DP3 Merrill leaked
Started Jan 7, 2013 | Discussions
nandadevieast Regular Member • Posts: 400
DP3 Merrill leaked
Sigma DP3 Merrill
PicOne
PicOne Veteran Member • Posts: 6,923
Re: DP3 Merrill leaked
nandadevieast wrote:
http://www.mirrorlessrumors.com/sigma-dp3-merrill-pics-and-specs-leaked/
Interesting, though I don't understand why a 50mm (75mm equivalent) version would be labelled as the "all rounder" within Sigmas 3 camera choices?
'Everything in photography boils down to what's sharp and what's fuzzy.'
-Gaylord Herron
FritsThomsen Senior Member • Posts: 2,759
This new camera should be able to do MACRO, PORTRAITS, some landscape -work ..thats is pretty allround , I guess
-Gaylord Herron
zodiacfml Contributing Member • Posts: 521
-Gaylord Herron
Interesting indeed. I studied the leaked image and found the lens housing a little bit larger and the glass opening quite larger compared to the DP2M which makes me feel that its plausible. I'm not quite excited as the max aperture is pretty lacking for producing bokeh in portraits and the focal length quite limiting for plenty landscapes but I'm confident that the lens performance is even better than the DP2M's.
 zodiacfml's gear list:zodiacfml's gear list
Sigma DP2
mike earussi Veteran Member • Posts: 5,727
Here's hoping they've also improved the buffer and write speed.
nandadevieast OP Regular Member • Posts: 400
But the million dollar question is, SKIN TONES !!
villebon Senior Member • Posts: 2,185
Another fixed lens cameras! Has Sigma not heard about the ILC concept?
Villebon
gooseta
gooseta Contributing Member • Posts: 707
me want. finally able to utilize the foveon sensor for macro... Should be better than my K5iis and sigma 70 for sharpness
Angad S. aka gooseta
LBA and CBA haunt me.
angadsrin.zenfolio.com
K5iis with DA 17-70/4, 35/2.4, M 50/1.7, Tamron 70-200/2.8, Sigma 70/2.8 macro
Sigma DP1 MERRILL WOOHOO
Isold the sony stuff!
 gooseta's gear list:gooseta's gear list
Pentax K-3 Pentax smc DA 17-70mm F4.0 AL (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Sigma 70mm F2.8 EX DG Macro Sigma 8-16mm F4.5-5.6 DC HSM +1 more
The lens focusses down to 23 cm, and macro is 1:3
steven_k Regular Member • Posts: 496
Villebon
They have, it's called the SD1M, the problem is there lenses are mostly not good enough, and with no LV focusing can be a real bitch.
Just have to wait and see
Andrewteee Senior Member • Posts: 2,668
I recall a comment a long time ago that Sigma's original intent was to produce three DP cameras. So perhaps now we finally have that trio.
 Andrewteee's gear list:Andrewteee's gear list
Leica Q Ricoh GR II Ricoh GXR A12 50mm F2.5 Macro Olympus PEN-F Olympus M.Zuiko Digital 25mm F1.8
maple Veteran Member • Posts: 3,098
DP is solution for lack of wide lenses for SD. Now that we have the 35mm 1.4 working great on SD, DP with lens longer than that is less attractive.
A 24mm DP makes more sense to me.
Maple
ArneMarco
ArneMarco Senior Member • Posts: 1,974
To me the problem would be the lack of a viewfinder ... I don't want to buy a camera without a real VF ever again ...
gooseta
The range would ideally for me include four cameras
DP1M - An 18mm (27mm equiv), ever so slightly wider
DP2M - same
DP3M - 40mm (60mm equiv)
DP4M - ultrawide, maybe 14mm (21mm equiv)
Oliver_B Contributing Member • Posts: 831
Yes, 1:2.8 may also be a little slow, all things considered. Anyway, I am really willing to belive in this one to be true.
 Oliver_B's gear list:Oliver_B's gear list
Sigma DP1 Sigma DP3 Merrill
Dave Miner Regular Member • Posts: 422
New software leaked?
That's wha should happen first.
 Dave Miner's gear list:Dave Miner's gear list
Sigma DP2 Merrill
Re: New software leaked?
Nooo, the software is too leaky already!
HBowman
HBowman Senior Member • Posts: 1,213
Today, you can circumventing the "Skin tone problem" with two things : Correct lighting and or some adjustments in apps (Photoshop or other). So at the end this is not really a problem.
For me, this DP is a damn great news, just magic. A very good start of 2013 !!
Kind regards - www.hulyssbowman.com
Noted, color is not the main problem. SPP has serious performance issues which are much more of a concern.
Indeed! After a miserable monday full of petty annoyances, this rumor made me smile.
petr marek Regular Member • Posts: 178
steven_k wrote:
Villebon
They are lots of great lenses (Leica, Voigtlander, Canikon, Oly...........), but Sigma have to use universal M43 mount:
http://www.flickr.com/photos/hhackbarth/5456405797/
http://www.flickr.com/photos/hannes_frick/5706330874/
etc...
They have probably problem with that... Marketing problem... With such a beauties I wouldn´t mind manual focusing and manual aperture at all !!!
