G15 low light issue
5 months ago
I am somehow unable to set higher iso than 80 while having shutter speed slower than 1". On 1" I can set any iso I like, but on 1"3 I am suddenly forced to use iso 80. That is surprising on a camera that should be good in low light conditions.
Also, is there a bulb mode? I can't find it.
By Design
In reply to Funderadus,
5 months ago
This is by design, probably to help with sensor noise from longer exposures. And they probably feel that shutter speeds longer than 1 second would not be hand-holdable.
No bulb mode but there should be hacked firmware available soon.
Re: By Design
In reply to MisterPootieCat,
5 months ago
This does not make sense to me. I have never seen such behaviour from any other camera. I bought it mainly to take shots of night city. 5" and iso400 would be perfectly fine for me. But 1" and iso 3200 is too noisy and 15" and iso80 is to dark and too slow. I am very angry, because now I will have to buy another camera.
Re: By Design
5 months ago
You should have done your homework. Most Canon compact cameras these days have this behaviour. It's annoying, but that's the way it is.
Re: By Design
In reply to photofan1986,
5 months ago
Damn. So I have two questions:
1) is there any chance this would be allowed in alternative firmware?
2) What camera should I buy in similar price level that has remote control, fast lens (not necessailry as fast as G15) that does not have this idiotic feature? (I know about XZ-1, but it has terrible movies)
Re: By Design
5 months ago
You should be glad instead, 15 sec, iso80 will collect 3x more light/photons than 5 sec, iso400, and will therefore give you better IQ. If 15 sec, iso80 gives a JPEG that's to dark, then just shoot RAW and increase the brightness in the RAW converter.
Re: By Design
5 months ago
I think you know the answer already, it's simple it's the XZ-2 !!!
Re: By Design
In reply to Steen Bay,
5 months ago
Well, I was not precise with the numbers, I am sorry. My point was: now I am forced to use long exposures while it would be ok to use much faster exposures with some noise in the picture. It is enthusiasts camera and enthusiasts do now what consequences result from using hi iso and long exposure.
Re: By Design
In reply to phototherapy,
5 months ago
It is another 100usd, which is over my budget, given that now I lost some money on buying wrong (but otherwise perfect) camera.
Re: By Design
5 months ago
Read the manual p. 162, middle of page.
Phil
Re: By Design
In reply to PC Wheeler,
5 months ago
Phil
Thaks Phil. Could you by more specific, please? I turned off the IS, but it does not make any difference. And there is no explanation of this behaviour.
G15 user manual p.162: "While shutter speed 1.3 or slower, ISO speed is 80 and cannot be changed."
Re: G15 low light issue
5 months ago
Use manual mode in that situation then you can increase your ISO.
That doesn't work
In reply to Darren N,
5 months ago
Even when set to manual mode the ISO will be forced to 80 for shutter speeds lower than 1 second.
Re: That doesn't work
5 months ago
Sorry about that but it don't on my G12 Just tried it.
Re: By Design
5 months ago
OK, but still, if you shoot RAW, then it doesn't really matter. Let's say that you want to shoot at 5 sec, iso400. That's not possible (for whatever reason), but then you can just shoot at 5 sec, iso80 instead and push the exposure/brightness a bit more than two stops afterwards in the RAW converter. The final result will be pretty much the same as if shooting at 5 sec, iso400. You are not forced to use a longer shutterspeed than you want to. But on the other hand, a longer exposure will collect more light and give you better IQ, so why not?
5 months ago
Yeah. You are correct about being able to do it on the G12. I just did on mine also.
But when I tried it on the G15, it doesn't work. I just set M mode, 1/125 sec and f4.0, ISO 3200. Then I lowered the shutter speed with the front dial a click at a time. As soon as it crossed 1 second, the ISO dropped to 80 and grayed out, so that it could not be changed. But that had worked OK on the G12, and I went down to 13 seconds with the ISO still at 3200.
kind regards
Dale
In reply to Dale Buhanan,
5 months ago
Must be a new thing on the G's now. I suppose if you need a tripod anyway it keeps it at 80 ISO to minimise noise.
if you want to do it in black & white & add a bit of noise or freeze something using the fastest speed possible then I guess your stuffed.
5 months ago
Darren N wrote:
Must be a new thing on the G's now. I suppose if you need a tripod anyway it keeps it at 80 ISO to minimize noise.
The G15 loses the dedicated ISO dial, apparently that wasn't everything it lost.
5 months ago
Nice one Canon!.
Re: By Design
5 months ago
Thanks a lot, I'll definitely try it asap. The problem with long exposure is that I am going to have people in the pictures. I don't care if they are a little bit blurred, but it has to be recognizable who is it. I bought this camera for urban exploration, in other words just for documentary pictures.
