I think SR causes image blur
Started Jan 10, 2013 | Discussions
guzzibreva1 Contributing Member • Posts: 948
I have noticed that it is hard to get a razor sharp image unless I use a flash or tripod with long exposure with my K5. Shutter speeds faster than 1/200 are not usually a problem when hand held.
I can't help but think that since the sensor is mounted on a movable mechanism there would be a tendency for this to be subject to vibrations that occur faster than the gyro feedback from the SR system.
Has anyone else experienced this tendency?
Pentax K-5
Simon Devlin
Simon Devlin Senior Member • Posts: 1,326
Re: I think SR causes image blur
At high shutter speeds or tripod mounting you are meant to switch the SR off.
I have no problem with SR even if I forget to leave it on!
Are you pixel peeping?
Simon
Legacy lens lover
Simon Devlin
Ooooops, I have a K-30 btw.
Simon
Legacy lens lover
guzzibreva1 OP Contributing Member • Posts: 948
I always turn off SR and use time delay when using tripod. The results then are always good. It just that it seems quite often there is a blur in one axis when SR is on using the camera hand held. I am pixel peeping for sure but I like to make large prints and it does show then.
Maybe the problem is that I never had a camera with this high  resloution and small defect are more visible.
Nick Savoiu Senior Member • Posts: 1,631
SR has a setup time for each shot. Use PhotoME to check if the shot was fully stabilized. Otherwise SR might not have been fully effective.
DrewE Senior Member • Posts: 2,053
Have you tried comparing shots with SR and without SR under identical circumstances?  I suspect you may well find that the non-SR shots are even more blurred.
--DrewE
 DrewE's gear list:DrewE's gear list
Pentax K10D Pentax K-5 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 40mm F2.8 Limited Voigtlander 58mm F1.4 Nokton SL II +3 more
I think I have found my problem.  If the camera has been somewhat motionless prior to the shot, the shake reduction is just as quick as auto focus. If I move the camera somewhat then take the shot the auto focus is too quick for the SR to be ready.
SRT201
SRT201 Senior Member • Posts: 2,342
My initial experience with SR using a Kx was much the same.  If the setup time doesn't elapse you can get a blurry shot.  Fortunately the K5 setup time is a LOT shorter than the Kx.
Any government that has the power to correct any injustice and level any inequality also has the power to do ANYTHING it wants.
Giant Tsunami
Giant Tsunami Forum Member • Posts: 91
I went through this question myself, I am no lab tech but in the tests I did I found no difference if the factors were identical. I cared as you do becuase I often magnify the small detail in my shots (through cropping tho, not large print), so for me it was also very important, hence the reason I bought a IIs. I can say I now shoot with IS on all the time, and if it were going to show a flaw on any pentax camera, it would be the IIs. Any little thing shows on this camera as the sharpness ceiling is quite high. I would shoot away using IS and not worry, it will be no worse than having it off. The only downside I can think of is perhaps a small battery drain?
audiobomber
audiobomber Veteran Member • Posts: 5,299
Nope!
I've tested this many times. I get better results with SR when it's needed, and have found no ill effects when it's not needed. I use SR at all times except when on tripod. IOW, I use SR even with high shutter speeds, on a monopod and when panning.
Dan
 audiobomber's gear list:audiobomber's gear list
Pentax K-3 Sony a6000 Pentax K20D Pentax smc D-FA 100mm F2.8 macro Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye +17 more
MonkRX Regular Member • Posts: 206
I'll echo the rest of the group. SR and Auto Focus both need to be "ready" for a sharp image. Off topic, but SR on my K-x is slightly buggy too. I get tons of double images at certain shutter speeds.
Pentax could definitely use a little more R&D with the SR tech. It could use a fair bit more optimization.
 MonkRX's gear list:MonkRX's gear list
Pentax K-01 Pentax K-5 IIs +1 more
Petroglyph
Petroglyph Senior Member • Posts: 4,973
After about 10K shots with a K5 I can say the SR always stays on for me.  (I have even left it on during video recording and I think it actually helped but that might be folklore.)  I was even hoping Pentax would start anti-aliasing the K5IIs by moving the sensor one pixel width around a square pattern during the shutter release.  Bet they've already thought of that.
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +5 more
KRG1953
KRG1953 Regular Member • Posts: 253
I am also a happy K-x user. But sometimes i also get a blurry pic. And when i analyse ths via Photome I also see Sometimes Not ready, or sometimes not stabilized. Both occur.
Esspecially when you take multiple shots of the same object several seconds after each other.
It takes time for the SR to get ready apperently. You can see this in the viewfinder but i mostly don't look at the symbol.
 KRG1953's gear list:KRG1953's gear list
Pentax K-x Pentax K-S2 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax 18-50mm F4.5-5.6 Pentax smc DA 18-55mm F3.5-5.6 ED AL II (IF) +3 more
Matthew Miller
Matthew Miller Senior Member • Posts: 1,310
Wait for the hand
Yes. Half-press the shutter and wait. A green "hand" indicator will appear in the viewfinder when SR is ready. If you take the photo before that, SR can add additional blur.
Matthew Miller « http://mattdm.org/ »
 Matthew Miller's gear list:Matthew Miller's gear list
Pentax K-5 II Fujifilm X-T10 Pentax smc DA 40mm F2.8 Limited Pentax smc DA 70mm F2.4 AL Limited Fujifilm XF 23mm F1.4 R +5 more
+1 to the guy who never checks the "SR" ready symbol. I never look either.
There should be a custom menu option to have an additional "beep" when SR is ready. So you have confirmation of both AF and SR through visual and auditory senses. Or Pentax could simply perfect the SR system
Simon Devlin
I have to admit I didn't know that either!
+2
Simon
Legacy lens lover
awaldram
awaldram Forum Pro • Posts: 12,316
How about a hand that pops out slaps you and a voice saying take the shot dummy
Seriously Pentax et al can only hold the photgs hand so much a certain level of ability has to remain the province of the human element else why not just get rid of this constantly failing part altogether (humanless images)
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax Q7 Pentax K-x Pentax smc DA 40mm F2.8 Limited +15 more
bjake Regular Member • Posts: 327
Used a K-X for about two years and found sr was good on handheld shots but turned it off when shooting flying birds and such.Shooting macro and close up was getting too many blurred pictures and found leaving sr off got a lot more keepers.It shouldn't have been setup time as I always shoot these all manual including focus.Got a K-5 a couple month's ago,not had a chance to check this out on it but will when spring comes,flowers bloom and bees fly.
SRT201
Of course with the Kx you also have some serious, audible mirror slap going on.  I find my Kx is not really useful for long tele for that reason.  Sometimes I would get sharp, other times the slap was evident.
SRT201
Re: Nope!
I will second that.  I have found SR to help at shutter speeds even above 1/500 with long tele lenses.
