Action self portrait with the A57
Started Jan 12, 2013 | Discussions
Benjamin Marsh Regular Member • Posts: 107
7
Needed a shot of someone training on a particular route for a photo competition relating to a race I am entering, fitting it in after work in the absence of a photographer/subject combination I took our my timer remote and did it by myself.  Rather happy with the result
 Benjamin Marsh's gear list:Benjamin Marsh's gear list
Samsung NX200 Sony SLT-A57 Sony DT 35mm F1.8 SAM Samsung NX 20-50mm F3.5-5.6 ED +1 more
Sony SLT-A57
brian14478
brian14478 Senior Member • Posts: 3,703
Re: Action self portrait with the A57
Looks like maybe a mountain lion is around that bend and you gotta haul az*....ha ha . Seriously though nice shot and timing. Good luck with the race and contest....brian
Fulton17 Regular Member • Posts: 107
And so you should be - I enjoyed the dust behind you and it looks like you are running on air.
Ed at Ridersite Forum Pro • Posts: 17,232
Great job on that one!  Nice action, nice exposure, nice sharpness and nice processing.  You timed it perfectly and the dust works wonders.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
TomvL Contributing Member • Posts: 549
You should not be rather happy.
You should be Very Happy!
Both feet from the ground, the dust behind you, the scenery. Great shot!
How many times did you have to run until you had this result?
Sonyshine
Sonyshine Senior Member • Posts: 7,830
...and you managed all that without gurning into the camera!
Impressive!
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
William Porter Senior Member • Posts: 1,676
Yes, I concur. +1!
I was wondering exactly the same thing.
Will
 William Porter's gear list:William Porter's gear list
Panasonic Lumix DMC-LX7 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +7 more
john farrar
john farrar Veteran Member • Posts: 5,038
That one could be a winner.
How did you work it out.... burst? number of steps past the tree? And did you know the dust might kick up perfectly like that?
walking dude Contributing Member • Posts: 529
Run Benjamin....RUN!!
 walking dude's gear list:walking dude's gear list
Sony SLT-A99 Tamron SP AF 90mm F/2.8 Di Macro Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Tamron SP 70-300mm F/4-5.6 Di USD Tamron SP 24-70mm F2.8 Di VC USD +1 more
Benjamin Marsh OP Regular Member • Posts: 107
I set the timer to wait about 8 seconds then use bulb for about 5-6 seconds (I mixed this up between a few runs), having the camera pre focused and on the 12 FPS setting it just went straight to burst mode after the delay (which gave me time to run to the corner and turn around)
In all between all my fiddling I took about 300-350 photos with probably about 10 or so passes by the camera, there were a few other good photos from the lot but this was my favourite.
I was rather aware after a bit of dabbling how I had to run to kick up the dust for the effect which I thought would work quite well.
The lens is my favourite at the moment, the 35mm 1.8.
