • Posts: 795
As a result of your post, i double checked and, as i mentioned before, i can't see anything wrong with my EVF! I see exactly the same perfect image as on the LCD.
 guybie's gear list:guybie's gear list
Olympus XZ-2 iHS Panasonic Lumix DMC-FZ1000 Canon EOS 7D Mark II Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III +5 more
brianf Senior Member • Posts: 1,225
Re: Mine a disappointment
Hi Pete,
The colours on my Evf are exactly as you described yours, I also have a GH2 and the Evf colour is fine on it but my Gh3 reds are wrong purple / violet is displayed as pale blue and some types of green foliage  is more a dirty yellow,.
Adjusting the tint controls does not improve things much, I bought mine from Mathers in Lancashire and returned it once as they were  happy to exchange it but when they received it and checked it against another from stock the new one was the same so I just assumed they all have poor Evf colour.
I am not so sure now as some users are happy with the colour and  some are reporting the same issue as me, I will wait for more user comments on this before deciding whether to return itagain or not.
Cheers.
Brian.
 brianf's gear list:brianf's gear list
Canon PowerShot N
Nikcan
Sorry but so do I, the colours are fine. Btw, I only take raw, are you doing Jpegs and comparing with the end result? I am so sorry that you are having problems, I think the GH3 as a massive step up from the GH2 camera, viewfinder, colour, noise, and even quality wise. Love the level guide as I use it with the 7-14 mm Panasonic and it is magic to use to help with distortion. AND the silly white balance button is now were it should be, on top of the camera.
Best Regards Mike.
StevenN Senior Member • Posts: 1,062
Vision impairments
sea_dragon wrote:
I have astigmatism and wear contact lenses and have absolutely no problems with my GH3's viewfinder. It is sharp and clear from corner to corner.
Maybe you should try wearing contacts?
StevenN
 StevenN's gear list:StevenN's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-GH3 Fujifilm X-A1 Nikon D750 Panasonic Lumix DMC-GM5 +8 more
jalywol
jalywol Veteran Member • Posts: 7,284
Are you finding your output in general is lacking in reds or just the EVF?  I did notice the EVF color errors, but I also had a problem with the actual images rendering true reds.  I got a lot of pinkish reds, oranges, and brownish oranges, but no true reds when I was out shooting a lot of brickwork when I was trying the camera out.  After working with the camera for a couple of days, and not getting anywhere with it in terms of better results, I ended up returning it, thinking I had a defective unit.  I am curious if anyone else has had a similar experience.
-J
s_grins
Could it be sRGB - aRGB mismatch?
-J
B
Just the EVF, and to a lesser extent the monitor.
Pete
